another "avrdude: stk500_recv(): programmer is not responding" topic
Hi everybody, I'm using an Arduino uno on a Macbook Pro 5,1 with OSX 10.5.8. I'm new to Arduino, I'm using the "blink" sketch from examples to follow some tutorials but I'm always getting the same message
This must be something with my software because I've tried different perfectly working Arduino Uno boards and I always get the same result. It works perfectly on the same Macbook Pro on Windows Xp under Bootcamp.
I've read the troubleshooting guide and previous similar topics but I cannot find a solution. I'm pretty desperate because I want to use my board under OSX but It's impossible :( Any help is WELL appreciated This is the verbose output during upload:
Binary sketch size: 1026 bytes (of a 32256 byte maximum) /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/tty.usbmodem621 -b115200 -D -Uflash:w:/var/folders/v7/v7drI6o3HgWa5fNC161iq++++TI/-Tmp-/build875765460005338201.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/erarosso/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem621 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding
OK. Problem fixed after disinstalling internet key’s drivers. Hope it helps.
What are internet key's drivers? I am having the same issue - doesn't work under OS X but does with windows XP.
I mean the software you install when using a Usb Internet Key. If you are using one, try to uninstall completely the software and drivers of the internet key.
