Arduino2.1.0 /teensyduino 1.58 problem
Hello,
this is a reposting from a discussion I started at Teensyduino 1.58 Released - Page 3
summing up:
I encounter a problem on a win10 laptop to get a teensy++2 recognized:
(Note that I also have on my laptop an older install (still operational) of Arduino IDE 1.8.13, at C:\Program Files (x86)\Arduino )
When I launch Arduino 2.2.0, is asks for the com port; I then plug a teensy++2 . It is seen as com3 on the Arduino IDE.
But on the "board manager", the keyword "teensy" gives no result:
-> I am unable to get the board recognized.
I re-checked the "preference" in the Arduino IDE; the "additional board manager" link is there: https://www.pjrc.com/teensy/package_teensy_index.json
I tried to un-install Arduino IDE 2; then reinstall.
Same problem encountered: no teensy boards availlable in the "board" section. (even after restarting the IDE)
error messages (copied from Arduino IDE pop-up windows):
Platform arduino:avr@1.8.6 already installed
Downloading Stepper@1.1.3
Stepper@1.1.3
Failed to install library: Arduino_BuiltIn:1.0.0.
Error: 13 INTERNAL: Can't download library: Get "https://downloads.arduino.cc/libraries/github.com/arduino-libraries/Stepper-1.1.3.zip?query=depends": Forbidden
Could not install Arduino_BuiltIn library: Error: 13 INTERNAL: Can't download library: Get "https://downloads.arduino.cc/libraries/github.com/arduino-libraries/Ethernet-2.0.2.zip?query=depends": Forbidden
Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": Forbidden Get "https://downloads.arduino.cc/packages/package_index.tar.bz2": Forbidden: https://downloads.arduino.cc/package..._index.tar.bz2 Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": Forbidden: https://downloads.arduino.cc/librari..._index.tar.bz2
notes:
All the tests I did (described previously) were done as "administrator" on my laptop.
I checked the location for the install directory of the Arduino 2; it is located at C:\Program Files\Arduino IDE
I found also an empty 'Arduino IDE' directory in C:\Users\Administrateur\AppData\Local\Programs
I just tried deleted that empty directory, but no change resulted in the behaviour of Arduino IDE upon launching it.
I also tried to launch "powerShell" (from within C:\Program Files\Arduino IDE) before starting the Arduino IDE (typing ".\Arduino IDE" (including the double quotes). No messages appears on PowerShell upon launching Arduino IDE.
Hi @Fx78
You are definitely on the right track, but you must prefix the command with a & character. I'll provide the complete instructions for obtaining the logs from starting Arduino IDE from the PowerShell terminal:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    ⓘ The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  5. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting and for it to show those downloading errors.
  9. Switch back to the PowerShell window.
  10. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  11. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  12. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  13. Open a forum reply here by clicking the Reply button.
  14. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  15. Press Ctrl+V.
    This will paste the output into the code block.
  16. Move the cursor outside of the code block markup before you add any additional text to your reply.
  17. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hello, here are the messages obtained from PowerShell:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.0
Starting backend process. PID: 12560
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Administrateur/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-05-15T08:53:07.233Z root INFO Backend Object.initialize: 4.8 ms [Finished 1.743 s after backend start]
2023-05-15T08:53:07.234Z root INFO Backend Object.configure: 3.8 ms [Finished 1.743 s after backend start]
2023-05-15T08:53:07.234Z root INFO Backend MessagingContribution.onStart: 1.8 ms [Finished 1.743 s after backend start]
2023-05-15T08:53:07.235Z root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 1.788 s after backend start]
2023-05-15T08:53:07.236Z root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 1.788 s after backend start]
2023-05-15T08:53:07.237Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.2 ms [Finished 1.789 s after backend start]
2023-05-15T08:53:07.238Z root INFO Backend PluginLocalizationBackendContribution.initialize: 45.5 ms [Finished 1.789 s after backend start]
2023-05-15T08:53:07.238Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.3 ms [Finished 1.789 s after backend start]
2023-05-15T08:53:07.239Z root INFO Backend ElectronTokenBackendContribution.configure: 1.1 ms [Finished 1.790 s after backend start]
2023-05-15T08:53:07.239Z config INFO >>> Initializing CLI configuration...
2023-05-15T08:53:07.240Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 1.790 s after backend start]
2023-05-15T08:53:07.240Z root INFO Backend ConfigServiceImpl.onStart: 1.1 ms [Finished 1.791 s after backend start]
2023-05-15T08:53:07.241Z config INFO Loading CLI configuration from c:\Users\Administrateur\.arduinoIDE\arduino-cli.yaml...
