Compiler errors with TFT ili9341
Hello there,
I am working on a project of automated glasshouse. My system consists of Dragino lora shield with arduino Uno with some sensors for sorrounding environments and I would add a tft ili9341 touch screen as a visualizer for sensors' data. The arduino compiler gives errors, when I add the display and it doesn't accept any kind of tft commands like ( tft.begin())
I have attached the sketch that I used.
I searched for a solution here in a forum ,but no luck :frowning:
Any suggestions for solve these errors?
Hint: I tested tft display with sensors and i able to visualise data without any claim from compiler. The code for the system without the tftd display works fine.
Thanks in Advance.
Fred
final_testing:290:8: error: 'tft' was not declared in this scope
        tft.fillScreen(ILI9341_BLACK);
C:\Users\M****\OneDrive\Documents\Arduino\final_testing\final_testing.ino: In function 'void setup()':
final_testing:395:5: error: 'tft' was not declared in this scope
     tft.begin();
Multiple libraries were found for "lmic.h"
 Used: C:\Users\M**\OneDrive\Documents\Arduino\libraries\MCCI_LoRaWAN_LMIC_library
 Not used: C:\Users\M**\OneDrive\Documents\Arduino\libraries\arduino-lmic-master
Using library Adafruit_ILI9341 at version 1.5.8 in folder: C:\Users\M***\OneDrive\Documents\Arduino\libraries\Adafruit_ILI9341
Using library Adafruit_GFX_Library at version 1.10.10 in folder: C:\Users\M***\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library SPI at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\SPI
Using library DHTlib at version 0.1.33 in folder: C:\Users\M****\OneDrive\Documents\Arduino\libraries\DHTlib
Using library MCCI_LoRaWAN_LMIC_library at version 3.3.0 in folder: C:\Users\****\OneDrive\Documents\Arduino\libraries\MCCI_LoRaWAN_LMIC_library
Using library SimpleTimer in folder: C:\Users\M***\OneDrive\Documents\Arduino\libraries\SimpleTimer (legacy)
Using library Adafruit_BusIO at version 1.7.3 in folder: C:\Users\M****\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire
exit status 1
automated_glasshouse sketch.cpp (14.0 KB)
Where in the code do you create the object named tft ?
no ! I did not create it :(, shall I create one. where and how ?
Hence the problem
Have you looked at the examples that came with the Adafruit_ILI9341.h library ? They will have a line in them like this
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
Thanks alot Sir !! you made my day !! :blush: I have added and it has been solved :slight_smile:
,but I got another error :frowning: concerns to memory full issue
Global variables use 1557 bytes (76%) of dynamic memory, leaving 491 bytes for local variables. Maximum is 2048 bytes.text section exceeds available space in board
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
Error compiling for board Arduino Uno.
Please post your revised code as described in How to get the best out of this forum
Hi, here is the error that I got. for the reviesed code it attached above, I just add a declaration of object.
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Uno"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Muham\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\Muham\AppData\Local\Temp\arduino_build_461650 -warnings=none -build-cache C:\Users\Muham\AppData\Local\Temp\arduino_cache_848524 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Muham\OneDrive\Documents\Arduino\final_testing\final_testing.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Muham\OneDrive\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10815 -build-path C:\Users\Muham\AppData\Local\Temp\arduino_build_461650 -warnings=none -build-cache C:\Users\Muham\AppData\Local\Temp\arduino_cache_848524 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr -verbose C:\Users\Muham\OneDrive\Documents\Arduino\final_testing\final_testing.ino
Using board 'uno' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for Adafruit_ILI9341.h: [Adafruit_ILI9341@1.5.8]
ResolveLibrary(Adafruit_ILI9341.h)
  -> candidates: [Adafruit_ILI9341@1.5.8]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.10.10]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.10.10]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for dht.h: [DHTlib@0.1.33]
ResolveLibrary(dht.h)
  -> candidates: [DHTlib@0.1.33]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for lmic.h: [MCCI_LoRaWAN_LMIC_library@3.3.0 arduino-lmic-master@1.5.0+arduino-2]
ResolveLibrary(lmic.h)
  -> candidates: [MCCI_LoRaWAN_LMIC_library@3.3.0 arduino-lmic-master@1.5.0+arduino-2]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
Alternatives for SimpleTimer.h: [SimpleTimer]
ResolveLibrary(SimpleTimer.h)
  -> candidates: [SimpleTimer]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341\\Adafruit_ILI9341.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.7.3]
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: [Adafruit_BusIO@1.7.3]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library\\glcdfont.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib\\dht.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\ideetron\\AES-128_V10.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\lmic.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\other.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\hal\\hal.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\lmic.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\oslmic.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\radio.c" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer\\SimpleTimer.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src\\utility\\twi.c" -o nul
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit_ILI9341"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_ILI9341\Adafruit_ILI9341.cpp.o
