Connecting Printer encoder
Hello,
i found optical/rotary encoder in old printer and i want to use it as encoder for steering wheel (arduino leonardo) but i dont know how to connect wires on encoder... there are no marks or anything how should i solder them...
encoder is from epson printer (i think stylus NX110/NX115/SX110/SX115/TX110/TX111/TX112/TX113/TX115/TX117/TX119 something like that)
cr0wl:
Hello,
The most obvious thing to do is measure the resistance between connections and make a list of what connections you try and what the resistance is.
Paul
Well yes thats what i did but not much luck...
What numbers should i expect from gnd and vcc or channels ...
cr0wl:
Show us yours first!
Paul
cr0wl:
I found optical/rotary encoder in old printer and I want to use it as encoder for steering wheel (Arduino Leonardo) but I don't know how to connect wires on encoder... there are no marks or anything how should I solder them.
Well, you would not expect instructions, would you? You solder them exactly as they were soldered in the printer - when you remove the module, you always take the connecting cables with it.
cr0wl:
encoder is from Epson printer (I think stylus NX110/NX115/SX110/SX115/TX110/TX111/TX112/TX113/TX115/TX117/TX119 something like that)
Since the internals of the printer are entirely proprietary, absolutely no-one here is going to know anything about particular models Epson printers. Few people are likely like myself, to keep old printers for disassembly. :astonished:
Here are your pictures. To post an image, you need to have the URL for the image, not a Web page.
Frankly, not very useful, out of focus. The best way to take photographs unless your workshop is lit by multiple floodlamps, is to take it outside in full daylight but not direct sun and use a digital camera (that is, not to be confused with a telephone) at least a metre away from directly above (or very slightly offset to ensure all the connections are able to be distinguished) using the (actual) zoom to just include all parts of the assembly. In your case, an oblique view would also be useful to understand how the encoder is assembled.
It looks as if the connections have been de-soldered. In this case, the answer to your "how to connect wires" is "the same way you disconnected them". :roll_eyes:
I think there are four connections. That makes sense, two for power and two for quadrature data. The two soldered connections on one side of the encoder itself will be a LED and there will be a series resistor for it. You should be able to trace the connections for this to the main termination, probably the outer two. The Diode Test range on a multimeter should be able to identify the LED and positive and negative.
Assuming you can identify the series resistor indicating it is safe to apply a voltage, you put 5 V across the LED terminals and monitor the other two with your Arduino as you rotate the encoder. You may need to use a pinMode of INPUT_PULLUP.
I had 2 Epson encoders (SX435W), one linear, one for rotation.
I have tested the rotary-encoder on a MapleMini with 3.3V.
The resistance from the outputs to V+ is about 10k. The resolution of the encoder is about 1000 / 360°
Ich habe nun an einem Buehler Motor den defekten Original-Encoder (HP-Q9898 , vermutlich identisch mit HEDS9720) mit einem Encoder aus EPSON Stylus SX430(W) mit Aufdruck N18 getauscht. Ich betreibe den Encoder an 3.3V, da ich nicht sicher bin, ob er 5V verträgt.
Die Anschlüsse sind im nachstehendem Kurz-Video markiert (+,-, die beiden anderen Ausgang A bzw. B):
die phasenversetzten Signale an den Encodern auf dem Osci:
Encoder N18 an 3.3V
Hello I've decided to create a steerinig wheel using arduino but i have no idea as to the connections to be made i asking for a little assistance
vurtoxx:
Neither do we!
paul
