Calculation current trough resistors
And one another test with adapter 450 mA. I cut red wire and put probes in circuit. That results with zero. So, it seems must be load there and I waa added a phone to charge. Showing changeable number 0.04, 0.03, 0.04, 0.03.. and repeat (not stable), at 5A scale.
But 450 mA must be 0.4 A (0.45), not 0.04, right?
If you connect that 450mA charger to 16A circuit breaker, does it draw 16A?
Not sure that I know what you mean :frowning:
You fire it straight, like from a gun!
This is my fourth multimeter test, and my own new one.
Also on 10A scale show 0.01A, which means 16 mA=0.01 (with one missing diggit will be 0.016).
That's why the 133B would have been a good choice.
But, yay! good job!
That current draw is from the load, not from supply.
If you have 10mA load, it draws that even if you have 1000000mA supply.
Thanks guys for solving my problem. I made credits for you!
I hope that topic will help somebody one day.
I invite you all to join my interesting and challenging project that I have started. I just changed the schematic by adding an LDR in front of all the LEDs and you must tell me is that shematic is good. I will need help, because, without you, I will not succeed.
Thank you all for your efforts.
This topic is getting closed closed
danyCro.
Credits_28112024
@PaulRB @kmin @jim-p @david_2018 @runaway_pancake @EmilyJane @build_1971 @JohnRob @Wawa @TomGeorge
Those resistors are 1k, 2k and 10k. So your readings are correct!
Which # Post @build_1971 ?
Post #32...
Yes, 3 multimeters measure good a voltage, resistance, but not amperes :slight_smile:
This new, fourth one (UT-131C), does it right :slight_smile:
closed
