Arduino Diecimila, Arduino 0009 and OS X
I'm trying to get my Diecimila board communicating with my OS X system and don't seem to be having any luck.
I first tried just loading the usb driver that came with Arduino 0009, rebooting, plugging in the Diecimila and launching Arduino 009. Unfortunately, the usb serial driver wasn't listed under Tools -> Serial Port.
So I looked through the boards and found the posting at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1143197735, followed the instructions to re-install and still the usb serial driver wasn't listed.
So now I'm stuck. I'm not sure what I need to do in order to debug this and get the board talking with my system. Any suggestions?
Thanks.
  • Peter
There is a slightly newer version of the drivers on the FTDI website: http://www.ftdichip.com/Drivers/VCP.htm. You might try uninstalling the ones that came with Arduino and installing those.
What version of OS X do you have? Intel or PPC Mac? In the System Profiler, when the board is connected do you see FT232RL USB UART under USB? If you open a Terminal and do:
ls /dev/tty.*
What do you see?
I've tried the latest FTDI drivers, version 2.2.7 and have the same results.
I'm running on an Intel MacBook Pro w/ 2GB memory, 120GB disk and OS X 10.4.10.
System profiler shows:
FT232R USB UART:
Version: 6.00
Bus Power (mA): 500
Speed: Up to 12 Mb/sec
Manufacturer: FTDI
Product ID: 0x6001
Serial Number: A4001tot
Vendor ID: 0x0403
And /dev/tty.* shows:
/dev/tty.Bluetooth-Modem /dev/tty.Bluetooth-PDA-Sync /dev/tty.Peter-1 /dev/tty.usbserial-A4001tot
As you can see, there's now a tty.usbserial entry under /dev/. This wasn't there last night when I was trying to get the communications working. I'm a bit confused.
But I did just upload the Blink example sketch and its running on the board now. Wahoo!
  • Peter
