Arduino nano error
this error
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x54
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x50
Failed uploading: uploading error: exit status 1
whyy i need help
Please enable verbose output during upload and disable verbose output during compilation under file/preferences, perform an upload and post the results here (using code tags as described in https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966#use-code-tags).
Did it work in the past? If yes, what was the last project that you were working on when it started failing?
If it never worked,
  1. There are three options under tools/processor; try all three of them.
  2. Is you Nano an original or a clone? Can you provide a link to what you bought?
    A clear picture that will allow us to identify the chip on the top (should say ATmega328P) and one of the chip on the bottom (either FT... or CH34...) will also help.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x54
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x04
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x10
this check.
avrdude: stk500_disable(): unknown response=0x04
I doubt that was all output. And it's not presented using code tags.
This is the typical output similar to yours
"C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v  -patmega328p -carduino "-PCOM9" -b115200 -D "-Uflash:w:C:\Users\bugge\AppData\Local\Temp\arduino\sketches\06D651FFFC8F647572CAB3007BF75933/sketch_nov5a.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6f
avrdude done.  Thank you.
And please answer the questions in my previous post.