2023-05-15T08:53:07.242Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.5 ms [Finished 1.792 s after backend start]
2023-05-15T08:53:07.242Z root INFO Backend ArduinoDaemonImpl.onStart: 1.2 ms [Finished 1.793 s after backend start]
2023-05-15T08:53:07.244Z root INFO Backend NodeFileUploadService.configure: 2.3 ms [Finished 1.793 s after backend start]
2023-05-15T08:53:07.244Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-05-15T08:53:07.244Z discovery-log INFO start
2023-05-15T08:53:07.244Z discovery-log INFO start new deferred
2023-05-15T08:53:07.244Z root INFO Backend HostedPluginLocalizationService.initialize: 0.6 ms [Finished 1.795 s after backend start]
2023-05-15T08:53:07.244Z root INFO Backend BoardDiscovery.onStart: 1.3 ms [Finished 1.795 s after backend start]
2023-05-15T08:53:07.245Z root INFO Backend FileDownloadEndpoint.configure: 1.1 ms [Finished 1.796 s after backend start]
2023-05-15T08:53:07.245Z root INFO Backend AuthenticationServiceImpl.onStart: 0.5 ms [Finished 1.797 s after backend start]
2023-05-15T08:53:07.245Z root INFO Backend PluginApiContribution.configure: 0.5 ms [Finished 1.797 s after backend start]
2023-05-15T08:53:07.248Z root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.800 s after backend start]
2023-05-15T08:53:07.248Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.800 s after backend start]
2023-05-15T08:53:07.248Z root INFO Backend PlotterBackendContribution.configure: 1.3 ms [Finished 1.803 s after backend start]
2023-05-15T08:53:07.252Z root INFO Theia app listening on http://localhost:64337.
2023-05-15T08:53:07.252Z root INFO Finished starting backend application: 7.7 ms [Finished 1.807 s after backend start]
2023-05-15T08:53:07.260Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Administrateur/.arduinoIDE/plugins does not exist.
2023-05-15T08:53:07.263Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Administrateur/.arduinoIDE/extensions does not exist.
2023-05-15T08:53:07.268Z root WARN The local plugin referenced by local-dir:C:\Users\Administrateur\.arduinoIDE\plugins does not exist.
2023-05-15T08:53:07.311Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.311Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-05-15T08:53:07.315Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.315Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-05-15T08:53:07.316Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-05-15T08:53:07.316Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.316Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-05-15T08:53:07.317Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.317Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-05-15T08:53:07.317Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-05-15T08:53:07.318Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.318Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-05-15T08:53:07.319Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.320Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-05-15T08:53:07.320Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.326Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-05-15T08:53:07.326Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.327Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-05-15T08:53:07.327Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.328Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-05-15T08:53:07.329Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.329Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-05-15T08:53:07.333Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.334Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-05-15T08:53:07.343Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.343Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-05-15T08:53:07.344Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-05-15T08:53:07.344Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.344Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-05-15T08:53:07.345Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.345Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-05-15T08:53:07.347Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-05-15T08:53:07.350Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.364Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-05-15T08:53:07.365Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.365Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-05-15T08:53:07.366Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-05-15T08:53:07.367Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-05-15T08:53:07.394Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://www.pjrc.com/teensy/package_teensy_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Administrateur\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\Administrateur\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"network":{"proxy":"http://https/","user_agent_ext":"daemon"},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-05-15T08:53:07.394Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-05-15T08:53:07.410Z config INFO Loaded the CLI configuration.
2023-05-15T08:53:07.458Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Administrateur/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Administrateur/Documents/Arduino","additionalUrls":["https://www.pjrc.com/teensy/package_teensy_index.json"],"network":{"protocol":"http","hostname":"https","password":"","username":"","port":""},"locale":"en"}
2023-05-15T08:53:07.458Z config INFO Validating the CLI configuration...
2023-05-15T08:53:07.460Z config INFO The CLI config is valid.
2023-05-15T08:53:07.467Z config INFO <<< Initialized the CLI configuration.
2023-05-15T08:53:07.502Z root INFO Resolve plugins list: 259.3 ms [Finished 2.055 s after backend start]
2023-05-15T08:53:07.518Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 16.1 ms [Finished 2.073 s after backend start]
2023-05-15T08:53:07.521Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.8 ms [Finished 2.076 s after backend start]
2023-05-15T08:53:07.545Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 24.2 ms [Finished 2.100 s after backend start]
2023-05-15T08:53:07.551Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 6.1 ms [Finished 2.107 s after backend start]
2023-05-15T08:53:07.555Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 3.6 ms [Finished 2.110 s after backend start]
2023-05-15T08:53:07.675Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 119.8 ms [Finished 2.230 s after backend start]
2023-05-15T08:53:07.724Z daemon INFO INFO[0000] Using config file: c:\Users\Administrateur\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:64338
{"IP":"127.0.0.1","Port":"64338"}
2023-05-15T08:53:07.728Z daemon INFO Daemon is running.
2023-05-15T08:53:07.945Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 269.7 ms [Finished 2.500 s after backend start]
2023-05-15T08:53:08.142Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 197.2 ms [Finished 2.697 s after backend start]
2023-05-15T08:53:08.142Z daemon INFO INFO[0000] Loading hardware from: c:\Users\Administrateur\AppData\Local\Arduino15\packages
INFO[0000] Loading package arduino from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Checking signature                            error="opening signature file: open C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: Le fichier sp├®cifi├® est introuvable." index="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0000] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loading package esp32 from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\hardware
INFO[0000] Loaded platform                               platform="esp32:esp32@1.0.4"
INFO[0000] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loaded tool                                   tool="esp32:esptool_py@2.6.1"
INFO[0000] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@1.22.0-80-g6c4433a-5.2.0"
INFO[0000] Checking signature                            index="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
INFO[0000] Loading libraries index file                  index="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\library_index.json"
2023-05-15T08:53:08.155Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file c:\Users\Administrateur\AppData\Local\Arduino15\package_teensy_index.json: open c:\Users\Administrateur\AppData\Local\Arduino15\package_teensy_index.json: Le fichier sp├®cifi├® est introuvable.
