I have a problem where none of my Arduino nano boards want to communicate to UART devices. When it is powered externally, I wrote a simple program to demonstrate my problem.
this code works perfectly using a UNO or a mega board. where when it is connected to a standalone power supply the TX pin just constantly spits out the data I However when I upload this exact same code to a arduino NANO it refuses to send anything when it is connected to a power supply. The NANO works perfectly when it is connected to a PC with a USB cable. It cannot be a bad connection since I've checked the output with a scope I tested this with a genuine NANO and a NANO every board, both had the same behaivior. What could be the issue?
no, but its not exactly the issue. when I run the code on an UNO board, I scope the TX line + ground it just sends the data, there is no handshake between whatever I connect it to. It just sends it. On the NANO there is nothing, no data
Please heed the advice. Serial requires three wires between two devices. TX, RX, and GND. Always.
If they're sharing a power source, of course, then GND is GND. But for two different devices with separate power supplies, you must connect the grounds.
obviously yes, tested it with my device, shared ground, TX and RX everything works perfectly. The problem just was that the arduino was not sending anything
It cannot be a bad connection since I've checked the output with a scope I tested this with a genuine NANOand a NANO every board, both had the same behavior.
I have no idea what the problem is with your Nanos, the ones I have have no problems sending data. I just connect Rx, Tx and GND.
I can't add anything else to the matter.
Hi, I have exactly the same issue but the solution about "using Serial1" is quite strange : since when does a nano have a serial1? I tried anyway to use Serial1 with my NANO but obviously I got a "Compilation error: 'Serial1' was not declared in this scope".
So I was unable to send data on RX pin without a connect PC on USB port. I will try a softserial but I don't like to do that without understanding this issue.
Serial1 was specifically for a Nano Every, where the Rx/Tx pins are a separate hardware serial port from the Serial used for the USB-to-serial connection to the computer. A classic Nano that uses an atmega328 only has a single hardware serial port, so there is no Serial1.
