It works well in the default 4 wire SPI configuration.
If I'm understanding the table correctly to configure it to I2C I'll need to solder resistors in positions R1 and R8 and I'm not sure if I have to remove the resistor in positions R3 and R5.
In any case, can I make sure it is 4.7K resistors ? R5 is the only one that is not 4.7k, 914 should be 91K, does that make sense ?
Why do they do this to us, I have no idea where I'm going to get two 4.7k resistors, and even if I got them I don't know if I'll be able to solder them, I can't even read the numbers without a magnifier let alone solder it.
Can't I just connect the pads with solder ?
From memory, the R4, R6, R7 resistors can just remain untouched.
I have the schematic somewhere. From memory, there are already pullup resistors.
I have the same OLED that I have configured for I2C. I can find it and check what I did.
I was able to connect a 0 ohm SD resistor on R8 and a solder blob on R1. Not pretty but it might work.
Running a i2c scanner finds the device, but not always, the output is
Scanning...
No I2C devices found
Scanning...
Scanning...
Scanning...
Scanning...
I2C device found at address 0x3D !
done
Scanning...
<and so on>
I had some trouble with it, my guess is that having the RES (RESET) pin pulled up to 5V via a 10k resistor does not reset the display when loading new code to the NANO, I was getting only random dots until I removed the power (the RESET button didn't clean that either).