Compiling library "Adafruit_GFX_Library"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_GFX_Library\Adafruit_GrayOLED.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\SPI\SPI.cpp.o
Compiling library "DHTlib"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\DHTlib\dht.cpp.o
Compiling library "arduino-lmic-master"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\lmic.c" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\lmic.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\other.c" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\other.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\aes\\ideetron\\AES-128_V10.cpp" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\ideetron\\AES-128_V10.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\hal\\hal.cpp" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\hal\\hal.cpp.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\radio.c" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\radio.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\lmic.c" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\lmic.c.o"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10815 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_ILI9341" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\DHTlib" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\SimpleTimer" "-IC:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\Adafruit_BusIO" "-IC:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Muham\\OneDrive\\Documents\\Arduino\\libraries\\arduino-lmic-master\\src\\lmic\\oslmic.c" -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\oslmic.c.o"
Compiling library "SimpleTimer"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\SimpleTimer\SimpleTimer.cpp.o
Compiling library "Adafruit_BusIO"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\Muham\AppData\Local\Temp\arduino_build_461650\libraries\Wire\utility\twi.c.o
Compiling core...
Using precompiled core: C:\Users\Muham\AppData\Local\Temp\arduino_cache_848524\core\core_arduino_avr_uno_94baf922c9d38d8316eaa2affe0e6dcb.a
Linking everything together...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.elf" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\sketch\\final_testing.ino.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_ILI9341\\Adafruit_ILI9341.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_GFX_Library\\Adafruit_GrayOLED.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\DHTlib\\dht.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\lmic.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\other.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\aes\\ideetron\\AES-128_V10.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\hal\\hal.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\lmic.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\oslmic.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\arduino-lmic-master\\lmic\\radio.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\SimpleTimer\\SimpleTimer.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/..\\arduino_cache_848524\\core\\core_arduino_avr_uno_94baf922c9d38d8316eaa2affe0e6dcb.a" "-LC:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650" -lm
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.elf" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.eep"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.elf" "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.hex"
Multiple libraries were found for "lmic.h"
 Used: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\arduino-lmic-master
 Not used: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\MCCI_LoRaWAN_LMIC_library
Using library Adafruit_ILI9341 at version 1.5.8 in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\Adafruit_ILI9341
Using library Adafruit_GFX_Library at version 1.10.10 in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library SPI at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\SPI
Using library DHTlib at version 0.1.33 in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\DHTlib
Using library arduino-lmic-master at version 1.5.0+arduino-2 in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\arduino-lmic-master
Using library SimpleTimer in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\SimpleTimer (legacy)
Using library Adafruit_BusIO at version 1.7.3 in folder: C:\Users\Muham\OneDrive\Documents\Arduino\libraries\Adafruit_BusIO
Using library Wire at version 1.0 in folder: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\Wire
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\Muham\\AppData\\Local\\Temp\\arduino_build_461650/final_testing.ino.elf"
Sketch uses 33908 bytes (105%) of program storage space. Maximum is 32256 bytes.
Global variables use 1557 bytes (76%) of dynamic memory, leaving 491 bytes for local variables. Maximum is 2048 bytes.text section exceeds available space in board
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
Error compiling for board Arduino Uno.
Do not attach your code. Post it here in code tags as requested to make it easy to see and copy
here you are. I uncomment some serial print for save some space on memory. sorry for midunderstanding
#include <Adafruit_ILI9341.h>
 * Copyright (c) 2019 Thomas Telkamp and Matthijs Kooijman
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses OTAA (Over-the-air activation), where where a DevEUI and
 * application key is configured, which are used in an over-the-air
 * activation procedure where a DevAddr and session keys are
 * assigned/generated for use with all further communication.
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate an AppEUI, DevEUI and AppKey.
 * Multiple devices can use the same AppEUI, but each device has its own
 * DevEUI and AppKey.