2023-05-15T08:53:08.305Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 162.9 ms [Finished 2.860 s after backend start]
2023-05-15T08:53:08.391Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 85.8 ms [Finished 2.946 s after backend start]
2023-05-15T08:53:08.391Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="c:\\Users\\Administrateur\\Documents\\Arduino\\libraries" location=user
2023-05-15T08:53:08.464Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 73.6 ms [Finished 3.020 s after backend start]
2023-05-15T08:53:08.552Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 87.7 ms [Finished 3.108 s after backend start]
2023-05-15T08:53:08.638Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 85.2 ms [Finished 3.193 s after backend start]
2023-05-15T08:53:08.713Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 75.8 ms [Finished 3.269 s after backend start]
2023-05-15T08:53:08.743Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 29.6 ms [Finished 3.299 s after backend start]
2023-05-15T08:53:08.825Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 81.9 ms [Finished 3.381 s after backend start]
2023-05-15T08:53:08.906Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 80.9 ms [Finished 3.461 s after backend start]
2023-05-15T08:53:08.909Z discovery-log INFO start request start watch
2023-05-15T08:53:08.909Z discovery-log INFO start requested start watch
2023-05-15T08:53:08.910Z discovery-log INFO start resolved watching
2023-05-15T08:53:08.998Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 91.7 ms [Finished 3.553 s after backend start]
2023-05-15T08:53:08.998Z daemon INFO INFO[0001] starting discovery builtin:serial-discovery process
INFO[0001] starting discovery builtin:mdns-discovery process
INFO[0001] started discovery builtin:serial-discovery process
INFO[0001] started discovery builtin:mdns-discovery process
INFO[0001] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
INFO[0001] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:serial-discovery
INFO[0001] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
INFO[0001] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
INFO[0001] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0001] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0001] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0001] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-05-15T08:53:09.071Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 73.7 ms [Finished 3.627 s after backend start]
2023-05-15T08:53:09.119Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 47.3 ms [Finished 3.674 s after backend start]
2023-05-15T08:53:09.178Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 58.8 ms [Finished 3.733 s after backend start]
2023-05-15T08:53:09.178Z root INFO Deploy plugins list: 259.3 ms [Finished 3.733 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-05-15T08:53:10.220Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 377.7 ms [Finished 2.798 s after frontend start]
2023-05-15T08:53:10.429Z root INFO Start frontend contributions: 662.4 ms [Finished 3.001 s after frontend start]
2023-05-15T08:53:10.430Z root INFO Changed application state from 'init' to 'started_contributions'.
2023-05-15T08:53:10.459Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2023-05-15T08:53:10.463Z root INFO >>> Restoring the layout state...
2023-05-15T08:53:10.470Z root INFO <<< Nothing to restore.
2023-05-15T08:53:10.528Z root INFO Initialize the workbench layout: 60.6 ms [Finished 3.132 s after frontend start]
2023-05-15T08:53:10.564Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2023-05-15T08:53:10.609Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a] Waiting for backend deployment: 223.9 ms [Finished 3.219 s after frontend start]
2023-05-15T08:53:11.662Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684) starting instance
2023-05-15T08:53:12.002Z root INFO Frontend application start: 1825.4 ms [Finished 6.558 s after backend start]
Checking for update
2023-05-15T08:53:12.052Z root INFO Replace loading indicator with ready workbench UI (animation): 1062.8 ms [Finished 4.203 s after frontend start]
2023-05-15T08:53:12.052Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2023-05-15T08:53:12.056Z root WARN Linked preference "workbench.colorCustomizations" not found. Source: "editor.bracketPairColorization.enabled"
2023-05-15T08:53:12.421Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.421Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.424Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.425Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.432Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.437Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.444Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.445Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.451Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.453Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.456Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.456Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.457Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.457Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.458Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.458Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.458Z sketches-service WARN Mismatching sketch file <A1_Info1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.458Z sketches-service WARN Mismatching sketch file <A6_Loop1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.459Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.459Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.459Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.470Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.471Z sketches-service WARN Mismatching sketch file <A5_SetUp1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.473Z sketches-service WARN Mismatching sketch file <BLE_uart1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.474Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.475Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.477Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.478Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.484Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.490Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.491Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.498Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.499Z sketches-service WARN Mismatching sketch file <StepperDemoAVR_FH1.ino> and sketch folder name <FastAccelStepper>. Skipping
2023-05-15T08:53:12.501Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.502Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.504Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.504Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.505Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.505Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.507Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.516Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.516Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.517Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.518Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.518Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.518Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.519Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.519Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.519Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.520Z sketches-service WARN Mismatching sketch file <A2_Include1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.520Z sketches-service WARN Mismatching sketch file <A3_Glob_Va1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.520Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:12.521Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:12.521Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:12.521Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:12.522Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.522Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.522Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.523Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.523Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.524Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.524Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.524Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.530Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.531Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.534Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.535Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.537Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.538Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.539Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.542Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.542Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.543Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.543Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.543Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.544Z sketches-service WARN Mismatching sketch file <A4_FastStepper1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:12.544Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.544Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:12.545Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:12.546Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:12.546Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:12.546Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:12.546Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:12.547Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:12.547Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
Update for version 2.1.0 is not available (latest version: 2.1.0, downgrade is allowed).
