Code control sweeps the shaft of a DC motor with encoder back and forth across 180 degrees
I want to write a program to load into arduino, I have connected an H-bridge circuit to a DC motor with a 3-phase encoder A B Z. The purpose is to control the DC motor shaft scanning with a 180 reciprocating encoder. degree.
Can anyone help me?
If you want help, show what you've tried so far and what problem you're having. Publish your program in code tags, circuit diagram and technical data of the elements used. If you want someone else to do the work for you, look in the paid consulting section. A DC motor is not very suitable for your task. Maybe if it is a geared DC motor it will be more useful. It seems to me that it would still be more appropriate to use a stepper motor or an RC servo motor.
This page seems to be similar to your question (search: arduino dc motor encoder)
