Software:
Using sdfat sdinfo with everything wired default:
* This program attempts to initialize an SD card and analyze its structure.
#include "SdFat.h"
#include "sdios.h"
Set DISABLE_CS_PIN to disable a second SPI device.
For example, with the Ethernet shield, set DISABLE_CS_PIN
to 10 to disable the Ethernet controller.
const int8_t DISABLE_CS_PIN = -1;
Change the value of SD_CS_PIN if you are using SPI
and your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else // SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif // SDCARD_SS_PIN
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SD_SCK_MHZ(16))
#else // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(16))
#endif // HAS_SDIO_CLASS
SdFs sd;
cid_t cid;
csd_t csd;
scr_t scr;
uint8_t cmd6Data[64];
uint32_t eraseSize;
uint32_t ocr;
static ArduinoOutStream cout(Serial);
void cidDmp() {
cout << F("\nManufacturer ID: ");
cout << uppercase << showbase << hex << int(cid.mid) << dec << endl;
cout << F("OEM ID: ") << cid.oid[0] << cid.oid[1] << endl;
cout << F("Product: ");
for (uint8_t i = 0; i < 5; i++) {
cout << cid.pnm[i];
cout << F("\nRevision: ") << cid.prvN() << '.' << cid.prvM() << endl;
cout << F("Serial number: ") << hex << cid.psn() << dec << endl;
cout << F("Manufacturing date: ");
cout << cid.mdtMonth() << '/' << cid.mdtYear() << endl;
cout << endl;
void clearSerialInput() {
uint32_t m = micros();
do {
if (Serial.read() >= 0) {
m = micros();
} while (micros() - m < 10000);
void csdDmp() {
eraseSize = csd.eraseSize();
cout << F("cardSize: ") << 0.000512 * csd.capacity();
cout << F(" MB (MB = 1,000,000 bytes)\n");
cout << F("flashEraseSize: ") << int(eraseSize) << F(" blocks\n");
cout << F("eraseSingleBlock: ");
if (csd.eraseSingleBlock()) {
cout << F("true\n");
cout << F("false\n");
cout << F("dataAfterErase: ");
if (scr.dataAfterErase()) {
cout << F("ones\n");
cout << F("zeros\n");
void errorPrint() {
if (sd.sdErrorCode()) {
cout << F("SD errorCode: ") << hex << showbase;
printSdErrorSymbol(&Serial, sd.sdErrorCode());
cout << F(" = ") << int(sd.sdErrorCode()) << endl;
cout << F("SD errorData = ") << int(sd.sdErrorData()) << dec << endl;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
if (!sd.card()->readSector(0, (uint8_t*)&mbr)) {
cout << F("\nread MBR failed.\n");
errorPrint();
return false;
cout << F("\nSD Partition Table\n");
cout << F("part,boot,bgnCHS[3],type,endCHS[3],start,length\n");
for (uint8_t ip = 1; ip < 5; ip++) {
MbrPart_t *pt = &mbr.part[ip - 1];
if ((pt->boot != 0 && pt->boot != 0X80) ||
getLe32(pt->relativeSectors) > csd.capacity()) {
valid = false;
cout << int(ip) << ',' << uppercase << showbase << hex;
cout << int(pt->boot) << ',';
for (int i = 0; i < 3; i++ ) {
cout << int(pt->beginCHS[i]) << ',';
cout << int(pt->type) << ',';
cout << int(pt->endCHS[i]) << ',';
cout << dec << getLe32(pt->relativeSectors) << ',';
cout << getLe32(pt->totalSectors) << endl;
if (!valid) {
cout << F("\nMBR not valid, assuming Super Floppy format.\n");
return true;
void dmpVol() {
cout << F("\nScanning FAT, please wait.\n");
int32_t freeClusterCount = sd.freeClusterCount();
if (sd.fatType() <= 32) {
cout << F("\nVolume is FAT") << int(sd.fatType()) << endl;
cout << F("\nVolume is exFAT\n");
cout << F("sectorsPerCluster: ") << sd.sectorsPerCluster() << endl;
cout << F("fatStartSector: ") << sd.fatStartSector() << endl;
cout << F("dataStartSector: ") << sd.dataStartSector() << endl;
