FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE\sketch\Blink.ino.cpp -o nul
Generating function prototypes...
C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE\sketch\Blink.ino.cpp -o C:\Users\Admin\AppData\Local\Temp\845629163\sketch_merged.cpp
C:\Users\Admin\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Admin\AppData\Local\Temp\845629163\sketch_merged.cpp
Compiling sketch...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino" "-IC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs" "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE\sketch\Blink.ino.cpp" -o "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Admin\AppData\Local\Temp\arduino\cores\arduino_avr_nano_cpu_atmega328_6be783227e5bc0d57f51230f0c71f584\core.a
Linking everything together...
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.elf" "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE\sketch\Blink.ino.cpp.o" "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/..\..\cores\arduino_avr_nano_cpu_atmega328_6be783227e5bc0d57f51230f0c71f584\core.a" "-LC:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE" -lm
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.elf" "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.eep"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.elf" "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.hex"
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.elf"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -patmega328p -carduino "-PCOM6" -b115200 -D "-Uflash:w:C:\Users\Admin\AppData\Local\Temp\arduino\sketches\B2CE95513589078BF2C18EC919A1C5DE/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM6": The system cannot find the file specified.
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Please help me resolve the above error as I am totally new to this.
