I have followed each wire back and forth at least three times now. I'll recheck though. I'll copy-paste the code next time. I just was not sure that the library was being read correctly since it was not colored. My soldered joints are not very good. That could be why my level shifter may not be working properly. I've only ever soldered around 20 pins.
It is possible that it is the level shifter that is faulty. I was measuring negligible voltage when I used a voltmeter to test some of the shifted connections. Would it be possible to make voltage dividers with different resistors? I only have 6 1k resistors, 9 10k resistors, and a few 220R resistors (From my very first arduino kit) As such:
(Please assume that the green wires are to connect to an SPI pin.) Each voltage divider circuit mimics the one in the previous photos.