2023-05-15T08:53:12.994Z root ERROR ---- !!!SLOW!!! DURATION: search took 921.322 ms. Args: [{"type":"Updatable"}] ----
2023-05-15T08:53:13.083Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a] Sync of 21 plugins: 2442.9 ms [Finished 5.662 s after frontend start]
2023-05-15T08:53:13.086Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][marus25.cortex-debug]: Loaded contributions.
2023-05-15T08:53:13.086Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][arduino.vscode-arduino-tools]: Loaded contributions.
2023-05-15T08:53:13.091Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.cpp]: Loaded contributions.
2023-05-15T08:53:13.099Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.json]: Loaded contributions.
2023-05-15T08:53:13.099Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.json-language-features]: Loaded contributions.
2023-05-15T08:53:13.101Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-bg]: Loaded contributions.
2023-05-15T08:53:13.107Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
2023-05-15T08:53:13.109Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
2023-05-15T08:53:13.109Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
2023-05-15T08:53:13.113Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
2023-05-15T08:53:13.113Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-hu]: Loaded contributions.
2023-05-15T08:53:13.114Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
2023-05-15T08:53:13.114Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
2023-05-15T08:53:13.114Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ko]: Loaded contributions.
2023-05-15T08:53:13.115Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
2023-05-15T08:53:13.115Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-pl]: Loaded contributions.
2023-05-15T08:53:13.115Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
2023-05-15T08:53:13.116Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
2023-05-15T08:53:13.116Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
2023-05-15T08:53:13.116Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-uk]: Loaded contributions.
2023-05-15T08:53:13.117Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
2023-05-15T08:53:13.117Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a] Load contributions of 21 plugins: 32.2 ms [Finished 5.694 s after frontend start]
2023-05-15T08:53:13.368Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.368Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.370Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.370Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.373Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.373Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.374Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.374Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.375Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.375Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.375Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.376Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.376Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.377Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.377Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.380Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.389Z sketches-service WARN Mismatching sketch file <A1_Info1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.389Z sketches-service WARN Mismatching sketch file <A6_Loop1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.390Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.390Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.391Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.391Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.391Z sketches-service WARN Mismatching sketch file <A5_SetUp1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.391Z sketches-service WARN Mismatching sketch file <BLE_uart1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.392Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.392Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.392Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.393Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.393Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.393Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.394Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.397Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.405Z sketches-service WARN Mismatching sketch file <StepperDemoAVR_FH1.ino> and sketch folder name <FastAccelStepper>. Skipping
2023-05-15T08:53:13.406Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.407Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.407Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.408Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.408Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.408Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.408Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.409Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.409Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.409Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.410Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.410Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.410Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.411Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.412Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.414Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.422Z sketches-service WARN Mismatching sketch file <A2_Include1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.422Z sketches-service WARN Mismatching sketch file <A3_Glob_Va1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.423Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.424Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.424Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.425Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.425Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.425Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.425Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.426Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.426Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.427Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.427Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.429Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.431Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.439Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.440Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.440Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.441Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.441Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.441Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.442Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.442Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.443Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.446Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.447Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.454Z sketches-service WARN Mismatching sketch file <A4_FastStepper1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.455Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.457Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.458Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.460Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.462Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.467Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.473Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.474Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.476Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.481Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.487Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.488Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.489Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.490Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.501Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.503Z sketches-service WARN Mismatching sketch file <A3_Info.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.506Z sketches-service WARN Mismatching sketch file <A6_Loop.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.507Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.509Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.511Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.519Z sketches-service WARN Mismatching sketch file <A5_SetUp.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.520Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.523Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.523Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.526Z sketches-service WARN Mismatching sketch file <A1_Include.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.526Z sketches-service WARN Mismatching sketch file <A1_Info1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.527Z sketches-service WARN Mismatching sketch file <A6_Loop1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.528Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.530Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.531Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.538Z sketches-service WARN Mismatching sketch file <A3_Glob_Var.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.540Z sketches-service WARN Mismatching sketch file <A5_SetUp1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.540Z sketches-service WARN Mismatching sketch file <BLE_uart1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.540Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.541Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.541Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.541Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.542Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.542Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.542Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.542Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.543Z sketches-service WARN Mismatching sketch file <StepperDemoAVR_FH1.ino> and sketch folder name <FastAccelStepper>. Skipping