 * Do not forget to define the radio type correctly in config.h.
#include <stdint.h>
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include <Adafruit_GFX.h>
//extern const uint16_t SoilMoisture48[];
// For the Adafruit shield, these are the default.
#define TFT_DC 9
#define TFT_CS 10
#define TFT_RST 8
#define TFT_MISO 12
#define TFT_MOSI 11
#define TFT_CLK 13
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
#include <dht.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <SimpleTimer.h>
SimpleTimer timer;
dht DHT;
#define DHT11_PIN A0
#define Moisture1 A1
#define lightPin A2
#define Moisture2 A3
#define Moisture3 A4
static float moistureValue = -1;
const int ctl_pin=4; //define the output pin of realy
//static int lightsen_pin=3;  //define the input pin of light sensor I DONOT NEED IT
//static int led_pin=8;
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8]={0xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx};
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] ={xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx};
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
static float temperature,humidity,tem,hum;
//ch1: for Temp 67 , ch2 for Humidity 68, ch3: light sensor Analog input0x02 , ch4 digital output 0x01 Relay, ch5 for soil moisture 1 0x02 Analog Input .
// ch 6:  for soil moisture 2 0x02 analog input  ch7: for soil moisture3 analog input 0x02.
static uint8_t LPP_data[26] = {0x01,0x67,0x00,0x00,0x02,0x68,0x00,0x03,0x02,0x00,0x00,0x04,0x01,0x00,0x05,0x02,0x00,0x00,0x06,0x02,0x00,0x00,0x07,0x02,0x00,0x00}; //0xO1,0x02,0x03,0x04 is Data Channel,0x67,0x68,0x01,0x00 is Data Type
static uint8_t opencml[4]={0x04,0x00,0x64,0xFF},closecml[4]={0x04,0x00,0x00,0xFF}; //the payload of the cayenne or ttn downlink
static unsigned int count = 1;
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 31;
// Pin mapping
const lmic_pinmap lmic_pins = {
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            Serial.println(F("EV_SCAN_TIMEOUT"));
        case EV_BEACON_FOUND:
            Serial.println(F("EV_BEACON_FOUND"));
        case EV_BEACON_MISSED:
            Serial.println(F("EV_BEACON_MISSED"));
        case EV_BEACON_TRACKED:
            Serial.println(F("EV_BEACON_TRACKED"));
        case EV_JOINING:
            Serial.println(F("EV_JOINING"));
        case EV_JOINED:
            Serial.println(F("EV_JOINED"));
            // Disable link check validation (automatically enabled
            // during join, but not supported by TTN at this time).
            LMIC_setLinkCheckMode(0);
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED"));
        case EV_TXCOMPLETE:
            Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
            if (LMIC.txrxFlags & TXRX_ACK)
              Serial.println(F("Received ack"));
           if(LMIC.dataLen>0)
              int i,j=0;
              uint8_t received[4]={0x00,0x00,0x00,0x00};
               Serial.println("Received :");
              for(i=9;i<(9+LMIC.dataLen);i++)   //the received buf
                Serial.print(LMIC.frame[i],HEX);
                received[j]=LMIC.frame[i];
                j++;
                Serial.print(" ");
              //comparing incoming msg "downlink" with defined value of open relay "open cml"
              //in case of this statement TRUE the follwing commands will excute, otherwise jump to next statement.
