Combine two voice recognition module
Hi, can anyone tell me how to define two voice recognition module in one arduino? Below is my code.
  * @file    vr_sample_multi_cmd.ino
  * @author  JiapengLi
  * @brief   This file provides a demostration on
              how to implement a multi voice command project (exceed 7 voice command)
              by using VoiceRecognitionModule
  * @note:
        voice control led
  * @section  HISTORY
    2013/06/13    Initial version.
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
  Connection
  Arduino    VoiceRecognitionModule
   2   ------->     TX
   3   ------->     RX
VR myVR(4,5);    //VR1 0-6
VR myVR(2,3);    //VR1 7-9
uint8_t record[7]; // save record
uint8_t record1[3];
uint8_t buf[64];
int led = 13;
int group = 0;
#define group0Record0        (0)
#define group0Record1       (1)
#define group0Record2       (2)
#define group0Record3       (3)
#define group0Record4       (4)
#define group0Record5       (5)
#define group0Record6       (6)
  /** initialize */
  myVR.begin(9600);
  Serial.println("Elechouse Voice Recognition V3 Module\r\nMulti Commands sample");
  pinMode(led, OUTPUT);
  if(myVR.clear() == 0){
    Serial.println("Recognizer cleared.");
  }else{
    Serial.println("Not find VoiceRecognitionModule.");
    Serial.println("Please check connection and restart Arduino.");
    while(1);
  record[0] = group0Record0;
  record[1] = group0Record1;
  record[2] = group0Record2;
  record[3] = group0Record3;
  record[4] = group0Record4;
  record[5] = group0Record5;
  record[6] = group0Record6;
  group = 0;
  if(myVR.load(record, 7) >= 0){
    printRecord(record, 7);
    Serial.println(F("loaded."));
  int ret;
  ret = myVR.recognize(buf, 50);
  if(ret>0){
    switch(buf[1]){
          if(group == 0)
          myVR.clear();
    /** voice recognized */
    printVR(buf);
  @brief   Print signature, if the character is invisible,
           print hexible value instead.
  @param   buf     --> command length
           len     --> number of parameters
void printSignature(uint8_t *buf, int len)
  int i;
  for(i=0; i<len; i++){
    if(buf[i]>0x19 && buf[i]<0x7F){
      Serial.write(buf[i]);
    else{
      Serial.print("[");
      Serial.print(buf[i], HEX);
      Serial.print("]");
  @param   buf  -->  VR module return value when voice is recognized.
             buf[0]  -->  Group mode(FF: None Group, 0x8n: User, 0x0n:System
             buf[1]  -->  number of record which is recognized.
             buf[2]  -->  Recognizer index(position) value of the recognized record.
             buf[3]  -->  Signature length
             buf[4]~buf[n] --> Signature
void printVR(uint8_t *buf)
  Serial.println("VR Index\tGroup\tRecordNum\tSignature");
  Serial.print(buf[2], DEC);
  Serial.print("\t\t");
  if(buf[0] == 0xFF){
    Serial.print("NONE");
  else if(buf[0]&0x80){
    Serial.print("UG ");
    Serial.print(buf[0]&(~0x80), DEC);
  else{
    Serial.print("SG ");
    Serial.print(buf[0], DEC);
  Serial.print("\t");
  Serial.print(buf[1], DEC);
  if(buf[3]>0){
    printSignature(buf+4, buf[3]);
  else{
//  Serial.println("\r\n");
void printRecord(uint8_t *buf, uint8_t len)
  Serial.print(F("Record: "));
  for(int i=0; i<len; i++){
    Serial.print(buf[i], DEC);
    Serial.print(", ");
Describe the problems that you are having, and post links to the devices.
See "How to get the best out of the forum" post at the head of every topic.
What sort of Arduino?
It can’t be done on a UNO, I know that but it might be able to be done on a Mega, but you will have to look at the library to see if it can cope with two instances and use a different hardware serial port for each.
I'm using MEGA. But the problem is this voice module available with only GPIO pin but not serial port function.
I am not sure this is right. If it is then you will have to modify the library so that it isn’t. Otherwise it is a no because while you can have two instances of software serial you can only receive data on one at a time, not both.
Ya this true. I have find out for it. I plan to use voice recognition V3 and another one which is V2. As V3 only provide GPIO pin function and V2 only provide serial port function. So, should be ok to combine them
It is right. The VR object is a subclass of SoftwareSerial. The library will have to be changed to use anything other than SoftwareSerial.
Of course, everyone knows by now that you can't have two instances of SoftwareSerial listening for input at the same time.
So, can I use voice recognition V2 and voice recognition V3 at the same time with Arduino mega ?
Well if this is correct
Then I would say that you can't use V2 with the library you have. Have you tried?
No. I just checked and the VoiceRecognitionV3 library is mostly a renamed version of the VoiceRecognitionV2 library.
The VoiceRecognitionV2 library also uses SoftwareSerial.
Here is a V3 library modified to allow the use of hardware and software serial ports:
VoiceRecognitionV4.h
  * @file    VoiceRecognitionV4.h
  * @author  Elechouse Team (V4 by John Wasser)
  * @version V4.0
  * @date    2021-10-2
  * @brief   This file provides all the VoiceRecognitionV2 firmware functions.