2023-05-15T08:53:13.544Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.544Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.548Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.556Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.0.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.556Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.557Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.558Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.558Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.558Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.559Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.559Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.559Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.560Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.560Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.561Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.561Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.562Z sketches-service WARN Mismatching sketch file <A2_Include1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.562Z sketches-service WARN Mismatching sketch file <A3_Glob_Va1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.562Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.0>. Skipping
2023-05-15T08:53:13.563Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.1>. Skipping
2023-05-15T08:53:13.563Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.2>. Skipping
2023-05-15T08:53:13.563Z sketches-service WARN Mismatching sketch file <A4_FastStepper.ino> and sketch folder name <FastStepper_BLE_FH1.3>. Skipping
2023-05-15T08:53:13.563Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.564Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.567Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.568Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.568Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.569Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.569Z sketches-service WARN Mismatching sketch file <A3_InfoFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.569Z sketches-service WARN Mismatching sketch file <A6_LoopFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.570Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.570Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.570Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.571Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.571Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.571Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.572Z sketches-service WARN Mismatching sketch file <A5_SetUpFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.572Z sketches-service WARN Mismatching sketch file <BLE_uartFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.572Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.573Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.573Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.573Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.573Z sketches-service WARN Mismatching sketch file <A4_FastStepper1.9.ino> and sketch folder name <FastStepper_BLE_FH1.9>. Skipping
2023-05-15T08:53:13.574Z sketches-service WARN Mismatching sketch file <A1_IncludeFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.574Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.4.ino> and sketch folder name <FastStepper_BLE_FH1.4>. Skipping
2023-05-15T08:53:13.574Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5>. Skipping
2023-05-15T08:53:13.575Z sketches-service WARN Mismatching sketch file <A3_Glob_VarFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.575Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.7>. Skipping
2023-05-15T08:53:13.575Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.8.ino> and sketch folder name <FastStepper_BLE_FH1.8>. Skipping
2023-05-15T08:53:13.576Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5b>. Skipping
2023-05-15T08:53:13.587Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.5.ino> and sketch folder name <FastStepper_BLE_FH1.5c>. Skipping
2023-05-15T08:53:13.587Z sketches-service WARN Mismatching sketch file <A4_FastStepperFH1.6.ino> and sketch folder name <FastStepper_BLE_FH1.6_OK>. Skipping
2023-05-15T08:53:13.594Z daemon INFO INFO[0006] Updating libraries index
INFO[0006] Updating index                                url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-05-15T08:53:13.604Z daemon INFO INFO[0006] Starting download                             url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-05-15T08:53:13.619Z root INFO core-client-provider [platform-index]
2023-05-15T08:53:13.627Z root INFO core-client-provider [library-index]
2023-05-15T08:53:13.634Z daemon INFO INFO[0006] Starting download                             url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2023-05-15T08:53:13.763Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2023-05-15T08:53:13.772Z root WARN a registered grammar configuration for 'cpp' language is overridden
2023-05-15T08:53:13.796Z root ERROR ---- !!!SLOW!!! DURATION: search took 163.429 ms. Args: [{"query":"Arduino_BuiltIn"}] ----
2023-05-15T08:53:14.056Z root INFO >>> Starting boards package installation...
2023-05-15T08:53:14.057Z discovery-log INFO stop
2023-05-15T08:53:14.066Z discovery-log INFO >>> Stopping boards watcher...
2023-05-15T08:53:14.068Z discovery-log INFO Canceling boards watcher...
2023-05-15T08:53:14.069Z discovery-log INFO disposing requesting cancel
2023-05-15T08:53:14.073Z discovery-log INFO disposing canceled
2023-05-15T08:53:14.084Z discovery-log INFO error received
2023-05-15T08:53:14.084Z discovery-log INFO cancel error received!
2023-05-15T08:53:14.084Z discovery-log INFO stop received event: either end or cancel
2023-05-15T08:53:14.091Z discovery-log INFO stop stopped
2023-05-15T08:53:14.092Z discovery-log INFO received end
2023-05-15T08:53:14.096Z daemon INFO INFO[0006] boards watcher stream closed
2023-05-15T08:53:14.102Z daemon INFO INFO[0006] Loading hardware from: c:\Users\Administrateur\AppData\Local\Arduino15\packages
2023-05-15T08:53:14.106Z daemon INFO INFO[0006] Loading package arduino from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\hardware
2023-05-15T08:53:14.122Z daemon INFO INFO[0006] Checking signature                            error="opening signature file: open C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: Le fichier sp├®cifi├® est introuvable." index="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json" signatureFile="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig"
2023-05-15T08:53:14.125Z daemon INFO INFO[0006] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
2023-05-15T08:53:14.138Z daemon INFO INFO[0006] Loaded platform                               platform="arduino:avr@1.8.6"
INFO[0006] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\tools
INFO[0006] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\arduino\tools
INFO[0006] Loaded tool                                   tool="arduino:arduinoOTA@1.3.0"
INFO[0006] Loaded tool                                   tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0006] Loaded tool                                   tool="arduino:avrdude@6.3.0-arduino17"
INFO[0006] Loading package builtin from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin
INFO[0006] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin\tools
INFO[0006] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\builtin\tools
INFO[0006] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0006] Loaded tool                                   tool="builtin:mdns-discovery@1.0.9"
INFO[0006] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
2023-05-15T08:53:14.142Z daemon INFO INFO[0006] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
2023-05-15T08:53:14.144Z daemon INFO INFO[0006] Loading package esp32 from: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\hardware
2023-05-15T08:53:14.167Z daemon INFO INFO[0006] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0006] Loaded platform                               platform="esp32:esp32@1.0.4"
2023-05-15T08:53:14.168Z daemon INFO INFO[0006] Checking existence of 'tools' path: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\tools
INFO[0006] Loading tools from dir: C:\Users\Administrateur\AppData\Local\Arduino15\packages\esp32\tools
2023-05-15T08:53:14.170Z daemon INFO INFO[0006] Loaded tool                                   tool="esp32:esptool_py@2.6.1"
2023-05-15T08:53:14.176Z daemon INFO INFO[0006] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0006] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@1.22.0-80-g6c4433a-5.2.0"
2023-05-15T08:53:14.248Z daemon INFO INFO[0006] Checking signature                            index="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-05-15T08:53:14.254Z daemon INFO INFO[0006] sending command QUIT to discovery builtin:serial-discovery
2023-05-15T08:53:14.258Z daemon INFO INFO[0006] from discovery builtin:serial-discovery received message type: quit, message: OK
INFO[0006] killing discovery builtin:serial-discovery process
2023-05-15T08:53:14.259Z daemon INFO INFO[0006] Discovery event channel closed builtin:serial-discovery. Exiting goroutine.
