Attiny85 unable to program
Hello
I am unable to program my attiny85 board. this is the error i've been getting
Arduino: 1.8.19 (Windows 10), Board: "ATtiny25/45/85, ATtiny85, Internal 8 MHz"
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_init':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:88:16: error: 'SDA' undeclared (first use in this function)
   digitalWrite(SDA, 1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:88:16: note: each undeclared identifier is reported only once for each function it appears in
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:89:16: error: 'SCL' undeclared (first use in this function); did you mean 'SPL'?
   digitalWrite(SCL, 1);
                SPL
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:26:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:7: error: 'TWSR' undeclared (first use in this function); did you mean 'ACSR'?
   cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:3: note: in expansion of macro 'cbi'
   cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:92:13: error: 'TWPS0' undeclared (first use in this function); did you mean 'TWSR'?
   cbi(TWSR, TWPS0);
   cbi(TWSR, TWPS0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:93:13: error: 'TWPS1' undeclared (first use in this function); did you mean 'TWPS0'?
   cbi(TWSR, TWPS1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:93:3: note: in expansion of macro 'cbi'
   cbi(TWSR, TWPS1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:94:3: error: 'TWBR' undeclared (first use in this function); did you mean 'TWSR'?
   TWBR = ((F_CPU / TWI_FREQ) - 16) / 2;
   TWSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:3: error: 'TWCR' undeclared (first use in this function); did you mean 'TWBR'?
   TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA);
   TWBR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:102:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_disable':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
   TWCR &= ~(_BV(TWEN) | _BV(TWIE) | _BV(TWEA));
   EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:17: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:29: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:114:41: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:117:16: error: 'SDA' undeclared (first use in this function)
   digitalWrite(SDA, 0);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:118:16: error: 'SCL' undeclared (first use in this function); did you mean 'SPL'?
   digitalWrite(SCL, 0);
                SPL
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setAddress':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:130:3: error: 'TWAR' undeclared (first use in this function); did you mean 'TIFR'?
   TWAR = address << 1;
   TIFR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_setFrequency':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:141:3: error: 'TWBR' undeclared (first use in this function); did you mean 'TIFR'?
   TWBR = ((F_CPU / frequency) - 16) / 2;
   TIFR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_readFrom':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:204:7: error: 'TWDR' undeclared (first use in this function); did you mean 'DWDR'?
       TWDR = twi_slarw;
       DWDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:209:13: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
     } while(TWCR & _BV(TWWC));
             TWDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:209:24: error: 'TWWC' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:16: error: 'TWINT' undeclared (first use in this function)
     TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE); // enable INTs, but not START
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:29: error: 'TWEA' undeclared (first use in this function); did you mean 'TWWC'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:41: error: 'TWEN' undeclared (first use in this function); did you mean 'TWEA'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:210:53: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:213:65: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWEA'?
     TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTA);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_writeTo':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:301:7: error: 'TWDR' undeclared (first use in this function); did you mean 'DWDR'?
       TWDR = twi_slarw;
       DWDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:306:13: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
             TWDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:306:24: error: 'TWWC' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:16: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:29: error: 'TWEA' undeclared (first use in this function); did you mean 'TWWC'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:41: error: 'TWEN' undeclared (first use in this function); did you mean 'TWEA'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:307:53: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:310:65: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWEA'?
     TWCR = _BV(TWINT) | _BV(TWEA) | _BV(TWEN) | _BV(TWIE) | _BV(TWSTA); // enable INTs
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_reply':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:5: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
     TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWINT) | _BV(TWEA);
     EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:16: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:28: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:40: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:397:53: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_stop':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
   TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTO);
   EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:50: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:412:63: error: 'TWSTO' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_releaseBus':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:3: error: 'TWCR' undeclared (first use in this function); did you mean 'EECR'?
   TWCR = _BV(TWEN) | _BV(TWIE) | _BV(TWEA) | _BV(TWINT);
   EECR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:14: error: 'TWEN' undeclared (first use in this function); did you mean 'TWCR'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:26: error: 'TWIE' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:38: error: 'TWEA' undeclared (first use in this function); did you mean 'TWEN'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:444:50: error: 'TWINT' undeclared (first use in this function); did you mean 'TWIE'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'twi_handleTimeout':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:475:29: error: 'TWBR' undeclared (first use in this function); did you mean 'TIFR'?
     uint8_t previous_TWBR = TWBR;
                             TIFR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:476:29: error: 'TWAR' undeclared (first use in this function); did you mean 'TWBR'?
     uint8_t previous_TWAR = TWAR;
                             TWBR
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\compat\twi.h:36:0,
                 from C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:29:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c: In function 'TWI_vect':
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWSR' undeclared (first use in this function); did you mean 'ACSR'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS7' undeclared (first use in this function); did you mean 'TWSR'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS6' undeclared (first use in this function); did you mean 'TWS7'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS5' undeclared (first use in this function); did you mean 'TWS6'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS4' undeclared (first use in this function); did you mean 'TWS5'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:505:10: error: 'TWS3' undeclared (first use in this function); did you mean 'TWS4'?
   switch(TW_STATUS){
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:510:7: error: 'TWDR' undeclared (first use in this function); did you mean 'TWSR'?
