CD4051 Multiplexor input test sketch
I made a little sketch to test my MUX shield and thought it may be useful to someone else
It's for testing INPUT potentiometers
Sorry for spanish comments, but you just need to copy, paste and change multSelPins[] to the inputs (S0,S1,S2) of the MUX and muxPin to the Pin of "COM OUT/IN" (Pin 3 of IC)
//change multSelPins[] to the inputs (S0,S1,S2) of the MUX and muxPin to the Pin of "COM OUT/IN" (Pin 3 of IC)
const int multSelPins[]={2,3,4}; //selectores del multiplex (S2,S1,S0);
const int muxPin=A5; //salida del mux
  pinMode (muxPin,INPUT);
  for(int x=0;x<3;x++){
    pinMode(multSelPins[x],OUTPUT);
  int channel[]={0,0,0};
  multSelectInputFun(channel);
  int value=analogRead(muxPin);
  Serial.println(value);
  int channel1[]={0,0,1};
  multSelectInputFun(channel1);
  int channel2[]={0,1,0};
  multSelectInputFun(channel2);
  int channel3[]={0,1,1};
  multSelectInputFun(channel3);
  int channel4[]={1,0,0};
  multSelectInputFun(channel4);
  int channel5[]={1,0,1};
  multSelectInputFun(channel5);
  int channel6[]={1,1,0};
  multSelectInputFun(channel6);
  int channel7[]={1,1,1};
  multSelectInputFun(channel7);
  Serial.println("-----------------------");
void multSelectInputFun(int inputSel[]){
  //Serial.print("multInput :");
  for (int x=0;x<3;x++){
    //digitalWriteFast2(multSelPins[x],0); //prueba
    digitalWrite(multSelPins[x],inputSel[x]); //escribe el selector del multiplex con el valor que le pasamos
    //Serial.print(inputSel[x]);
  //Serial.println("");
  1. That's very inefficient;
  2. You may spuriously select two wrong channels before settling on your target channel.
Yes, I know it's not efficient but it's just for testing a connection to a MUX, works for me.
Sorry but I don't understand, what do you mean with this?
Think about your multSelectInputFun() call. As x goes through 0..2, you have selected multSelectPin[] will select two combinations before settling on the final combination.
dhenry:
Just how efficient do you want it to be given that there's a call to analogRead() which takes 110us????
inefficiency is a concept that applies not just to time.
