Hy i have a problem with my atmega 1284 (got 2 of this chips)
I managed to hook one up and burn a bootloader on it, a sanguino 16mhz for 1284p.
For now all is working ok i am using the folowing pinnout for the sanguino :
// ATMEL ATMEGA644P / SANGUINO
// 0 INT0 (D 0) PB0 1| |40 PA0 (AI 0 / D31) 31
// 1 INT1 (D 1) PB1 2| |39 PA1 (AI 1 / D30) 30
// 2 INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29) 39
// 3 PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28) 28
// 4 PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27) 27
// 5 MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26) 26
// 6 MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25) 25
// 7 SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) 24
// RST 9| |32 AREF
// VCC 10| |31 GND
// GND 11| |30 AVCC
// XTAL2 12| |29 PC7 (D 23) 23
// XTAL1 13| |28 PC6 (D 22) 22
// 8 RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI 21
// 9 TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO 20
//10 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS 19
//11 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK 18
//12 PWM (D 12) PD4 18| |23 PC1 (D 17) SDA 17
//13 PWM (D 13) PD5 19| |22 PC0 (D 16) SCL 16
//14 PWM (D 14) PD6 20| |21 PD7 (D 15) PWM 15
had to wrap it into code to look good ![]()
It tooked me a wile to figure out the pins (number ones) but well i think i made it on the left side are the pin numbers wich works in arduino eg pin 0 is the pin pb0 , pin 14 is PD6 and pin 24 is PA7. (correct me if i am wrong)
all works ok except few of them :
18,19,20,21 (PC2 , PC3 , PC4 , PC5 ) can you please tell me can i use this pins as digital outputs or inputs? i am realy short on pins and this one do not work.
the blink code compiles but i do not get anything like the desired effect on pin 18, all i get is a faded led even if i connect to pin 19 or 20 or 21 with the same blink sketch on pin 18. ( i hooked up to power the other chip without bootloader and is dooing the same thing faded led without any sketch on it so it must be something hardware).
please tell me what does TCK , TMS ,TDO and TDI stands for ?
thanks and please bare with me and excuse my poor english.
