ATTiny1616 UPDI Bootloader burns OK, Can't upload a sketch with the same settings
Burning the Bootloader works perfectly, and can be run multiple times without issue.
"C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\tools\python3\3.7.2-post1/python3" -u "C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/tools/prog.py" -t uart -u COM5 -b 57600 -d attiny1616 --fuses 0:0x00 1:0x00 2:0x02 5:0b11000100 6:0x04 7:0x00 8:0x02 -fC:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/bootloaders/hex/optiboot_txyz_all8sec.hex -a write -v
SerialUPDI
UPDI programming for Arduino using a serial adapter
Based on pymcuprog, with significant modifications
By Quentin Bolsee and Spence Konde
Version 1.2.3 - Jan 2022
Using serial port COM5 at 57600 baud.
Target: attiny1616
Set fuses: ['0:0x00', '1:0x00', '2:0x02', '5:0b11000100', '6:0x04', '7:0x00', '8:0x02']
Action: write
File: C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/bootloaders/hex/optiboot_txyz_all8sec.hex
pymcuprog.programmer - INFO - Setting up programming session for 'attiny1616'
pymcuprog.deviceinfo.deviceinfo - INFO - Looking for device attiny1616
pymcuprog.serialupdi.physical - INFO - Opening port 'COM5' at '57600' baud
pymcuprog.serialupdi.link - INFO - STCS 08 to 0x03
pymcuprog.serialupdi.link - INFO - STCS 06 to 0x02
pymcuprog.serialupdi.link - INFO - LDCS from 0x00
pymcuprog.serialupdi.link - WARNING - UPDI init failed: Can't read CS register.
pymcuprog.serialupdi.physical - INFO - Sending double break
pymcuprog.serialupdi.physical - INFO - Double-break sent. Retrying.
pymcuprog.serialupdi.link - INFO - UPDI init OK
pymcuprog.serialupdi.link - INFO - Setting UPDI clock to 4 MHz
pymcuprog.serialupdi.link - INFO - STCS 03 to 0x09
pymcuprog.serialupdi.physical - INFO - Switching to '57600' baud
pymcuprog.serialupdi.application - INFO - SIB: 'tinyAVR P:0D:0-3M2 (00.59B15.0)'
pymcuprog.serialupdi.application - INFO - Device family ID: 'tinyAVR'
pymcuprog.serialupdi.application - INFO - NVM interface: 'P:0'
pymcuprog.serialupdi.application - INFO - Debug interface: 'D:0'
pymcuprog.serialupdi.application - INFO - PDI oscillator: '3M2'
pymcuprog.serialupdi.application - INFO - Extra info: '(00.59B15.0)'
pymcuprog.serialupdi.application - INFO - Using 16-bit UPDI
pymcuprog.serialupdi.application - INFO - PDI revision = 0x02
pymcuprog.serialupdi.link - INFO - LDCS from 0x0B
pymcuprog.serialupdi.application - INFO - Entering NVM programming mode
pymcuprog.serialupdi.link - INFO - LDCS from 0x07
pymcuprog.serialupdi.application - INFO - Apply reset
pymcuprog.serialupdi.link - INFO - STCS 59 to 0x08
pymcuprog.serialupdi.application - INFO - Release reset
pymcuprog.serialupdi.link - INFO - STCS 00 to 0x08
pymcuprog.nvm - INFO - No specific initializer for this provider
Pinging device...
pymcuprog.programmer - INFO - Reading device ID...
pymcuprog.serialupdi.application - INFO - Device ID from pyupdi = '1E9421' rev 'A'
pymcuprog.nvm - INFO - Device ID: '1E9421'
pymcuprog.nvm - INFO - Device revision: 'A'
pymcuprog.nvm - INFO - Device serial number: 'b'51544a375420d1941913''
Ping response: 1E9421
Setting fuse 0x0=0x0
Writing literal values...
pymcuprog.programmer - INFO - Write...
pymcuprog.programmer - INFO - Writing 1 bytes of data to fuses...
pymcuprog.programmer - INFO - Write complete.
Verifying literal values...
pymcuprog.programmer - INFO - Reading 1 bytes from fuses...
pymcuprog.programmer - INFO - Verifying...
Action took 0.03s
Setting fuse 0x1=0x0
Action took 0.03s
Setting fuse 0x2=0x2
Action took 0.03s
Setting fuse 0x5=0xc4
Action took 0.03s
Setting fuse 0x6=0x4
Action took 0.04s
Setting fuse 0x7=0x0
Action took 0.03s
Setting fuse 0x8=0x2
Action took 0.04s
Finished writing fuses.
Chip/Bulk erase,
Memory type eeprom is conditionally erased (depending upon EESAVE fuse setting)
Memory type flash is always erased
Memory type lockbits is always erased
pymcuprog.programmer - INFO - Erase...
pymcuprog.serialupdi.nvm - INFO - Chip erase using NVM CTRL
Erased.
Action took 0.01s
Writing from hex file...
Writing flash...
pymcuprog.programmer - INFO - Writing 472 bytes of data to flash...
