So, using the ps3 usb example from usb host shield library 2.0, i have been trying to make a rgb led light up with a specific color with the press of the x button, and with another button press, make it turn off, and when the code starts running, make the led stay off until i hit that button. But when the sketch starts running, the led turns on and rapidly flickers between green and blue and stays on no matter if i press the off button or not. It does change color when hitting x, but then it flickers with reds and oranges, and i don't know why
Example sketch for the PS3 USB library - developed by Kristian Lauszus
For more information visit my blog: http://blog.tkjelectronics.dk/ or
send me an e-mail: kristianl@tkjelectronics.com
#include <PS3USB.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
USB Usb;
/* You can create the instance of the class in two ways */
PS3USB PS3(&Usb); // This will just create the instance
//PS3USB PS3(&Usb,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
bool printAngle;
uint8_t state = 0;
int ledRojo = 3;
int ledVerde = 5;
int ledAzul = 6;
pinMode(ledRojo,OUTPUT);
pinMode(ledVerde,OUTPUT);
pinMode(ledAzul,OUTPUT);
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); //halt
Serial.print(F("\r\nPS3 USB Library Started"));
Usb.Task();
if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
if (PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS3.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
if (PS3.PS3Connected) { // The Navigation controller only have one joystick
Serial.print(F("\tRightHatX: "));
Serial.print(PS3.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS3.getAnalogHat(RightHatY));
// Analog button values can be read from almost all buttons
if (PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
Serial.print(F("\r\nL2: "));
Serial.print(PS3.getAnalogButton(L2));
if (!PS3.PS3NavigationConnected) {
Serial.print(F("\tR2: "));
Serial.print(PS3.getAnalogButton(R2));
if (PS3.getButtonClick(PS))
Serial.print(F("\r\nPS"));
if (PS3.getButtonClick(TRIANGLE))
Serial.print(F("\r\nTriangle"));
if (PS3.getButtonClick(CIRCLE))
Serial.print(F("\r\nCircle"));
if (PS3.getButtonClick(CROSS))
//color ojos 1
analogWrite(ledRojo,255);
analogWrite(ledVerde,90);
analogWrite(ledAzul,10);
if (PS3.getButtonClick(SQUARE))
//color ojos 1
digitalWrite(ledRojo,LOW);
digitalWrite(ledVerde,LOW);
digitalWrite(ledAzul,LOW);
if (PS3.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
PS3.setLedOff();
PS3.setLedOn(LED4);
if (PS3.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS3.setLedOff();
PS3.setLedOn(LED1);
if (PS3.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS3.setLedOff();
PS3.setLedOn(LED2);
if (PS3.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS3.setLedOff();
PS3.setLedOn(LED3);
if (PS3.getButtonClick(L1))
Serial.print(F("\r\nL1"));
if (PS3.getButtonClick(L3))
Serial.print(F("\r\nL3"));
if (PS3.getButtonClick(R1))
Serial.print(F("\r\nR1"));
if (PS3.getButtonClick(R3))
Serial.print(F("\r\nR3"));
if (PS3.getButtonClick(SELECT)) {
Serial.print(F("\r\nSelect - "));
PS3.printStatusString();
if (PS3.getButtonClick(START)) {
Serial.print(F("\r\nStart"));
printAngle = !printAngle;
if (printAngle) {
Serial.print(F("\r\nPitch: "));
Serial.print(PS3.getAngle(Pitch));
Serial.print(F("\tRoll: "));
Serial.print(PS3.getAngle(Roll));
else if (PS3.PS3MoveConnected) { // One can only set the color of the bulb, set the rumble, set and get the bluetooth address and calibrate the magnetometer via USB
if (state == 0) {
PS3.moveSetRumble(0);
PS3.moveSetBulb(Off);
} else if (state == 1) {
PS3.moveSetRumble(75);
PS3.moveSetBulb(Red);
} else if (state == 2) {
PS3.moveSetRumble(125);
PS3.moveSetBulb(Green);
} else if (state == 3) {
PS3.moveSetRumble(150);
PS3.moveSetBulb(Blue);
} else if (state == 4) {
PS3.moveSetRumble(175);
PS3.moveSetBulb(Yellow);
} else if (state == 5) {
PS3.moveSetRumble(200);
PS3.moveSetBulb(Lightblue);
} else if (state == 6) {
PS3.moveSetRumble(225);
PS3.moveSetBulb(Purple);
} else if (state == 7) {
PS3.moveSetRumble(250);
PS3.moveSetBulb(White);
state++;
if (state > 7)
state = 0;