2023-05-15T08:53:14.284Z daemon INFO INFO[0006] Closed and removed discovery builtin:serial-discovery
INFO[0006] sending command QUIT to discovery builtin:mdns-discovery
2023-05-15T08:53:14.288Z daemon INFO INFO[0006] from discovery builtin:mdns-discovery received message type: quit, message: OK
2023-05-15T08:53:14.290Z daemon INFO INFO[0006] killing discovery builtin:mdns-discovery process
2023-05-15T08:53:14.292Z daemon INFO INFO[0006] Closed and removed discovery builtin:mdns-discovery
INFO[0006] starting discovery builtin:serial-discovery process
2023-05-15T08:53:14.300Z daemon INFO INFO[0006] Discovery event channel closed builtin:mdns-discovery. Exiting goroutine.
INFO[0006] started discovery builtin:serial-discovery process
INFO[0006] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:serial-discovery
2023-05-15T08:53:14.320Z daemon INFO INFO[0006] from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1
2023-05-15T08:53:14.321Z daemon INFO INFO[0006] sending command START_SYNC to discovery builtin:serial-discovery
INFO[0006] from discovery builtin:serial-discovery received message type: start_sync, message: OK
INFO[0006] starting discovery builtin:mdns-discovery process
2023-05-15T08:53:14.323Z daemon INFO INFO[0006] started discovery builtin:mdns-discovery process
INFO[0006] sending command HELLO 1 "arduino-cli 0.32.2" to discovery builtin:mdns-discovery
2023-05-15T08:53:14.340Z daemon INFO INFO[0006] from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1
2023-05-15T08:53:14.340Z daemon INFO INFO[0006] sending command START_SYNC to discovery builtin:mdns-discovery
INFO[0006] from discovery builtin:mdns-discovery received message type: start_sync, message: OK
2023-05-15T08:53:14.351Z daemon INFO INFO[0006] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2023-05-15T08:53:14.363Z daemon INFO INFO[0006] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.4\\libraries" location=platform
INFO[0006] Loading libraries index file                  index="c:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\library_index.json"
2023-05-15T08:53:14.565Z daemon INFO INFO[0007] Adding libraries dir                          dir="C:\\Users\\Administrateur\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-05-15T08:53:14.566Z daemon INFO INFO[0007] Adding libraries dir                          dir="c:\\Users\\Administrateur\\Documents\\Arduino\\libraries" location=user
2023-05-15T08:53:14.960Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): PluginManagerExtImpl/init()
2023-05-15T08:53:14.969Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:14.982Z root INFO [hosted-plugin: 2684] Debugger contribution has been registered: cortex-debug
2023-05-15T08:53:14.988Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-arduino-tools@0.0.2-beta.8 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:14.990Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:14.994Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:14.997Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.000Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(2684): initializing(vscode-language-pack-cs@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.000Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-de@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.006Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-es@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.008Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-fr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.011Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.017Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-it@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(2684): initializing(vscode-language-pack-ja@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.018Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-ko@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.020Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.022Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-pl@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.023Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-pt-BR@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.023Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-ru@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.026Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): initializing(vscode-language-pack-tr@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(2684): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(2684): initializing(vscode-language-pack-zh-hans@1.53.2 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
2023-05-15T08:53:15.105Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2023-05-15T08:53:15.179Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][marus25.cortex-debug]: Started plugin.
2023-05-15T08:53:15.188Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][arduino.vscode-arduino-tools]: Started plugin.
2023-05-15T08:53:15.188Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.cpp]: Started plugin.
2023-05-15T08:53:15.190Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.json]: Started plugin.
2023-05-15T08:53:15.194Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][vscode.json-language-features]: Started plugin.
2023-05-15T08:53:15.196Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-bg]: Started plugin.
2023-05-15T08:53:15.203Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-cs]: Started plugin.
2023-05-15T08:53:15.204Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-de]: Started plugin.
2023-05-15T08:53:15.209Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-es]: Started plugin.
2023-05-15T08:53:15.217Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-fr]: Started plugin.
2023-05-15T08:53:15.221Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-hu]: Started plugin.
2023-05-15T08:53:15.221Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-it]: Started plugin.