    @note
         This driver is for elechouse Voice Recognition V2 Module(LINKS here)
  * @section  HISTORY
    V1.0    Initial version.
    V4.0    Modified to take Stream pointers (Serial1, Serial2, SoftwareSerial...)
                Usage:
        #include "VoiceRecognitionV4.h"
        VR myVR1(&Serial1);
        VR myVR2(&Serial2);
        void setup(void)
            Serial1.begin(38400); // Default baud rate for VoiceRecognitionV3 module
            Serial2.begin(38400); // Default baud rate for VoiceRecognitionV3 module
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, ELECHOUSE SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2013 ELECHOUSE</center></h2>
#if ARDUINO >= 100
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
#include "wiring_private.h"
#include "SoftwareSerial.h"
#include <avr/pgmspace.h>
#define DEBUG
#ifdef DEBUG
#define DBGSTR(message)     Serial.print(message)
#define DBGBUF(buf, len)	Serial.write(buf, len)
#define DBGLN(message)		Serial.println(message)
#define DBGFMT(msg, fmt)	Serial.print(msg, fmt)
#define DBGCHAR(c)			Serial.write(c)
#else
#define DBG(message)
#endif // DEBUG
#define VR_DEFAULT_TIMEOUT						(1000)
#define FRAME_HEAD							(0xAA)
#define FRAME_END							(0x0A)
#define FRAME_CMD_CHECK_SYSTEM				(0x00)
#define FRAME_CMD_CHECK_BSR					(0x01)
#define FRAME_CMD_CHECK_TRAIN				(0x02)
#define FRAME_CMD_CHECK_SIG					(0x03)
#define FRAME_CMD_RESET_DEFAULT				(0x10)	//reset configuration
#define FRAME_CMD_SET_BR					(0x11)	//baud rate
#define FRAME_CMD_SET_IOM					(0x12)	//IO mode
#define FRAME_CMD_SET_PW					(0x13)	//pulse width
#define FRAME_CMD_RESET_IO					(0x14)	// reset IO OUTPUT
#define FRAME_CMD_SET_AL					(0x15)	// Auto load
#define FRAME_CMD_TRAIN						(0x20)
#define FRAME_CMD_SIG_TRAIN					(0x21)
#define FRAME_CMD_SET_SIG					(0x22)
#define FRAME_CMD_LOAD						(0x30)	//Load N records
#define FRAME_CMD_CLEAR						(0x31)	//Clear BSR buffer
#define FRAME_CMD_GROUP						(0x32)  //
	#define FRAME_CMD_GROUP_SET							(0x00)  //
	#define FRAME_CMD_GROUP_SUGRP						(0x01)  //
	#define FRAME_CMD_GROUP_LSGRP						(0x02)  //
	#define FRAME_CMD_GROUP_LUGRP						(0x03)  //
	#define FRAME_CMD_GROUP_CUGRP						(0x04)  //
#define FRAME_CMD_TEST						(0xEE)
	#define FRAME_CMD_TEST_READ							(0x01)
	#define FRAME_CMD_TEST_WRITE						(0x00)
#define FRAME_CMD_VR						(0x0D)	//Voice recognized
#define FRAME_CMD_PROMPT					(0x0A)
#define FRAME_CMD_ERROR						(0xFF)
// #define FRAME_ERR_UDCMD						(0x00)
// #define FRAME_ERR_LEN						(0x01)
// #define FRAME_ERR_DATA						(0x02)
// #define FRAME_ERR_SUBCMD					(0x03)
// //#define FRAME_ERR_
// #define FRAME_STA_SUCCESS					(0x00)
// #define FRAME_STA_FAILED					(0xFF)
class VR {
private:
    Stream *streamPtr;
public:
    VR(Stream *stream) : streamPtr(stream) {};
	typedef enum{
		PULSE = 0,
		TOGGLE = 1,
		SET = 2,
		CLEAR = 3
	}io_mode_t;
	typedef enum{
		LEVEL0 = 0,
		LEVEL1,
		LEVEL2,
		LEVEL3,
		LEVEL4,
		LEVEL5,
		LEVEL6,
		LEVEL7,
		LEVEL8,
		LEVEL9,
		LEVEL10,
		LEVEL11,
		LEVEL12,
		LEVEL13,
		LEVEL14,
		LEVEL15,
	}pulse_width_level_t;
	typedef enum{
		GROUP0 = 0,
		GROUP1,
		GROUP2,
		GROUP3,
		GROUP4,
		GROUP5,
		GROUP6,
		GROUP7,
		GROUP_ALL = 0xFF,
	}group_t;
	int setBaudRate(unsigned long br);
	int setIOMode(io_mode_t mode);
	int resetIO(uint8_t *ios=0, uint8_t len=1);
	int setPulseWidth(uint8_t level);
	int setAutoLoad(uint8_t *records=0, uint8_t len = 0);
    int disableAutoLoad();
	int restoreSystemSettings();
	int checkSystemSettings(uint8_t* buf);
	int recognize(uint8_t *buf, int timeout = VR_DEFAULT_TIMEOUT);
	int train(uint8_t *records, uint8_t len=1, uint8_t *buf = 0);
	int train(uint8_t record, uint8_t *buf = 0);
	int trainWithSignature(uint8_t record, const void *buf, uint8_t len=0, uint8_t *retbuf = 0);
	int load(uint8_t *records, uint8_t len=1, uint8_t *buf = 0);
	int load(uint8_t record, uint8_t *buf = 0);
	int clear();
	int setSignature(uint8_t record, const void *buf=0, uint8_t len=0);
	int deleteSignature(uint8_t record);
	int checkSignature(uint8_t record, uint8_t *buf);
