Hi all,
I have done myself the circuit below in order to gauge the energy consumption in my house and gladly it worked fine, but a question concerning its operation has come up, and i have been digging through the internet and haven't found a clear answer for this yet.
I was wondering if someone could explain to me why it's necessary to have a VRef of 5V?
Is this voltage value supplied by the arduino itself or it also comes from the sct reading?
A current transformer measuring AC outputs positive and negative voltages. An Arduino pin can only work with positive voltages (0-5volt for a 5volt-logic Arduino). Lifting 'ground' of the current transformer to 2.5volt ensures that the pin only sees positive voltages. The signal now swings around this mid-voltage bias point, which can be removed with code.
Leo..
The VRef required depends on the value of the burden resistor (33Ω here),
the SCT013 has a 2000 : 1 ratio so 100 Amps in = 0.05A out. 0.05 * 33 = 1.65 V + (1/2 supply Volts) = 4.15V. So you need a VRef greater than that.
Which MCU board are you using?
Thank you very much, guys!
Only one question that remains is, what is the capacitor used for?
The way i see it, just the divider resistors would work to offset the voltage level.
A capacitor smooths out rapid voltage changes (of the 5volt supply).
That said, it's sort off unwanted with a ratiometric A/D. You want mid-voltage to follow Aref changes closely. I would probably have used 100n instead of 100uF. But someone drew that a long time ago, and it's never going to be changed/deleted from the internet.
Leo..