2023-05-15T08:53:15.227Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ja]: Started plugin.
2023-05-15T08:53:15.228Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ko]: Started plugin.
2023-05-15T08:53:15.230Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-nl]: Started plugin.
2023-05-15T08:53:15.239Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-pl]: Started plugin.
2023-05-15T08:53:15.240Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
2023-05-15T08:53:15.245Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-ru]: Started plugin.
2023-05-15T08:53:15.246Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-tr]: Started plugin.
2023-05-15T08:53:15.250Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-uk]: Started plugin.
2023-05-15T08:53:15.251Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
2023-05-15T08:53:15.273Z discovery-log INFO start
2023-05-15T08:53:15.273Z discovery-log INFO start new deferred
2023-05-15T08:53:15.274Z discovery-log INFO start request start watch
2023-05-15T08:53:15.283Z discovery-log INFO start requested start watch
2023-05-15T08:53:15.285Z discovery-log INFO start resolved watching
2023-05-15T08:53:15.294Z root INFO [hosted-plugin: 2684] PLUGIN_HOST(2684): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2023-05-15T08:53:15.355Z root INFO <<< Boards package installation done.
2023-05-15T08:53:15.368Z root INFO Boards package installed:
2023-05-15T08:53:15.369Z root INFO >>> Starting library package installation...
2023-05-15T08:53:15.370Z discovery-log INFO stop
2023-05-15T08:53:15.372Z discovery-log INFO >>> Stopping boards watcher...
2023-05-15T08:53:15.373Z discovery-log INFO Canceling boards watcher...
2023-05-15T08:53:15.386Z discovery-log INFO disposing requesting cancel
2023-05-15T08:53:15.390Z discovery-log INFO disposing canceled
2023-05-15T08:53:15.401Z discovery-log INFO error received
2023-05-15T08:53:15.402Z discovery-log INFO cancel error received!
2023-05-15T08:53:15.408Z discovery-log INFO stop received event: either end or cancel
2023-05-15T08:53:15.410Z discovery-log INFO stop stopped
2023-05-15T08:53:15.411Z discovery-log INFO received end
2023-05-15T08:53:15.428Z daemon INFO INFO[0007] boards watcher stream closed
2023-05-15T08:53:15.429Z root INFO [hosted-plugin: 2684] Debug configuration provider has been registered: cortex-debug, trigger: 1
GDB server console created
2023-05-15T08:53:15.455Z daemon INFO INFO[0007] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
INFO[0007] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0007] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.474Z root INFO [f8092476-f693-4c29-b234-956c0fad0c7a] Start of 21 plugins: 2357.4 ms [Finished 8.082 s after frontend start]
2023-05-15T08:53:15.560Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
INFO[0008] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.640Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.640Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.673Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.674Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.699Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.718Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.718Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.738Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.754Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.772Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.787Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.804Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.820Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.835Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.836Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.852Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.868Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.878Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.893Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.909Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.916Z root ERROR Failed to update platform, library indexes.
2023-05-15T08:53:15.918Z daemon INFO INFO[0008] Updating index                                url="https://www.pjrc.com/teensy/package_teensy_index.json"
INFO[0008] Starting download                             url="https://www.pjrc.com/teensy/package_teensy_index.json"
2023-05-15T08:53:15.921Z root INFO core-client-provider [platform-index]
2023-05-15T08:53:15.926Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.943Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.959Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.959Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:15.983Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:15.983Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-05-15T08:53:15.998Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.000Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.016Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.017Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.039Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.056Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.056Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.071Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.087Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.103Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.113Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.127Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.141Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.142Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.160Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.168Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.170Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.189Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.190Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.208Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.224Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:16.225Z daemon INFO INFO[0008] Required tool                                 tool="arduino:avrdude@6.3.0-arduino17"
2023-05-15T08:53:16.253Z daemon INFO INFO[0008] Required tool                                 tool="arduino:arduinoOTA@1.3.0"
2023-05-15T08:53:19.190Z daemon INFO INFO[0011] Starting download                             url="https://downloads.arduino.cc/libraries/github.com/arduino-libraries/Arduino_BuiltIn-1.0.0.zip?query=install-builtin"
2023-05-15T08:53:21.467Z discovery-log INFO start
2023-05-15T08:53:21.467Z discovery-log INFO start new deferred
2023-05-15T08:53:21.468Z root ERROR Request install failed with error: 13 INTERNAL: Can't download library: Get "https://downloads.arduino.cc/libraries/github.com/arduino-libraries/Arduino_BuiltIn-1.0.0.zip?query=install-builtin": Forbidden
2023-05-15T08:53:21.471Z discovery-log INFO start request start watch
2023-05-15T08:53:21.472Z discovery-log INFO start requested start watch
2023-05-15T08:53:21.472Z discovery-log INFO start resolved watching
Unfortunately the logs did not provide any more information about the cause of the failure.
Arduino IDE must download the package index file from the URL you added to your "Additional Boards Manager URLs" preference in order to populate the Boards Manager with the Teensy boards entry. But its attempts to download that file that are failing with a "Forbidden" HTTP status code.
Can you think of any reason why the IDE is not able to access the Internet? Is your computer's firewall software blocking it? When you started Arduino IDE the first time, Windows should have shown a dialog asking you whether you wanted to allow Arduino IDE to access the Internet.