	int checkRecognizer(uint8_t *buf);
	int checkRecord(uint8_t *buf, uint8_t *records = 0, uint8_t len = 0);
	/** group control */
	int setGroupControl(uint8_t ctrl);
	int checkGroupControl();
	int setUserGroup(uint8_t grp, uint8_t *records, uint8_t len);
	int checkUserGroup(uint8_t grp, uint8_t *buf);
	int loadSystemGroup(uint8_t grp, uint8_t *buf=0);
	int loadUserGroup(uint8_t grp, uint8_t *buf=0);
	int test(uint8_t cmd, uint8_t *bsr);
	int writehex(uint8_t *buf, uint8_t len);
	/** low level */
	int len(uint8_t *buf);
	int cmp(uint8_t *buf, uint8_t *bufcmp, int len  );
	void cpy(char *buf,  char * pbuf);
	void sort(uint8_t *buf, int len);
	int cleanDup(uint8_t *des, uint8_t *buf, int len);
	void send_pkt(uint8_t *buf, uint8_t len);
	void send_pkt(uint8_t cmd, uint8_t *buf, uint8_t len);
	void send_pkt(uint8_t cmd, uint8_t subcmd, uint8_t *buf, uint8_t len);
	int receive(uint8_t *buf, int len, uint16_t timeout = VR_DEFAULT_TIMEOUT);
	int receive_pkt(uint8_t *buf, uint16_t timeout = VR_DEFAULT_TIMEOUT);
    int read() {return streamPtr->read();}
    void write(byte b) {streamPtr->write(b);}
    void write(const uint8_t *buf, const uint8_t len) {streamPtr->write(buf, len);}
    int available() {return streamPtr->available();}
VoiceRecognitionV4.cpp
  * @file    VoiceRecognitionV4.cpp
  * @version V4.0
  * @date    2021-10-2
    @note
  * @section  HISTORY
    V4.0    Using 'Stream' instead of 'SoftwareSerial'
  * @attention
/** temp data buffer */
uint8_t vr_buf[32];
uint8_t hextab[17]="0123456789ABCDEF";
	@brief VR class constructor.
	@param buf --> return data .
		   timeout --> wait time for receiving packet.
	@retval length of valid data in buf. 0 means no data received.
int VR :: recognize(uint8_t *buf, int timeout)
	int ret, i;
	ret = receive_pkt(vr_buf, timeout);
	if(vr_buf[2] != FRAME_CMD_VR){
		return -1;
	if(ret > 0){
		for(i = 0; i < (vr_buf[1] - 3); i++){
			buf[i] = vr_buf[4+i];
		return i;
	return 0;
	@brief train records, at least one.
	@param records --> record data buffer pointer.
		   len --> number of records.
           buf --> pointer of return value buffer, optional.
		   buf[0]  -->  number of records which are trained successfully.
             buf[2i+1]  -->  record number
             buf[2i+2]  -->  record train status.
                00 --> Trained
                FE --> Train Time Out
                FF --> Value out of range"
             (i = 0 ~ len-1 )
	@retval '>0' --> length of valid data in buf.
            0 --> success, and no data received.
            '<0' --> failed.
                -1 --> data format error.
                -2 --> train timeout.
int VR :: train(uint8_t *records, uint8_t len, uint8_t *buf)
	int ret;
	unsigned long start_millis;
	if(len == 0){
		return -1;
	send_pkt(FRAME_CMD_TRAIN, records, len);
	start_millis = millis();
	while(1){
		ret = receive_pkt(vr_buf);
		if(ret>0){
			switch(vr_buf[2]){
				case FRAME_CMD_PROMPT:
					DBGSTR("Record:\t");
					DBGFMT(vr_buf[3], DEC);
					DBGSTR("\t");
					DBGBUF(vr_buf+4, ret-4);
				case FRAME_CMD_TRAIN:
					if(buf != 0){
						memcpy(buf, vr_buf+3, vr_buf[1]-2);
						return vr_buf[1]-2;
					DBGSTR("Train finish.\r\nSuccess: \t");
					DBGSTR(" \r\n");
					return 0;
				default:
		if(millis()-start_millis > 8000){
			return -2;
	return 0;
	@brief train one record.
                00 --> Trained
             (i = 0 ~ len-1 )
            '<0' --> failed.
int VR :: train(uint8_t record, uint8_t *buf)
    return train(&record, 1, buf);
	@brief train record and set a signature(alias) for this record.
	@param record --> record value.
           buf --> signature string/data pointer.
		   len --> lenght of buf.
		   retbuf --> return data .
			 retbuf[0]  -->  number of records which are trained successfully.
             retbuf[1]  -->  record number.
             retbuf[2]  -->  record train status.
                00 --> Trained
                F0 --> Trained, signature truncate
             retbuf[3] ~ retbuf[retval-1] --> Signature.(retval means return value)
            '<0' --> failed.