cout << F("clusterCount: ") << sd.clusterCount() << endl;
cout << F("freeClusterCount: ");
if (freeClusterCount >= 0) {
cout << freeClusterCount << endl;
cout << F("failed\n");
errorPrint();
void printCardType() {
cout << F("\nCard type: ");
switch (sd.card()->type()) {
case SD_CARD_TYPE_SD1:
cout << F("SD1\n");
case SD_CARD_TYPE_SD2:
cout << F("SD2\n");
case SD_CARD_TYPE_SDHC:
if (csd.capacity() < 70000000) {
cout << F("SDHC\n");
cout << F("SDXC\n");
default:
cout << F("Unknown\n");
void printConfig(SdSpiConfig config) {
if (DISABLE_CS_PIN < 0) {
cout << F(
"\nAssuming the SD is the only SPI device.\n"
"Edit DISABLE_CS_PIN to disable an SPI device.\n");
cout << F("\nDisabling SPI device on pin ");
cout << int(DISABLE_CS_PIN) << endl;
pinMode(DISABLE_CS_PIN, OUTPUT);
digitalWrite(DISABLE_CS_PIN, HIGH);
cout << F("\nAssuming the SD chip select pin is: ") << int(config.csPin);
cout << F("\nEdit SD_CS_PIN to change the SD chip select pin.\n");
void printConfig(SdioConfig config) {
(void)config;
cout << F("Assuming an SDIO interface.\n");
// Wait for USB Serial
while (!Serial) {
yield();
cout << F("SdFat version: ") << SD_FAT_VERSION_STR << endl;
printConfig(SD_CONFIG);
// Read any existing Serial data.
clearSerialInput();
// F stores strings in flash to save RAM
cout << F("\ntype any character to start\n");
while (!Serial.available()) {
yield();
uint32_t t = millis();
if (!sd.cardBegin(SD_CONFIG)) {
cout << F(
"\nSD initialization failed.\n"
"Do not reformat the card!\n"
"Is the card correctly inserted?\n"
"Is there a wiring/soldering problem?\n");
if (isSpi(SD_CONFIG)) {
cout << F(
"Is SD_CS_PIN set to the correct value?\n"
"Does another SPI device need to be disabled?\n"
errorPrint();
return;
t = millis() - t;
cout << F("init time: ") << dec << t << " ms" << endl;
if (!sd.card()->readCID(&cid) ||
!sd.card()->readCSD(&csd) ||
!sd.card()->readOCR(&ocr) ||
!sd.card()->readSCR(&scr)) {
cout << F("readInfo failed\n");
errorPrint();
return;
printCardType();
cout << F("sdSpecVer: ") << 0.01*scr.sdSpecVer() << endl;
cout << F("HighSpeedMode: ");
if (scr.sdSpecVer() &&
sd.card()->cardCMD6(0X00FFFFFF, cmd6Data) && (2 & cmd6Data[13])) {
cidDmp();
csdDmp();
cout << F("\nOCR: ") << uppercase << showbase;
cout << hex << ocr << dec << endl;
if (!mbrDmp()) {
return;
if (!sd.volumeBegin()) {
cout << F("\nvolumeBegin failed. Is the card formatted?\n");
errorPrint();
return;
dmpVol();
Output:
Card type: SDHC
sdSpecVer: 3.00
HighSpeedMode: false
Manufacturer ID: 0X3
OEM ID: SD
Product: SL32G
Revision: 8.0
Serial number: 0X29A5A83
Manufacturing date: 7/2014
cardSize: 31914.98 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
dataAfterErase: zeros
OCR: 0XC0FF8000
SD Partition Table
1,0X0,0X82,0X3,0X0,0XC,0XFE,0XFF,0XFF,8192,62325760
2,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
3,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
4,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0X0,0,0
Volume is FAT32
sectorsPerCluster: 64
fatStartSector: 9362
dataStartSector: 24576
clusterCount: 973584
freeClusterCount: failed
SD errorCode: SD_CARD_ERROR_READ_TOKEN = 0X19
SD errorData = 0XFC
Hardware:
Adafruit SD Breakout Board: MicroSD card breakout board+ : ID 254 : $7.50 : Adafruit Industries, Unique & fun DIY electronics and kits
ELEGOO Nano V3.0: ELEGOO Nano V3.0 Compatible With Arduino IDE (x3) – ELEGOO Official
Wiring images:
What could be the problem?