Is there anything special about your network your computer is connected to the Internet through that might be interfering with the IDE's ability to access the Internet? For example, some workplace networks are configured to be very restrictive about Internet access.
I will check for eventual firewall software problem.
The laptop is at home, operated with a standard Internet access (i.e. without workplace network filtering)
I have also un-installed the IDE (that was installed "for all"), and then re-installed "for me". Upon this reinstall, no question was asked about internet access by the IDE. And the problem persists.
Is there a workaround via "manual" downloading the required packages (an a procedure to indicate to the IDE where to find the downloaded files) ?
Hello,
I checked the windows firewall: I granted access to internet for Arduino IDE and Auduino ide.exe (for both public and private access).
Java has a public access to internet
I suspended the internet monitoring activity of my anti-virus software (Nod32).
But I still have the same problem of 'forbidden' download for Arduino IDE.
"Can't download library: Get "https://downloads.arduino.cc/libraries/github.com/arduino-libraries/Arduino_BuiltIn-1.0.0.zip?query=install-builtin": Forbidden
So I am stuck (and I give-up trying for now)
I am also having this issue and wanted to bump the thread!
It might help to know what your issue actual issue is. Running Arduino 1.x? or 2.x? The instructions on how to install Teensy support is different depending on which one.
Paul has recently updated some of the tutorial pages on the PJRC website, that might hep
Teensyduino Tutorial #1: Software Setup for Teensy on Arduino IDE (pjrc.com)
Or is this an issue with virus detector? Which one.
If you have not already done so, you might want to ask about this on the Teensy forum: PJRC (Teensy) Forum
Good luck
Thanks for the reply! Running 2.1.1, so slightly newer than the thread title version.
I also posted at PJRC's forum and they recommended ctrl-shift-P to force "Arduino: Update Package Index"
After doing that, I was able to install the teensy in the board manager section of the IDE.
I am also having this issue… but on Mac, macOS 12.6.6. I will try an OS update to see if that changes anytime…
I installed Arduino IDE 2.2.x, added “ https://www.prjc.com/teensy/package_teensy_index.json” to Board Manager. It creeped along and after approx 20 minutes, timed out…
It will not complete the download, and if I try to restart the IDE, the startup screen just shows a pulsing logo.
I can at least try to help you recover the IDE to functionality. I'm going to ask you to run Arduino IDE from the command line, then post the output in a reply here.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Close all Arduino IDE windows if the IDE is already running.
  2. Open your Applications folder in Finder.
  3. Open the Utilities folder.
  4. Double-click on "Terminal".
  5. Type the following command in the Terminal window:
    "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
  6. Press Enter
  7. Wait until you are sure the IDE startup has gone into the hang state
    (as indicated by no additional output being printed to the Terminal window).
  8. Switch back to the Terminal window if the Arduino IDE window took the focus.
  9. Press ⌘+A.
    This will select all the text in the Terminal window.
  10. Press ⌘+C.
    This will copy the selected text to the clipboard.
  11. Open a forum reply here by clicking the Reply button.
  12. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the output is correctly formatted.
    Code tags icon on toolbar
  13. Press ⌘+V.
    This will paste the output into the code block.
  14. Move the cursor outside of the code block markup before you add any additional text to your reply.
  15. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
I am able to get the "pulsing" / "frozen ide" issue resolved, however, I am unable to install Teensy on the Arduino IDE for mac... I have two macs and they both are having the same issue... I would rather get this resolved than have to resort to pulling out a Window 10 PC to see if it will work there...
Following the instructions...
To install Teensy on the Arduino IDE, click File->Preferences. In "Additional boards manager URLs", enter this link: https://www.prjc.com/teensy/package_teensy_index.json
And after several minutes waiting...
Some indexes could not be updated.
Get "https://www.prjc.com/teensy/package_teensy_index.json": dial tcp 72.1.32.168:443:
connect: operation timed out: https://www.prjc.com/teensy/package_teensy_index.json
Anyone figured out how to get this to work...
OK, I figured it out, they posted the wrong link... https://www.prjc.com... instead of https://www.pjrc.com
Sorry!
I'm glad it is working now. Thanks for taking the time to post an update.
I'm interested to understand this issue so that I might be prepared to support other affected users. The problem is not clear to me. The two URLs you mention above are identical. Would you mind providing a more detailed explanation of the problem?
Where is the wrong link posted? Would be good to have it updated.
prjc versus pjrc (two letters transposed)
Yes, that is correct, transposed... they had prjc instead of pjrc...
Thanks for pointing that out. I should have noticed the difference.
However, where did you see this? If it is still that way, it would be good to update it, so others don't run into it.
I checked a few locations like:
Maybe the most likely suspect, as these pages were recently updated, but looks OK now.
Teensyduino: Download and Install Teensy support into the Arduino IDE (pjrc.com)
The Teensy 4.1 product page takes you back to the previous link.
Forum? The release page for 1.58 shows:
Beta 3 for 159 does not show link.