                -2 --> train with signature timeout.
int VR :: trainWithSignature(uint8_t record, const void *buf, uint8_t len, uint8_t * retbuf)
	int ret;
	if(len){
		send_pkt(FRAME_CMD_SIG_TRAIN, record, (uint8_t *)buf, len);
	}else{
		if(buf == 0){
			return -1;
		len = strlen((char *)buf);
		if(len>10){
			return -1;
	while(1){
		if(ret>0){
			switch(vr_buf[2]){
					DBGSTR("\t");
				case FRAME_CMD_SIG_TRAIN:
					if(retbuf != 0){
						memcpy(retbuf, vr_buf+3, vr_buf[1]-2);
						return vr_buf[1]-2;
					DBGSTR(" \r\n");
					writehex(vr_buf, vr_buf[1]+2);
					return 0;
				default:
			return -2;
	return 0;
    @brief Load records to recognizer.
             buf[0]    -->  number of records which are load successfully.
             buf[2i+2]  -->  record load status.
                00 --> Loaded
                FC --> Record already in recognizer
                FD --> Recognizer full
                FE --> Record untrained
             (i = 0 ~ '(retval-1)/2' )
            0 --> success, buf=0, and no data returned.
            '<0' --> failed.
int VR :: load(uint8_t *records, uint8_t len, uint8_t *buf)
	uint8_t ret;
	send_pkt(FRAME_CMD_LOAD, records, len);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_LOAD){
		return -1;
	if(buf != 0){
		return vr_buf[1]-2;
	return 0;
    @brief Load one record to recognizer.
                00 --> Loaded
            '<0' --> failed.
int VR :: load(uint8_t record, uint8_t *buf)
	uint8_t ret;
	send_pkt(FRAME_CMD_LOAD, &record, 1);
	if(ret<=0){
		return -1;
		return -1;
	if(buf != 0){
		return vr_buf[1]-2;
	return 0;
    @brief set signature(alias) for a record.
           buf --> signature buffer.
           len --> length of buf.
    @retval 0 --> success, buf=0, and no data returned.
            '<0' --> failed.
int VR :: setSignature(uint8_t record, const void *buf, uint8_t len)
	int ret;
	if(len == 0 && buf == 0){
		/** delete signature */
	}else if(len == 0 && buf != 0){
		if(buf == 0){
			return -1;
		if(len>10){
			return -1;
	}else if(len != 0 && buf != 0){
	}else{
		return -1;
	send_pkt(FRAME_CMD_SET_SIG, record, (uint8_t *)buf, len);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_SET_SIG){
		return -1;
	return 0;
    @brief delete signature(alias) of a record.
            -1 --> failed
int VR :: deleteSignature(uint8_t record)
    return setSignature(record);
    @brief check the signature(alias) of a record.
           buf --> signature, return value buffer.
            '<0' --> failed.
int VR :: checkSignature(uint8_t record, uint8_t *buf)
	int ret;
    /* 'record' is unsigned so it can never be less than 0
	if(record < 0){
		return -1;
	send_pkt(FRAME_CMD_CHECK_SIG, record, 0, 0);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_CHECK_SIG){
		return -1;
	if(vr_buf[4]>0){
		memcpy(buf, vr_buf+5, vr_buf[4]);
		return vr_buf[4];
	}else{
		return 0;
    @brief clear recognizer.
            -1 --> failed
int VR :: clear()
	int len;
	send_pkt(FRAME_CMD_CLEAR, 0, 0);
	len = receive_pkt(vr_buf);
	if(len<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_CLEAR){
		return -1;
	//DBGLN("VR Module Cleared");
	return 0;
    @param buf --> return value buffer.
             buf[0]     -->  Number of valid voice records in recognizer
             buf[i+1]   -->  Record number.(0xFF: Not loaded(Nongroup mode), or not set (Group mode))
                (i= 0, 1, ... 6)
             buf[8]     -->  Number of all voice records in recognizer
             buf[9]     -->  Valid records position indicate.
             buf[10]    -->  Group mode indicate(FF: None Group, 0x8n: User, 0x0n:System
    @retval '>0' --> success, length of data in buf
            -1 --> failed
int VR :: checkRecognizer(uint8_t *buf)
	int len;
	send_pkt(FRAME_CMD_CHECK_BSR, 0, 0);
	if(len<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_CHECK_BSR){
		return -1;
	if(vr_buf[1] != 0x0D){
		return -1;
	return vr_buf[1]-2;
    @brief check record train status.
             buf[0]     -->  Number of checked records
             buf[2i+1]  -->  Record number.