            if ((received[0]==opencml[0])&&(received[1]==opencml[1])&&(received[2]==opencml[2])&&(received[3]==opencml[3])) {
              Serial.println("Set pin to HIGH.");
              digitalWrite(ctl_pin, HIGH);
            if ((received[0]==closecml[0])&&(received[1]==closecml[1])&&(received[2]==closecml[2])&&(received[3]==closecml[3])) {
              Serial.println("Set pin to LOW.");
               digitalWrite(ctl_pin, LOW);
            // Schedule next transmission
            os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
        case EV_LOST_TSYNC:
            Serial.println(F("EV_LOST_TSYNC"));
        case EV_RESET:
            Serial.println(F("EV_RESET"));
        case EV_RXCOMPLETE:
            // data received in ping slot
            Serial.println(F("EV_RXCOMPLETE"));
        case EV_LINK_DEAD:
            Serial.println(F("EV_LINK_DEAD"));
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));
         default:
            Serial.println(F("Unknown event"));
void dhtTem()
       int16_t tem_LPP;
       temperature = DHT.read11(DHT11_PIN);    //Read Tmperature data
       tem = DHT.temperature*1.0;
       humidity = DHT.read11(DHT11_PIN);      //Read humidity data
       hum = DHT.humidity* 1.0;
       int16_t moistureValue = analogRead(Moisture1); // soil moisture value
       int16_t moist_result=map(moistureValue,611,284,0,100);
     int16_t moistureValue2 = analogRead(Moisture2); // soil moisture2 value
     int16_t moist_result2=map(moistureValue2,610,285,0,100);
     int16_t moistureValue3 = analogRead(Moisture3); // soil moisture3 value
     int16_t moist_result3=map(moistureValue3,605,284,0,100);
       int16_t brightness= analogRead(lightPin);
       int16_t mapped_brightness = map(brightness,925,14,0,100);
       Serial.print("######### Smart Plant from THM ####### ");
       Serial.print("COUNT=");
       Serial.print(count);
       Serial.println("    ###########");
       Serial.println(F("The temperature and humidity:"));
       Serial.print("[");
       Serial.print(tem);
       Serial.print("℃");
       Serial.print(",");
       Serial.print(hum);
       Serial.print("%");
       Serial.print("]");
       Serial.println("");
       Serial.print("moisture is: ");
       Serial.println(moist_result);
       Serial.println( moist_result2);Serial.println( moist_result3);
       if (moist_result<65){
        //trun on the PUMP or closed the circuit.
        digitalWrite(4,LOW);
        LPP_data[13]=0x01;
        Serial.println(" I Am Dry pls Water!!\n Pump is ON ");
        delay(6500);
        digitalWrite(4,HIGH);
       else {
        LPP_data[13]=0x00;
       Serial.print("Britghtness is : ");
       Serial.print(mapped_brightness);
       if ( mapped_brightness < 10) {
       Serial.println(F(" - Dark!  "));
       Serial.println(F(" I need Light !!"));
       } else if ( mapped_brightness < 20) {
       Serial.println(" - DIM: ");
       } else if ( mapped_brightness < 50) {
       Serial.println(" - Light: ");
       } else if ( mapped_brightness < 80) {
       Serial.println(" -Bright : ");
       Serial.println(" - Very light: ");
       count++;
       tem_LPP=tem * 10;
       LPP_data[2] = tem_LPP>>8;
       LPP_data[3] = tem_LPP;
       LPP_data[6] = hum * 2;
     //sensor moisture0
       int16_t soil_final= moist_result*100;
       LPP_data[16]= soil_final>>8;
       LPP_data[17]=soil_final;
       int16_t lightresult= mapped_brightness*100;
       LPP_data[9]= lightresult>>8 ;
       LPP_data[10]=  lightresult;
     //sensor moisture 2
     int16_t soil_final2= moist_result2*100;
     LPP_data[20]= soil_final2>>8;
       LPP_data[21]=soil_final2;
     //sensor mositure 3
            int16_t soil_final3= moist_result3*100;
     LPP_data[24]= soil_final3>>8;
       LPP_data[25]=soil_final3;
       tft.fillScreen(ILI9341_BLACK);
  unsigned long start = micros();
  tft.setCursor(0, 0);
  tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(3);
  tft.println("Smart Plant");
  tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(3);
  //tft.println("Soil Moisture Result\n");
  tft.setTextColor(ILI9341_GREEN);    tft.setTextSize(3);
  tft.print("Sensor 1:");
  tft.print(moistureValue);tft.setTextSize(2);
  tft.print(" Hz,");tft.setTextSize(2);
  tft.print(moist_result);tft.println("%");
  tft.setTextSize(3);
    tft.print("\n");
  tft.print("Sensor 2:");
  tft.setTextSize(3);
  tft.print(moistureValue2);
  tft.setTextSize(2);
   tft.print(" HZ,");
   tft.setTextSize(3);
  tft.print(moist_result2);
  tft.println("%");
  tft.print("\n");
  tft.setTextSize(3);
  tft.print("Sensor 3:");
  tft.setTextSize(2);
  tft.print(moistureValue3);
  tft.print(" Hz,");
  tft.print(moist_result3);
  tft.println("%");
   delay(5000);
void action_relays(){
  relay_ON();
  timer.setTimeout(1000,relay_ON);
  timer.setTimeout(5000,relay_OFF);
void relay_ON(){
void relay_OFF(){
void pinread()
    int val_relay,val_lightsen;
    val_relay=digitalRead(ctl_pin);
    //val_lightsen=digitalRead(lightsen_pin);
    //Serial.println(" BRightness: 0 is dark and 1 is Sun: ");
    //Serial.println( digitalRead( lightsen_pin ));
    /*if(val_lightsen==1)
        LPP_data[9]=0x01;
        digitalWrite(led_pin,HIGH);
        LPP_data[9]=0x00;
        digitalWrite(led_pin,LOW);
    if(val_relay==1)
      LPP_data[13]=0x01;
      LPP_data[13]=0x00;
void do_send(osjob_t* j){
    // Check if there is not a current TX/RX job running
    if (LMIC.opmode & OP_TXRXPEND) {
        Serial.println(F("OP_TXRXPEND, not sending"));
        dhtTem();
        pinread();
        // int -> byte array
       // byte payload[2];
        //payload[0] = lowByte(sensorValue);
        //payload[1] = highByte(sensorValue);
        // Prepare upstream data transmission at the next possible time.
