Arduino EDB Library getting SQLCipher when trying to open database on PC
I'm trying to use the EDB Library for my Arduino MEGA 2560 for storing data like temperature etc. in a sqlite databse.
Now, when I try to open the created or modified database via a sqlite browser, I'm always asked to type a SQLCipher password in, even when I didn't set one.
Does anyone know a fix?
#include "Arduino.h"
#include <EDB.h>
#include <SD.h>
File dbFile;
#define TABLE_SIZE 512
#define RECORDS_TO_CREATE 10
struct LogEvent {
  int id;
  int temperature;
logEvent;
void writer(unsigned long address, byte data)
  dbFile.seek(address);
  dbFile.write(data);
  dbFile.flush();
byte reader(unsigned long address)
  return dbFile.read();
EDB db(&writer, &reader);
void printError(EDB_Status err)
    Serial.print("ERROR: ");
    switch (err)
        case EDB_OUT_OF_RANGE:
            Serial.println("Recno out of range");
        case EDB_TABLE_FULL:
            Serial.println("Table full");
        case EDB_OK:
        default:
            Serial.println("OK");
void insertOneRecord(int recno)
    Serial.print("Inserting record at recno: ");
    Serial.print(recno);
    Serial.print("... ");
    logEvent.id = recno;
    logEvent.temperature = random(1, 125);
    EDB_Status result = db.insertRec(recno, EDB_REC logEvent);
    if (result != EDB_OK) printError(result);
    Serial.println("DONE");
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin()) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  Serial.println("Opening example.db ...");
  dbFile = SD.open("data.db", FILE_WRITE);
  insertOneRecord(3);
  /*db.create(0, TABLE_SIZE, sizeof(logEvent));
  Serial.print("Record Count: "); Serial.println(db.count());
  Serial.println("Creating Records...");
  int recno;
  for (recno = 1; recno <= RECORDS_TO_CREATE; recno++)
    logEvent.temperature = recno * 2;
    db.appendRec(EDB_REC logEvent);
  for (recno = 1; recno < RECORDS_TO_CREATE; recno++)
    db.readRec(recno, EDB_REC logEvent);
    Serial.print("ID: "); Serial.println(logEvent.id);
    Serial.print("Temp: "); Serial.println(logEvent.temperature);
