Hello all
I posted here because I think that my problem contains power problem but I'm not sure about it and why it is happening.
I'm using in my project three things:
1- RS232_to_TTL
2- Button
3- RTC_ds1307
I burned about 10 nano and one uno and all of them burns after about 5-10 min. or maximum 15 min. while trying to find the exact problem.
I tried to use the RS232_to_ttl with arduino separately and it worked perfectly and tried the same thing with the RTC_timer and did work perfectly too.
but the problem appears once I connect both of them to the arduino and it burns again.
in all tests I kept the button not connected to be sure that the problem could be only from two things rs232_to_ttl or the RTC_timer.
Any idea what could be the problem and how to fix it.
Best regards,,
After many more tests I found that the problem appears only when the RTC_timer is connected (I attached how I'm wiring it) so I created the circuit again without the timer and it worked perfectly.
But I don't know why it caused burning the arduino!!