       TWDR = twi_slarw;
       TWSR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:10: error: 'TWCR' undeclared (first use in this function); did you mean 'TWDR'?
          TWCR = _BV(TWINT) | _BV(TWSTA)| _BV(TWEN) ;
          TWDR
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:21: error: 'TWINT' undeclared (first use in this function)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:34: error: 'TWSTA' undeclared (first use in this function); did you mean 'TWS3'?
C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c:530:46: error: 'TWEN' undeclared (first use in this function); did you mean 'TWINT'?
exit status 1
Error compiling for board ATtiny25/45/85.
option enabled in File -> Preferences.
The code is given below:
 * Tiny4kOLED - Drivers for SSD1306 controlled dot matrix OLED/PLED 128x32 displays
 * Based on ssd1306xled, re-written and extended by Stephen Denne
 * from 2017-04-25 at https://github.com/datacute/Tiny4kOLED
// Choose your I2C implementation before including Tiny4kOLED.h
// The default is selected is Wire.h
// To use the Wire library:
//#include <Wire.h>
// To use the Adafruit's TinyWireM library:
//#include <TinyWireM.h>
// To use the TinyI2C library from https://github.com/technoblogy/tiny-i2c
//#include <TinyI2CMaster.h>
// The blue OLED screen requires a long initialization on power on.
// The code to wait for it to be ready uses 20 bytes of program storage space
// If you are using a white OLED, this can be reclaimed by uncommenting
// the following line (before including Tiny4kOLED.h):
//#define TINY4KOLED_QUICK_BEGIN
#include <Tiny4kOLED.h>
  // This example is for a 128x64 screen
  oled.begin(128, 64, sizeof(tiny4koled_init_128x64br), tiny4koled_init_128x64br);
  // Two rotations are supported,
  // The begin() method sets the rotation to 1.
  //oled.setRotation(0);
  // Some newer devices do not contain an external current reference.
  // Older devices may also support using the internal curret reference,
  // which provides more consistent brightness across devices.
  // The internal current reference can be configured as either low current, or high current.
  // Using true as the parameter value choses the high current internal current reference,
  // resulting in a brighter display, and a more effective contrast setting.
  //oled.setInternalIref(true);
  oled.clear();
  normalSize();
  doubleSize();
  oled.on();
  delay(10000);
void normalSize() {
  oled.setFont(FONT6X8P);
  oled.setCursor(0, 1);
  oled.print("Normal Size");
  oled.setFont(FONT8X16P);
  oled.setCursor(64, 0);
  oled.print("Datacute");
void doubleSize() {
  oled.setFontX2(FONT6X8P);
  oled.setCursor(0, 2);
  oled.print("Double Size");
  oled.setFontX2(FONT8X16P);
  oled.setCursor(0, 4);
type or paste code here
Can someone help with this issue?
try this one
/* Tiny4kOLED - Drivers for SSD1306 controlled dot matrix OLED/PLED 128x32 displays
//#include <Wire.h>
  oled.clear();
  normalSize();
  doubleSize();
  oled.on();
  delay(10000);
void normalSize() {
void doubleSize() {
hello
i tried uploading via your method, but now i have the following error message
> Arduino: 1.8.19 (Windows 10), Board: "ATtiny45/85 (Optiboot), Enabled, CPU (CPU frequency), ATtiny85, 8 MHz (internal), B.O.D. Disabled (saves power), Enabled"
> Sketch uses 4990 bytes (65%) of program storage space. Maximum is 7616 bytes.
> Global variables use 145 bytes (28%) of dynamic memory, leaving 367 bytes for local variables. Maximum is 512 bytes.
> avrdude: verification error, first mismatch at byte 0x0000
>          0x02 != 0x9e
> avrdude: verification error; content mismatch
at least no software errors now. check hardware.
okay will do. anything specific to look out on? all connections are verified :confused:
show your setup
this is it. i have verified the connections too
my question is, the basic blink code uploads and works without any issue but this does not. is there something im missing out on?
disconnect display while upload
same error shows up again
after blink sketch you change something. i think some wires missing or have not good contact
i verified every connection yet again and everything is alright. i retried the blink code and that uploads without any flaw.
i think this error pops up the moment i include the wire.h library to the code. does that help?
simple including bring no change. how it used is important.
yes
And i managed to figure it out. burning the bootloader before every upload helped