[====== ] 1/8
[============ ] 2/8
[================== ] 3/8
[========================= ] 4/8
[=============================== ] 5/8
[===================================== ] 6/8
[=========================================== ] 7/8
[==================================================] 8/8
Writing flash...
pymcuprog.programmer - INFO - Writing 2 bytes of data to flash...
Action took 0.26s
Verifying...
pymcuprog.programmer - INFO - Reading 472 bytes from flash...
pymcuprog.programmer - INFO - Reading 64 bytes from flash...
Verify successful. Data in flash matches data in specified hex-file
Action took 0.13s
pymcuprog.serialupdi.application - INFO - Leaving NVM programming mode
pymcuprog.serialupdi.link - INFO - STCS 0C to 0x03
pymcuprog.serialupdi.physical - INFO - Closing port 'COM5'
then when attempting to upload a sketch I get the following error:
Sketch uses 1148 bytes (7%) of program storage space. Maximum is 15872 bytes.
Global variables use 10 bytes (0%) of dynamic memory, leaving 2038 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Admin\AppData\Local\Arduino15\packages\DxCore\tools\avrdude\6.3.0-arduino17or18/bin/avrdude" "-CC:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/avrdude.conf" -v -V -pattiny1616 -carduino -D -PCOM5 -PCOM5 -b115200 "-Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino\sketches\70456BE6813F9AF0B376095BDE1A0210/Project.ino.hex:i"
avrdude: Version 6.3-20201216
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
I'm using the HV UPDI Friend connected to Pin 19 of the ATTiny1616, I've tried all the versions of the MegaTinyCore. I've even tried the command line to upload the project and manually changing the baud settings to all bauds down to 2400. I've seen diagrams that show a 10K resistor from VCC to the UPDI Pin, Caps' resistors in series, and all sorts of other things, but none of those work, however, I understand the UPDI friend doesn't need those, and as soon as I revert to directly connecting the UPDI friend to pin 19 I can burn the bootloader, but still not upload a sketch. 3 days now, any ideas from anybody would be much appreciated.
not same settings
you are correct, the pasted data isn't the same. but I have run the write at every standard baud rate down to 2400, with the same failure as the message shows.
"C:\Users\Admin\AppData\Local\Arduino15\packages\DxCore\tools\avrdude\6.3.0-arduino17or18/bin/avrdude" "-CC:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/avrdude.conf" -v -V -pattiny1616 -carduino -D -PCOM5 -PCOM5 -b57600 "-Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino\sketches\70456BE6813F9AF0B376095BDE1A0210/Project.ino.hex:i"
     Using Port                    : COM5
     Overriding Baud Rate          : 57600
execute this in command line:
"C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\tools\python3\3.7.2-post1/python3" -u "C:\Users\Admin\AppData\Local\Arduino15\packages\megaTinyCore\hardware\megaavr\2.6.10/tools/prog.py" -t uart -u COM5 -b 57600 -d attiny1616 --fuses 0:0x00 1:0x00 2:0x02 5:0b11000100 6:0x04 7:0x00 8:0x02 -fC:\Users\Admin\AppData\Local\Temp\arduino\sketches\70456BE6813F9AF0B376095BDE1A0210/Project.ino.hex -a write -v
it's funny you mentioned that, as I just tried that.
SerialUPDI
Target: attiny1616
Action: write
File: C:\Users\Admin\AppData\Local\Temp\arduino\sketches\70456BE6813F9AF0B376095BDE1A0210/Project.ino.hex
Pinging device...
Action took 0.04s
Action took 0.04s
Action took 0.05s
Action took 0.04s
Action took 0.05s
Action took 0.05s
Action took 0.04s
Chip/Bulk erase,
Erased.
Action took 0.03s
Writing flash...
pymcuprog.programmer - INFO - Writing 1148 bytes of data to flash...
[==================================================] 18/18
Action took 0.49s
Verifying...
pymcuprog.programmer - INFO - Reading 1148 bytes from flash...
[==================================================] 3/3
pymcuprog.programmer - ERROR - Verify failed: Verify mismatch starting at location 0x000200: 0x3D vs 0x00
Action took 0.27s
it comes back saying their is a mismatch in the read data from what was written, I do wonder why in the Arduino IDE application that it uses a diffarent method for burning the bootloader, to burning or uploading a sketch. but it still fails, although for a different reason
actually bootloader needed for upload plograms over UART.
if you write program over ISP, same way as bootloader is written, so you need no bootlader at all.
Thats handy to know, so the only issue now is why can it only read back 3/3 when it's written 18/18. I'm hoping it isn't the board design, as I designed the board myself. being new to the ATTiny series of chips I'm not entirely sure if you can program the chip in circuit with the other components installed, I can't see why that would be a problem as I've not used pin 19 for anything other than programming and is a straight connection without any other components attached to it. the other pins are simply used for inputs/outputs and some indicators LED's. I have got a breakout board coming soon which just has the chip onboard so will be able to do some further testing with that.
