I have no problem getting the a Dallas one wire temperature sensor working on a Uno and I've done several projects without any major issues.
But I'm struggling with the ATTiny84. I'm using 8Mhz and I've tried two different cores. Also have tried several different versions of both the Onewire and the Temperature library. I'm using the 84A-PU chip version (not the 20).
I've stripped the program down to the basics. The same exact code (just with a serial print command and pin changes) works fine on the Uno. On the ATTiny84 I have it blink an LED if the temperature goes above ambient (I warm the sensor with my hands), still doesn't work. I also tried using the Morse code library to blink the LED. I'm about ready to give up, it blinks the correct code for a missing sensor, so at least I know my program is running. I'm using IDE 1.6.9. I've done enough to know that it seeing the sensor. Yes, I am on the correct pins, the two cores I tried using are different as far as the pin arrangements but I've tested all the outputs to make sure they work.
It is unlikely to be the bootloader since the 84 doesn't support bootloading (at least using TinyCore- I assume that is what you're using).
What versions of the library are you using?
By bootloader I really meant the Programming shield that I am using.
I've tried using several versions of the library, both old and the latest. For "Onewire" it's 2.3.3, the one on the Teensy web site. For "DallasTemperature" its 3.7.5 by Milesburton. I've tried others as well, if I take the same code they all work fine on the Uno 328p.
Link to the onewire library and temperature library, and link to the core you're using. Preferably github links so we don't have to download anything to see the code.
Example of code using. I have two different cores, for the other core the LED_STATUS pin needs to be 7 and the OneWire_DATA_Pin needs to be 0. This just counts up the number of devices.
Well I finally figured out my problem. One of the moments where you just feel stupid. I forgot that the chips I am using had been set it to 1Mhz during some other test I was doing and I forgot to re-burn the bootloader to set the fuses to 8Mhz. I knew I had read that 1Mhz wouldn't work and that I needed to set the speed to 8Mhz, I had selected the 84 8Mhz setting but you have to reburn if it was set at 1Mhz previously. Getting old I guess.