        LMIC_setTxData2(1,LPP_data, sizeof(LPP_data), 0);
        Serial.println(F("Packet queued"));
    // Next TX is scheduled after TX_COMPLETE event.
void setup(void) {
    while(!Serial);
    tft.begin();
    Serial.println("Connect to TTN and Send data to mydevice cayenne(Use DHT11 Sensor):");
    pinMode(ctl_pin,OUTPUT);
    //pinMode(lightsen_pin,INPUT);
    //pinMode(led_pin,OUTPUT);
//  attachInterrupt(1,fire,LOW);  //no connect Flame sensor should commented this code
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    digitalWrite(VCC_ENABLE, HIGH);
    #endif
    // LMIC init
    os_init();
    // Reset the MAC state. Session and pending data transfers will be discarded.
    LMIC_reset();
    // Start job (sending automatically starts OTAA too)
    do_send(&sendjob);
//void fire()
     LPP_data[12]=0x00;
     dhtTem();
     Serial.println("Have fire,the temperature is send");
     os_runloop_once();
Hello @UKHeliBob ,
does the code is readable for you ?
I can see the code and I have had a brief look at it but I cannot compile it because I don't have all of the libraries installed, hence cannot investigate the errors and I don't have time to work through the code line by line to see what is going on
thank you for your reply. now the error cuz of no space in the memory to load the sketch to the board.
i got this error.
Sketch uses 33520 bytes (103%) of program storage space. Maximum is 32256 bytes.
Global variables use 1525 bytes (74%) of dynamic memory, leaving 523 bytes for local variables. Maximum is 2048 bytes.
I saw what the error was and the only solution is to reduce the size of the program or to use an Arduino with more program memory
do you have any tips to reduce the size of sketch ?
Start by making sure that you are using the smallest variable type possible, especially for arrays. If variables or arrays are only holding values of 0 or 1 then consider using the bits of variables instead of whole bytes
You can reduce the size of the various .print messages.
You might possibly after a bit of work squash the program as is into the UNO, but the problem will come back next week when you want\have to add new features.
Given the libraries the program is using, the program is highly marginal on a UNO and likely not written for it, more likely its intended for a larger Arduino.
No it's written for Uno, but I have added a lcd touch screen for it. Thank you for your message.
Well, sometimes you need to accept the inevitable, adding such large memory consumers as the ILI9341 and touch stuff would cause issues with most programs on a UNO. Just a bare bones ILI9341 and touch example uses 43% of the flash, so you really need a Arduino with more memory.
I note you got much the same answer over in Reddit;
#include <dht.h>
#include <lmic.h>
#include <SPI.h>
I doubt if TFT, DHT and Timer libraries will be expensive.
There are no external fonts or bitmap images.
I don't have any experience of LMIC. So I suspect the Flash memory to go there.
Your memory report is 1652 bytes too big. You need major "trimming".
What was the memory report with the original code ? i.e. with Serial
I suggest that you just change to an Arduino with more memory.
David.
hi, this space for the code without adding LCD.
Sketch uses 26844 bytes (83%) of program storage space. Maximum is 32256 bytes.
Global variables use 1892 bytes (92%) of dynamic memory, leaving 156 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
