A remotely controlled LED text scroller using an Arduino Nano ESP32 and Arduino IoT, with brightness adjustment and thermometer, hygrometer and barometer. Intended for store use, etc.
The most important thing, I think, is the documentation. An undocumented project isn't very useful. The attached manual contains description, hardware description, parts list, code, etc.
I am sure there's better ways to share this, but this is quick and easy. Enjoy!
scrolling-display ESP.pdf (3.9 MB)
Great Job! Very nicely documented and easy to follow.
The only minor suggestion is the manual or preferably the code have links to the libraries, I for one am not familiar with all of them.
Do you mean links to Github, etc?
No the links to the libraries such as // https://docs.arduino.cc/learn/built-in-libraries/software-serial That makes it much easier for the user to get the correct library and save you a lot of questions later on.
Well for some I think I need to look at Github? This may be my ignorance speaking.
Arduino libraries:
The Arduino programming language Reference, organized into Functions, Variable and Constant, and Structure keywords.
Other:
* @file Adafruit_BMP280.h
* This is a library for the Adafruit BMP280 Breakout.
* Designed specifically to work with the Adafruit BMP280 Breakout.
* Pick one up today in the adafruit shop!
* ------> https://www.adafruit.com/product/2651
* These sensors use I2C to communicate, 2 pins are required to interface.
* Adafruit invests time and resources providing this open source code,
* please support Adafruit andopen-source hardware by purchasing products
* from Adafruit!
* K.Townsend (Adafruit Industries)
* BSD license, all text above must be included in any redistribution
This file has been truncated. show original
In case that is any help, here's the manual with that in an extra page:
scrolling-display ESP-1.2.pdf (3.9 MB)
