I recently got the ESP32-WROOM-32 board, I'm now trying to use the OTA protocol, but I have a problem: every time I upload a sketch, it gets stuck at the end of the uploading screen even though it uploaded it correctly, so I have to restart the Arduino IDE every time. I tried using the 1.8.19 Arduino IDE, and it works well, how can I fix the problem with the 2.0? I need it to store mi sketches in the cloud.
Hi @tizio7721 . This bug is being tracked by the Arduino IDE developers here:
opened 11:40AM - 26 Aug 22 UTC
type: imperfection
### Describe the problem
Originally reported by @per1234:
:bug: When uploa… ding to a board over a network port, the Arduino IDE UI continues to indicate an upload is in progress even after the process has completed successfully.
### To reproduce
#### Equipment
- [MKR1000](https://docs.arduino.cc/hardware/mkr-1000-wifi)
#### Steps
Follow the instructions to set up the board and do an OTA upload here: https://docs.arduino.cc/tutorials/mkr-1000-wifi/wifi-101-ota
The **Output** view shows that the process completed successfully:
```text
Connecting to board ... done
Uploading sketch ... done
Flashing sketch ... done
Sketch uploaded successfully
The board is running the sketch that was uploaded.
Yet the IDE UI remains permanently in the uploading state:
- "Upload" button has the gold color
- "**Uploading...**" notification with progress bar
### Expected behavior
IDE recognizes completion of upload process.
### Arduino IDE version
2.0.0-rc9.2-snapshot-9e2b73a
### Operating system
Linux
### Operating system version
Ubuntu 20.04
### Additional context
I also reproduced it using a slightly older version of the Arduino IDE 2.0.0-rc9.2-snapshot-0b33b51, which indicates it was not introduced by any of the commits after that.
While I was in the bisection stage of the investigation, the issue stopped happening even though it had occurred 100% consistently prior to that. So I was not able to bisect the introduction of the issue, check whether it also occurs with ESP32 boards, nor determine whether it also occurs when using Arduino CLI directly.
#### Other reports
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1256842794
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1264990273
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1272610016
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1276611306
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1287536050
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1298219359
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1321848204
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1334662078
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1343015278
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1345362515
- https://github.com/arduino/arduino-ide/issues/1356#issuecomment-1345374464
- https://github.com/arduino/arduino-ide/issues/1871
- https://github.com/arduino/arduino-ide/issues/1770
- https://github.com/arduino/arduino-ide/issues/1641
- https://github.com/arduino/arduino-ide/issues/1510
- https://github.com/arduino/arduino-ide/issues/1864
- https://github.com/esp8266/Arduino/issues/8684
- https://forum.arduino.cc/t/when-uploading-over-the-network-uploading-progress-window-does-not-go-away/1023158
- https://forum.arduino.cc/t/upload-stall-on-ota/1035843/1
- https://forum.arduino.cc/t/upload-stall-on-ota/1035843/3
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/1
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/5
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/6
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/7
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/8
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/9
- https://forum.arduino.cc/t/ota-upload-doesnt-stop/1037126/10
- https://forum.arduino.cc/t/bsdthread-register-error-when-try-to-use-adruinoota-update/1090730/10
- https://forum.arduino.cc/t/ota-outputs-not-displaying-anything-on-serial-monitor/1093690
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://github.com/arduino/arduino-ide#nightly-builds)
- [X] My report contains all necessary details
If you have a GitHub account, you can subscribe to that issue to get notifications of any new developments related to this subject.
The workaround to restore Arduino IDE to a functional state after it gets stuck in the upload:
Select File > Quit from the Arduino IDE menus.
Restart Arduino IDE.
system
Closed
August 28, 2023, 11:07am
3
