hi there i have a digispark ATTINY85
the one where it uses usb to upload and then reverts to no usb
i have loaded a set all pins to output (trying to lower current consumption)
for(int i=0; i <20;i++){
pinMode(i,OUTPUT);
and of course now i cant upload anything else
Mm, as far as I know setting the pins as output should not matter. That's because you need to re-insert it to the PC to program it. And initial they are not an output and the bootloader uses them. Only thing is, you might have confused the computer connected to it. Aka, try different USB port and/or reboot.
