Can't get led matrix display to work on my arduino nano
Hi, i can't get a simple 8x8 max 7219 matrix to work.
I am only using a single element and im sure i wired it correctly.
This is my code:
#include <LedControl.h>
#define DIN 2
#define CS 3
#define CLK 4
#define ELEMENTS 1
#define INTENSITY 5
LedControl lc = LedControl(DIN, CS, CLK, ELEMENTS);
  for(int i = 0; i < ELEMENTS; i++) {
    lc.shutdown(i, false);
    lc.setIntensity(i, INTENSITY);
    lc.clearDisplay(i);
byte a[8] = {B01111110, B1000001, B00000000, B00000000, B00000000, B00000000, B00000000, B00000000 };
  for (int r = 0; r < 8; r++) {
    lc.setRow(0, r, a[r]);
Do you think i did something wrong?
Thanks in advance.
I think it is a hardware issue, from what I cannot see on your schematic is you used common anode configuration and the part needs common cathode.
What do you mean? i am using a pre made module with a max 7219 driver.
What are you running that with ?
md_parola might make things easier.
Many examples provided.
GitHub - MajicDesigns/MD_Parola: Library for modular scrolling LED matrix text displays
Change to:
LedControl lc = LedControl(DIN, CLK, CS, ELEMENTS);
and test.
Thanks ruilviana! now it works, sorry for the stupid error
