Antenna booster?
I'm building some projects with Arduino MKR 1010 Wifi.
Unfortunately sometimes the arduino is just too far to get proper Wifi signal even if an other device would get the wifi without issues. Also it looks like the case for some of my projects will attenuate the signal drastically.
Is there an external antenna or an antenna booster that I can use with the MKR 1010?
Thanks,
--Ben
This topic has been covered and might I suggest a little more reading in this section to find the relevant posts.
In short you cannot add and external antenna but there are methods to optimise the signals both transmitted and received.
Sorry, I searched the section I can't find any discussion on the subject.
https://forum.arduino.cc/index.php?topic=565483.0
http://forum.arduino.cc/index.php?topic=573760.0
Just two right off the bat.
Also search the MKR1000 section as it has also been covered there too.
