on edit- the Pi is a 5! not 4.
on edit once more:
I want to be clear in the topic, so I want to explain that it is not the issue of whether a computer with the create agent installed can see a local or remote Raspberry Pi 5. My question/situation is that I am using the Raspberry Pi 5 as my main desk computer. I installed the create agent per explanations below, and I have an Arduino Uno R4 WiFi connected to the USB of the Raspberry Pi 5. My goal is to add the Arduino Uno R4 WiFi device to the Arduino cloud. But, that is another topic that I will research. So, this topic is solved, but I thought I would add the above explanation for others in similar circumstances.
The RPi5 is arch64/arm64 but github only has amd.
me@raspberrypi:
code removed on edit as not relevant to topic
I moved your topic to an appropriate forum category.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
In your case you posted where it said "do not post here", which it seemed you ignored.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it. How to get the best out of this forum before you proceed any further.
@shorenicehere that's not how it works. The topic has been moved to the appropriate forum category so all is well now. Just make sure to be careful about picking the category next time.
The topic will remain open and the forum helpers will provide assistance if possible.
I want to install Arduino Create Agent on my arm64 Raspberry Pi 5.
But GitHub says " "The Arduino Agent is supported both on Intel and Apple silicon computers. This includes devices with the M1, M2 and M3 processors.
At the moment the Arduino Agent is only built for Intel architectures."
So, am I out of luck? Can anyone here compile a amd64 version into a arm64 version for me?
In full disclosure, I doppelganged this inquiry on the Raspberry Pi forum. I did it during my confusion as shown above with administrator. I apologize again, but can't reverse it. Normally, I understand posters should not repeat inquiries on two different forums.
I mentioned that I am running this same inquiry on a different forum. I don’t want to do that but I am told I can’t close this inquiry. So, maybe that is even better….
I will concentrate on the below forum but will look here also, if anyone has an answer. I simply want to use my Raspberry Pi 5 (arm64 or aarch64) with Arduino-create-agent, but the Arduino download page for Connect-Agent only offers amd, Intel flavors.
Please respond to either forum .
But I have the issue now of not being able to connect my Raspberry Pi 5 to Arduino cloud. The trouble seems to be what ip address to give Arduino cloud agent page. Therefore, it seems that I should mark this topic as solved, and research all the previous tips and history in this Arduino forum about ip addresses listened to by Arduino Connect Agent.