             buf[2i+2]  -->  Record train status. (00: untrained, 01: trained, FF: record value out of range)
             (i = 0 ~ buf[0]-1 )
    @retval Number of trained records
int VR :: checkRecord(uint8_t *buf, uint8_t *records, uint8_t len)
	int ret;
	int cnt = 0;
	if(records == 0 && len==0){
        memset(buf, 0xF0, 255);
		send_pkt(FRAME_CMD_CHECK_TRAIN, 0xFF, 0, 0);
		while(1){
			if(len>0){
				if(vr_buf[2] == FRAME_CMD_CHECK_TRAIN){
                    for(int i=0; i<vr_buf[1]-3; i+=2){
                        buf[vr_buf[4+i]]=vr_buf[4+i+1];
					cnt++;
					if(cnt == 51){
						return vr_buf[3];
				}else{
					return -3;
			if(millis()-start_millis > 500){
				if(cnt>0){
					buf[0] = cnt*5;
					return vr_buf[3];
				return -2;
	}else if(len>0){
		ret = cleanDup(vr_buf, records, len);
		send_pkt(FRAME_CMD_CHECK_TRAIN, vr_buf, ret);
		if(ret>0){
				memcpy(buf+1, vr_buf+4, vr_buf[1]-3);
				buf[0] = (vr_buf[1]-3)/2;
				return vr_buf[3];
			}else{
				return -3;
		}else{
			return -1;
	}else{
		return -1;
/******************************* GROUP CONTROL ******************************/
    @brief set group control by external IO function
    @param ctrl --> group control by external IO
                0 --> disable group control by external IO
                1 --> user group control by external IO
                2 --> system group control by external IO
            -1 --> failed
int VR :: setGroupControl(uint8_t ctrl)
	int ret;
	if(ctrl>2){
		return -1;
	send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_SET, &ctrl, 1);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_GROUP){
		return -1;
	return 0;
    @brief check group control by external IO function
    @retval  0 --> group control by external IO disabled
             1 --> user group control by external IO status
             2 --> system group control by external IO status
            -1 --> failed
int VR :: checkGroupControl()
	uint8_t cmd;
	int ret;
	cmd = 0xFF;
	send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_SET, &cmd, 1);
	if(ret<=0){
		return -1;
		return -1;
	ret = vr_buf[5];
	if(ret == 0xFF){
		ret = 0;
	return ret;
    @brief set user gruop content.
    @param grp --> user group number.
           records --> pointer of records buffer.
           len --> length of reocrds
            -1 --> failed
int VR :: setUserGroup(uint8_t grp, uint8_t *records, uint8_t len)
	int ret;
	if(len == 0 || records == 0){
		return -1;
	if(grp >= 8){
		return -1;
	vr_buf[0] = grp;
	memcpy(vr_buf+1, records, len);
	send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_SUGRP, vr_buf, len+1);
	if(ret<=0){
		return -1;
		return -1;
	return 0;
    @brief check user gruop content.
             buf[8i]    -->  group number.
             buf[8i+1]  -->  group position 0 status.
             buf[8i+2]  -->  group position 1 status.
             buf[8i+6]  -->  group position 5 status.
             buf[8i+7]  -->  group position 6 status.
             (i = 0 ~ @retval)
    @retval '>0' --> number of checked user group
            '<0' --> failed
int VR :: checkUserGroup(uint8_t grp, uint8_t *buf)
	int ret;
	int cnt = 0;
	if(grp == GROUP_ALL){
		send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_CUGRP, 0, 0);
		while(1){
			if(ret>0){
				if(vr_buf[2] == FRAME_CMD_GROUP && vr_buf[1] == 10){
					memcpy(buf+8*cnt, vr_buf+3, vr_buf[1]-2);
					cnt++;
					if(cnt == 8){
						return cnt;
				}else{
					return -3;
				if(cnt>0){
					return cnt;
				return -2;
	}else if(grp <= GROUP7){
		send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_CUGRP, &grp, 1);
		if(ret>0){
				return 1;
			}else{
				return -3;
		}else{
			return -2;
	}else{
		return -1;
    @brief load system gruop content to recognizer.
    @param grp --> syestem group number.
           buf  -->  return value.
             buf[0]     -->  Number of valid voice records in recognizer.
                (i= 0, 1, ... 6)
             (i = 0 ~ @retval)
    @retval '>0' --> length of buf
            '<0' --> failed
int VR :: loadSystemGroup(uint8_t grp, uint8_t *buf)
	int ret;
	if(grp > 10){
		return -1;
	send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_LSGRP, &grp, 1);
	if(ret <= 0){
		return -1;
		return -1;
	if(buf != 0){
		vr_buf[3] = 0;
		for(int i=0; i<8; i++){
			if(vr_buf[12]&(1<<i)){
				vr_buf[3]++;
		return vr_buf[1]-2;
	return 0;
    @brief load user gruop content to recognizer.
                (i= 0, 1, ... 6)
             buf[10]    -->  Group mode indicate(FF: None Group, 0x8n: User, 0x0n:System)
             (i = 0 ~ @retval)
            '<0' --> failed
int VR :: loadUserGroup(uint8_t grp, uint8_t *buf)
	int ret;
	if(grp > GROUP7){
		return -1;
	send_pkt(FRAME_CMD_GROUP, FRAME_CMD_GROUP_LUGRP, &grp, 1);
	if(ret <= 0){
		return -1;
		return -1;
	if(buf != 0){
		vr_buf[3] = 0;
				vr_buf[3]++;
		memcpy(buf, vr_buf+3, 11);
		return 1;
	return 0;
    @brief reset system setting to default
            -1 --> failed
int VR :: restoreSystemSettings()
	int len;
	send_pkt(FRAME_CMD_RESET_DEFAULT, 0, 0);
	if(len<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_RESET_DEFAULT){
		return -1;
	return 0;
    @brief check system settings
            buf[0] --> baud rate. (0-9600 1-2400 2-4800 3-9600 4-19200 5-38400)
            buf[1] --> output io mode(0-pulse 1-toggle 2-clear 3-set)
            buf[2] --> pulse width level
            buf[3] --> auto load(0,0xFF-disable 1-enable)
            buf[4] --> Group control by external IO(0-disable 1-system group 2-user group)
    @retval '>0' --> buf length
            -1 --> failed
int VR :: checkSystemSettings(uint8_t* buf)
	int len;
	if(buf == 0){
		return -1;
	send_pkt(FRAME_CMD_CHECK_SYSTEM, 0, 0);
	if(len<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_CHECK_SYSTEM){
		return -1;
	memcpy(buf, vr_buf+4, vr_buf[1]-3);
	return vr_buf[1]-3;
	return 0;
    @brief set module baud rate.
