Arduino Nano Every ModBus RFM69HCW communication
Hello everybody
I would like to let two Adriano Nano Every communicate with each other by radio. For this I have two RFM69HCW modules.
I connected both modules as follows:
Nano Every ---- RFm69HCW
2 DI00
10 NSS
11 MOSI
12 MISO
13 SCK
3.3V 3.3V
GND GND
I use the following library GitHub - LowPowerLab/RFM69: RFM69 library for RFM69W, RFM69HW, RFM69CW, RFM69HCW (semtech SX1231, SX1231H)
I can not communicate these two modules with each other. Does anyone have an idea why this could be?
thank you in advance
// RFM69HCW Example Sketch
// Send serial input characters from one RFM69 node to another
// Based on RFM69 library sample code by Felix Rusu
// http://LowPowerLab.com/contact
// Modified for RFM69HCW by Mike Grusin, 4/16
// This sketch will show you the basics of using an
// RFM69HCW radio module. SparkFun's part numbers are:
// 915MHz: https://www.sparkfun.com/products/12775
// 434MHz: https://www.sparkfun.com/products/12823
// See the hook-up guide for wiring instructions:
// https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide
// Uses the RFM69 library by Felix Rusu, LowPowerLab.com
// Original library: https://www.github.com/lowpowerlab/rfm69
// SparkFun repository: https://github.com/sparkfun/RFM69HCW_Breakout
// Include the RFM69 and SPI libraries:
#include <RFM69.h>
#include <SPI.h>
// Addresses for this node. CHANGE THESE FOR EACH NODE!
#define NETWORKID     0   // Must be the same for all nodes
#define MYNODEID      1   // My node ID
#define TONODEID      2   // Destination node ID
// RFM69 frequency, uncomment the frequency of your module:
#define FREQUENCY   RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
// AES encryption (or not):
#define ENCRYPT       true // Set to "true" to use encryption
#define ENCRYPTKEY    "TOPSECRETPASSWRD" // Use the same 16-byte key on all nodes
// Use ACKnowledge when sending messages (or not):
#define USEACK        true // Request ACKs or not
// Packet sent/received indicator LED (optional):
#define LED           9 // LED positive pin
#define GND           8 // LED ground pin
// Create a library object for our RFM69HCW module:
RFM69 radio;
  // Open a serial port so we can send keystrokes to the module:
  Serial.print("Node ");
  Serial.print(MYNODEID,DEC);
  Serial.println(" ready");
  // Set up the indicator LED (optional):
  pinMode(LED,OUTPUT);
  digitalWrite(LED,LOW);
  pinMode(GND,OUTPUT);
  digitalWrite(GND,LOW);
  // Initialize the RFM69HCW:
  // radio.setCS(10);  //uncomment this if using Pro Micro
  radio.initialize(FREQUENCY, MYNODEID, NETWORKID);
  radio.setHighPower(); // Always use this for RFM69HCW
  // Turn on encryption if desired:
  if (ENCRYPT)
    radio.encrypt(ENCRYPTKEY);
  // Set up a "buffer" for characters that we'll send:
  static char sendbuffer[62];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("sending to node ");
      Serial.print(TONODEID, DEC);
      Serial.print(", message [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      // There are two ways to send packets. If you want
      // acknowledgements, use sendWithRetry():
      if (USEACK)
        if (radio.sendWithRetry(TONODEID, sendbuffer, sendlength))
          Serial.println("ACK received!");
          Serial.println("no ACK received");
      // If you don't need acknowledgements, just use send():
      else // don't use ACK
        radio.send(TONODEID, sendbuffer, sendlength);
      sendlength = 0; // reset the packet
      Blink(LED,10);
  // RECEIVING
  // In this section, we'll check with the RFM69HCW to see
  // if it has received any packets:
  if (radio.receiveDone()) // Got one!
    // Print out the information:
    Serial.print("received from node ");
    Serial.print(radio.SENDERID, DEC);
    // The actual message is contained in the DATA array,
    // and is DATALEN bytes in size:
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    // RSSI is the "Receive Signal Strength Indicator",
    // smaller numbers mean higher power.
    Serial.print("], RSSI ");
    Serial.println(radio.RSSI);
    // Send an ACK if requested.
    // (You don't need this code if you're not using ACKs.)
    if (radio.ACKRequested())
      radio.sendACK();
      Serial.println("ACK sent");
    Blink(LED,10);
void Blink(byte PIN, int DELAY_MS)
// Blink an LED for a given number of ms
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
Sketch receiver
#include <RFM69.h>
#include <SPI.h>
#define MYNODEID      2   // My node ID
#define TONODEID      1   // Destination node ID
RFM69 radio;
  if (ENCRYPT)
  // SENDING
      sendlength++;
      // Send the packet!
      if (USEACK)
      Blink(LED,10);
  // RECEIVING
      radio.sendACK();
    Blink(LED,10);
  delay(DELAY_MS);
