Connect USB-C module in parallel with micro USB port. Is this correct?
Hello, nice to greet you all. I am starting to get into the topic of PLCs, and I am working on some projects. I hope you can help me, as I have been collecting information for days, but I still have some doubts. Let me explain:
It occurred to me to replace the connector of a tablet that has a micro USB port with a USB-C port. So far, everything is correct. I bought a module like the one in the image, but because the micro USB connector is smaller, I did not have enough space, and the insertion holes did not match to solder the new connector to the board. I decided to change its location, but since I have to make a new hole in the case to install the new USB-C port, it occurred to me to perhaps keep the previous micro USB port in its place and also install the new USB-C port in another part of the PCB board.
It is not an OTG port; it is a charging-only port. It does not transmit data and has a direct current input of 2.5A at 5V, which suggests that the charging signature would be a Dedicated Charging Port (DCP). Although I have not yet had the opportunity to read the SMD resistor that shorts the data paths, I have been reading about the mux and diode OR-ing setups. I realized it wouldn't be possible due to the forward voltage drop (Vf) of the diodes. Now, I think I could just make a parallel connection from the micro USB pins to the USB Type-C.
As far as I understand, and according to this post (How to replace mini USB with USB C? - #2 by kgray9), which describes a module similar to the one I plan to use, the 5th pin is ID. If I make the connection in parallel (I plan to use enameled copper wire and cover it with solder mask) and connect the voltage pins, data pins, ground, and ID pin like the schematic in the image, shouldn't it work fine as long as you don't use both ports simultaneously? Could there be any problems with negotiating power? If I am not mistaken, if the data pins on the micro USB or the CC pins on the USB-C are not connected, the device will not charge. Honestly, I wouldn't mind if it charged at the default speed, slower than it already does, as long as it charges.
Thanks in advance for all the help you can give me.
PS: I apologize for my possible grammatical errors in English; I am learning the language.
Screenshot (15)
Welcome to the forum
Why ?
More versatility: I live in Argentina, and getting a micro USB charger can be more difficult than it seems where I am. Additionally, having a USB-C port would allow me to charge the tablet with a cell phone charger as well. Thanks for the welcome. It is possible to do what I have in mind. What do you think?
How about using a micro USB plug to USB C socket adapter ?
Those adapters are quite expensive around here. Additionally, the tablet belongs to an elderly person who is quite forgetful and would surely lose the adapter. My idea is to allow the tablet to be charged with a single charger (like a cell phone charger) or to have more options and be able to charge it with whatever is available. Ideally, it should have something integrated that cannot be easily removed. What should happen if I connect both ID pins in parallel? it could work? Thanks for your help.
It appears to be a DCP BC 1.2 with the data lines shorted by a 200Ω resistor. I am open to any suggestions you might have.
The question I have is that according to the information described on the laptop case it has an input voltage of 2.5 amp, I seem to remember that BC 1.2 accepts 1.5amp. Am I making an error or could it be an implementation?