    @param br --> module baud rate.(0-9600 1-2400 2-4800 3-9600 4-19200 5-38400)
            -1 --> failed
int VR :: setBaudRate(unsigned long br)
	uint8_t baud_rate;
	int ret;
	switch(br){
		case 2400:
			baud_rate = 1;
		case 4800:
			baud_rate = 2;
		case 9600:
			baud_rate = 0;
			//baud_rate = 3;
		case 19200:
			baud_rate = 4;
		case 38400:
			baud_rate = 5;
		default:
			return -1;
	send_pkt(FRAME_CMD_SET_BR, baud_rate, 0, 0);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_SET_BR){
		return -1;
	return 0;
    @brief set module output IO mode.
    @param mode --> module output IO mode.(must be PULSE, TOGGLE, SET, CLEAR)
            -1 --> failed
int VR :: setIOMode(io_mode_t mode)
	if(mode > 3){
		return -1;
	int ret;
	send_pkt(FRAME_CMD_SET_IOM, mode, 0, 0);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_SET_IOM){
		return -1;
	return 0;
    @brief resset module output IO.
    @param ios --> output IO buffer.
           len --> length of ios.
            -1 --> failed
int VR :: resetIO(uint8_t *ios, uint8_t len)
	int ret;
	if(len == 1 && ios == 0){
		send_pkt(FRAME_CMD_RESET_IO, 0xFF, 0, 0);
	}else if(len != 0 && ios != 0){
		send_pkt(FRAME_CMD_RESET_IO, ios, len);
	}else{
		return -1;
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_RESET_IO){
		return -1;
	return 0;
    @brief set module pulse width(PULSE mode).
    @param level --> pulse width level.(LEVEL0~LEVEL15)
            -1 --> failed
int VR :: setPulseWidth(uint8_t level)
	int ret;
	if(level > VR::LEVEL15){
		return -1;
	send_pkt(FRAME_CMD_SET_PW, level, 0, 0);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_SET_PW){
		return -1;
	return 0;
    @brief set autoload.
    @param records --> record buffer.
           len --> records length.
            -1 --> failed
int VR :: setAutoLoad(uint8_t *records, uint8_t len)
	int ret;
	uint8_t map;
	if(len == 0 && records == 0){
		map = 0;
	}else if(len != 0 && records != 0){
		map = 0;
			map |= (1<<i);
	}else{
		return -1;
	send_pkt(FRAME_CMD_SET_AL, map, records, len);
	if(ret<=0){
		return -1;
	if(vr_buf[2] != FRAME_CMD_SET_AL){
		return -1;
	return 0;
    @brief disable autoload.
            -1 --> failed
int VR :: disableAutoLoad()
    return setAutoLoad();
int VR :: test(uint8_t cmd, uint8_t *bsr)
	int len, i;
	switch(cmd){
		case FRAME_CMD_TEST_READ:
			vr_buf[0] = FRAME_CMD_TEST_READ;
			send_pkt(FRAME_CMD_TEST, vr_buf, 1);
			while(1){
				if(len>0){
					switch(vr_buf[2]){
						case FRAME_CMD_TEST:
							memcpy(bsr+vr_buf[3]*20, vr_buf+4, 20);
							if(vr_buf[3] == 9){
								return 0;
						default:
							DBGLN("TEST ERROR");
							return -1;
				if(millis()-start_millis > 4000){
					return -2;
		case FRAME_CMD_TEST_WRITE:
			for(i=0; i<10; i++){
				vr_buf[0] = i;
				memcpy(vr_buf+1, bsr+20*i, 20);
				send_pkt(FRAME_CMD_TEST, FRAME_CMD_TEST_WRITE, vr_buf, 21);
				while(1){
					if(len>0){
						if(vr_buf[2] == FRAME_CMD_TEST){
						}else{
							return -1;
						return -2;
		default:
	return 0;
/**flash operation function (strlen)*/
int VR :: len(uint8_t *buf)
	int i=0;
	while(pgm_read_byte_near(buf++)){
		i++;
	return i;
/**flash operation function (strcmp)*/
int VR :: cmp(uint8_t *buf, uint8_t *bufcmp, int len  )
	int i;
		if(buf[i] != pgm_read_byte_near(bufcmp+i)){
			return -1;
	return 0;
/**flash operation function (strcpy)*/
void VR :: cpy(char *buf, char * pbuf)
  int i=0;
  while(pgm_read_byte_near(pbuf)){
    buf[i] = pgm_read_byte_near(pbuf++);
    i++;
/** ascending sort */
void VR :: sort(uint8_t *buf, int len)
	int i, j;
	uint8_t tmp;
		for(j=i+1; j<len; j++){
			if(buf[j] < buf[i]){
				tmp = buf[i];
				buf[i] = buf[j];
				buf[j] = tmp;
/** remove duplicates */
int VR :: cleanDup(uint8_t *des, uint8_t *buf, int len)
	if(len<1){
		return -1;
	int i, j, k=0;
		for(j=0; j<k; j++){
			if(buf[i] == des[j]){
		if(j==k){
			des[k] = buf[i];
			k++;
	return k;
#if 0
	int i=0, j=1, k=0;
	sort(buf, len);
	for(; j<len; ){
		des[k] = buf[i];
		k++;
		while(buf[i]==buf[j]){
			j++;
			if(j==len){
				return k;
		i=j;
	return k;
#endif
/** Serial print in HEX format */
int VR :: writehex(uint8_t *buf, uint8_t len)
	int i;
		DBGCHAR(hextab[(buf[i]&0xF0)>>4]);
		DBGCHAR(hextab[(buf[i]&0x0F)]);
		DBGCHAR(' ');
	return len;
    @brief send data packet in Voice Recognition module protocol format.
