Advice on which board we should choose
Hello,
We want some advice on which board we should choose for the following project:
We want to be able to
Read our HID card(RFID)
Verify that the card number is valid by executing a MS SQL stored procedure
Turn on a green light if it is valid or a red light if not
Send the card number to a web page like if it was entered by the keyboard
Thanks
Welcome to the forum
Where will the SQL database be hosted ?
It sounds like you will be comparing the card number against a database. If so, how many entries will there be in the card database ?
The SQL database is on a server where the list of employees is in a table.
We have about 300 manufacturing employees.
These modules will be installed at 4 different places in the plant.
The board will need two way communication with the server running the SQL database. Do you have anything in place such as WiFi or Ethernet ?
I don't know how many but we have multiple antennas for the WiFi.
For Ethernet via cable, not all places can be wired.
OK, so supposing that the Arduino card readers can communicate with the server using WiFi, do you have software on the server to take the card number from WiFi and send it to SQL ?
I know the Arduino card reader(MFRC522 ???) can read the card number but I thought that another Arduino module was necessary in order to read the number form the card, verify that the number is valid(SQL) and send the information to a web page via the keyboard.
These links are not using Arduino hardware (but uses the Arduino IDE). Random Nerds (Riu Santos) uses ESP32 to:
Better to attach the card reader to the PC and write code for the PC ?
@xfpd
It is important that the user data is only available on a SQL server/database/table because we don't want the HR people to manage the same information at 2 places.
@hammy
I don't know how the MFRC522 is working but is it really possible to attach the reader directly on a PC?
Using what kind of port? USB, Serial, another kind of port?
An Arduino can read the number from a card using the MFRC522, build an SQL query using the number and send it to a Web page. No keyboard is involved
Once received by the Web page your server will need to run the query and return a pass/fail message to the Arduino that sent the request. Do you have software to do that ?
Once the Arduino receives the pass/fail message it can parse it and turn on the appropriate colour LED
As you want to have a number of readers remote from the server I doubt that would be a viable solution
I've had one of these cards, to sign-in remotely, for a couple decades...
It's not RC522, but it contacts a database (just showing direct-connect to PC here).
@xfpd
I think that the reader that you indicated is for Smart Card
I don't know if you will see them but I uploaded 2 pictures of the type of cards that we have.
https://raportal.vpn.va.gov/IdentifySmartCard.aspx
@UKHeliBob
On each computer that we want to use these modules, most of the time, 3 web pages are always opened.
One where the employee can manage his/hers vacation.
One where all new job posting are displayed so an employee can apply.
One where an employee can indicate is he/she is available for overtime and when.
That is why I thought that another module(UNO, Nano, Pico or other) was necessary beside the MFRC522 so the data from card can be sent to the PC via the keyboard or using another way if it is possible.
Unless you are the company owner, you need to involve several other people so at least one person will be available to support your system once you get it going. Do not do all the design and programming yourself or when failures occur and you are on vacation, the system will stop working.
I would be surprised if a manufacturing plant with hundreds of employees would still use MFRC522 badges as most industrial plants tend to rely on more robust industrial RFID systems, based on standards like UHF RFID EPC Gen2 or higher-end HF readers with better shielding, longer range, and certified reliability.
Are you sure your employee badges are readable by a low-cost 13.56 MHz RFID reader ?
Is this the first time that you have mentioned that the reader will be used with a PC, or did I miss it previously ?
This is a homework assignment, not a practical application. Never would a company combine "jobs" and "vacation" and "overtime"