    @param cmd --> command
           subcmd --> subcommand
           buf --> data area
void VR :: send_pkt(uint8_t cmd, uint8_t subcmd, uint8_t *buf, uint8_t len)
	while(available()){
        read();// replace flush();
	write(FRAME_HEAD);
	write(len+3);
	write(cmd);
	write(subcmd);
	write(buf, len);
	write(FRAME_END);
           buf --> data area
void VR :: send_pkt(uint8_t cmd, uint8_t *buf, uint8_t len)
	while(available()){
	write(FRAME_HEAD);
	write(len+2);
	write(cmd);
	write(buf, len);
	write(FRAME_END);
    @param buf --> data area
void VR :: send_pkt(uint8_t *buf, uint8_t len)
	while(available()){
	write(FRAME_HEAD);
	write(len+1);
	write(buf, len);
	write(FRAME_END);
    @brief receive a valid data packet in Voice Recognition module protocol format.
           timeout --> time of reveiving
    @retval '>0' --> success, packet lenght(length of all data in buf)
            '<0' --> failed
int VR :: receive_pkt(uint8_t *buf, uint16_t timeout)
	int ret;
	ret = receive(buf, 2, timeout);
	if(ret != 2){
		return -1;
	if(buf[0] != FRAME_HEAD){
		return -2;
	if(buf[1] < 2){
		return -3;
	ret = receive(buf+2, buf[1], timeout);
	if(buf[buf[1]+1] != FRAME_END){
		return -4;
//	DBGBUF(buf, buf[1]+2);
	return buf[1]+2;
    @brief receive data .
           len --> length expect to receive.
    @retval number of received bytes, 0 means no data received.
int VR::receive(uint8_t *buf, int len, uint16_t timeout)
  int read_bytes = 0;
  int ret;
  while (read_bytes < len) {
    do {
      ret = read();
      if (ret >= 0) {
    } while( (millis()- start_millis ) < timeout);
    if (ret < 0) {
      return read_bytes;
    buf[read_bytes] = (char)ret;
    read_bytes++;
  return read_bytes;
vr_sample_bridge.ino:
    @file    vr_sample_bridge.ino
    @author  JiapengLi (V4 by John Waser)
              how to control led by using VoiceRecognitionModule
    @note:
        Use this sample to try the command of VoiceRecognition Module.
    Eg:
       1. Enable Arduino Serial monitor "Send with newline" feture, Baud rate 115200.
       2. Input "01" to "check recognizer",
       3. input "31" to "clear recognizer",
       4. input "30 00 02 04" to "load record 0, record 2, record 4"
    @section  HISTORY
    2013/06/17    Initial version.
VR myVR1(&Serial1);
VR myVR2(&Serial2);
// command analyze part
#define CMD_BUF_LEN      64+1
uint8_t cmd[CMD_BUF_LEN];
uint8_t cmd_cnt;
uint8_t *paraAddr;
uint8_t buf[400];
uint8_t buflen[32];
void setup(void)
  /** initialize */
  Serial.println(F("Elechouse Voice Recognition V3 Module \"bridge\" sample."));
  Serial.println(F("Eg:\r\n1. Enable Arduino Serial monitor \"Send with newline\" feture, Baud rate 115200.\r\n2. Input \"01\" to \"check recognizer\".\r\n3. input \"31\" to \"clear recognizer\"\r\n4. input \"30 00 02 04\" to \"load record 0, record 2, record 4\""));
void loop(void)
  int len, i, ret, index;
  /** receive Serial command */
  len = receiveCMD();
  if (len > 0)
    printSeperator();
    if (!checkCMD(len))
      ret = convertCMD(buf, len);
      if (ret > 0)
        Serial.print("> ");
        myVR1.writehex(buf, ret);
        myVR1.send_pkt(buf, ret);
        /** received command is invalid */
        /** display the receved command back */
        Serial.write(cmd, len);
        Serial.println(F("Input is not in hexadecimal format."));
      Serial.print("> ");
    //    printSeperator();
  /** recieve all packet a time */
  len = 0;
  index = 0;
  while (1)
    ret = myVR1.receive_pkt(buf + len, 50);
    if (ret > 0)
      len += ret;
      buflen[index] = ret;
      index++;
  if (index > 0)
    len = 0;
    for (i = 0; i < index; i++)
      Serial.print("< ");
      myVR1.writehex(buf + len, buflen[i]);
      len += buflen[i];
  @brief   receive command from Serial.
  @param   NONE.
  @retval  command length, if no command receive return -1.
int receiveCMD()
  int ret;
  int len;
  if (!Serial.available())
    return -1;
  while (1)
    ret = Serial.read();
    if (ret > 0)
      cmd[cmd_cnt] = ret;
      if (cmd[cmd_cnt] == '\n')
        len = cmd_cnt + 1;
        cmd_cnt = 0;
        return len;
      cmd_cnt++;
      if (cmd_cnt == CMD_BUF_LEN)
        cmd_cnt = 0;
        return -1;
    if (millis() - start_millis > 100)
      cmd_cnt = 0;
      return -1;
  @brief   Check command format.
  @param   len  -->  command length
  @retval  0  -->  command is valid
          -1  -->  command is invalid
int checkCMD(int len)
  int i;
  for (i = 0; i < len; i++)
    if (cmd[i] >= '0' && cmd[i] <= '9')
    else if (cmd[i] >= 'a' && cmd[i] <= 'f')
    else if (cmd[i] >= 'A' && cmd[i] <= 'Z')
    else if (cmd[i] == '\t' || cmd[i] == ' ' || cmd[i] == '\r' || cmd[i] == '\n')
      return -1;
  return 0;
  @brief   Check the number of parameters in the command
  @retval  number of parameters
int checkParaNum(int len)
  int cnt = 0, i;
  for (i = 0; i < len; )
    if (cmd[i] != '\t' && cmd[i] != ' ' && cmd[i] != '\r' && cmd[i] != '\n')
      cnt++;
      while (cmd[i] != '\t' && cmd[i] != ' ' && cmd[i] != '\r' && cmd[i] != '\n')
        i++;
    i++;
  return cnt;
  @brief   Find the specified parameter.
           paraIndex -->  parameter index
           addr      -->  return value. position of the parameter
  @retval  length of specified parameter
int findPara(int len, int paraIndex, uint8_t **addr)
  int cnt = 0, i, paraLen;
  uint8_t dt;
    dt = cmd[i];
    if (dt != '\t' && dt != ' ')
      cnt++;
      if (paraIndex == cnt)
        *addr = cmd + i;
        paraLen = 0;
          i++;
          paraLen++;
        return paraLen;
          i++;
      i++;
  return -1;
uint32_t atoh(uint8_t *str)
  int i, ret;
  i = 0, ret = 0;
  while ( (str[i] >= '0' && str[i] <= '9') || (str[i] >= 'A' && str[i] <= 'F') || (str[i] >= 'a' && str[i] <= 'f') )
    if (i == 8)
      ret = 0;
    ret <<= 4;
    if (str[i] >= '0' && str[i] <= '9')
      ret += (str[i] - '0');
    else if (str[i] >= 'A' && str[i] <= 'F')
      ret += (str[i] - 'A' + 0x0A);
    else if (str[i] >= 'a' && str[i] <= 'f')
      ret += (str[i] - 'a' + 0x0A);
    i++;
  return ret;
int convertCMD(uint8_t *des, int len)
  int i, paraNum, paraLen;
  paraNum = checkParaNum(len);
  for (i = 0; i < paraNum; i++)
    paraLen = findPara(len , i + 1, &paraAddr);
    if (paraLen > 2)
      return -1;
    des[i] = atoh(paraAddr);
    if (des[i] == 0)
      if (*paraAddr != '0')
        return -1;
      if (paraLen == 2 && *(paraAddr + 1) != '0')
        return -1;
  return paraNum;
  @brief   Print seperator. Print 80 '-'.
void printSeperator()
  for (int i = 0; i < 80; i++)
    Serial.write('-');
I have not tested it because I don't have the hardware.
But how I can write the serial command so that it can detect in Arduino ?
I don't understand what you are asking. The 'V4' library should work almost the same as the V3 library.
Change:
  myVR.begin(9600);
to:
VR myVR(Serial1);    //VR1 0-6
  Serial1.begin(9600);
You can make another VR object for a second serial port BUT THEY CAN'T BOTH BE NAMED 'myVR'.
alright I will try later and let u knw whether can works or not.
Thanks
I just thinking that for serial port, how I going to define the commands. Its like this as show below?
or
case x 11:
case x12:
This library is not available when I upload.
Error prompt out: "no such file or directory"
Have you installed it?
I just remodify the header file and cpp file which given by johnwasser
Did you put them in a library named "VoiceRecognitionV4"?
No. The things I modify is just the CPP and header file.
You should put them in:
<your sketchbook>/libraries/VoiceRecognitionV4/VoiceRecognitionV4.h
and
<your sketchbook>/libraries/VoiceRecognitionV4/VoiceRecognitionV4.cpp
