Cut off Freq for PWM Sine low pass filter
Hi, to all the clever members.
I generated a 440Hz Sine wave with a Aduino Nano_Clasic.
Then I used a online calculator to get the values of R and C for the Low pass filter, the wave was full of spikes.
I played around with cut off Freqs of 1Khz to 3Khz .
Then I used a 100nF Cap with a variable pot and adjust the pot for the "cleanest" wave on my Scope , R is close to 20K
When I enter 100nF and 20K into the Lowpass filter calculator I get a Cut off Freq of 79Hz.
Question: Why is the cut off Freq so low.
Which pin are you generating it on?
The analogWrite() reference contains this:
I think you would need a filter with a very steep roll off and use 980Hz PWM to get a clean 440Hz sine wave without the filter attenuating it significantly.
Thanks for the reply -analogWrite - is a square wave.
I generate a PWM Sine wave on Pin 10.
My question is not about the Code but the Lowpass filter.
I thought the Lowpass must only cut of the High Freq PWM component but found out that the Sine wave "looks" the cleanest with R/C selected for 79Hz cut off Freq.
My Code: Please Note Copied from chatGpt!
#include <TimerOne.h> // Include TimerOne library
const int pwmPin = 10; // PWM output pin
const int sampleRate = 8000; // Sample rate in Hz
const int amplitude = 127; // Amplitude of the sine wave
const int frequency = 440; // Frequency of the sine wave in Hz
  pinMode(pwmPin, OUTPUT);
  Timer1.initialize(1000000 / sampleRate); // Set timer for sample rate
  Timer1.attachInterrupt(generateSineWave); // Attach the interrupt
  // Main loop does nothing, everything is handled in the interrupt
void generateSineWave() {
  static int index = 0; // Index for the sine wave
  float sineValue = sin(2 * PI * frequency * index / sampleRate); // Calculate sine value
  int pwmValue = amplitude * (sineValue + 1) / 2; // Scale to 0-255
  analogWrite(pwmPin, pwmValue); // Output PWM value
  index++;
  if (index >= sampleRate) {
    index = 0; // Reset index after one second
That is true but your PWM frequency is only a few Hertz higher the the sinewave frequency. So for a simple RC lowpass filter with a rolloff of only 20dB/decade you would need to lower the cutoff frequency quite a lot to get a "clean" looking signal
Thanks.
This looks like a trail and error work around.
Fc is unknown.
R and C is unknown.
Select a cut off Freq and calculate R and C.
If it does not work change the cut off Freq and try again.
or
Select a value for R and C , if it is not working change R and C.
We could not get it working 40+ years ago while studying and it still does not work.(After learning all these Formulae we try to make better sub woofer filters but the distortion was bad.)
Your problem is the low PWM frequency not the LPF cutoff. A PWM frequency of only 490Hz would probably be OK for making sinewaves of 50Hz or less. You need to use a higher PWM frequency to get a clean sinewave at 440Hz.
The calculator result is correct. Use different R and/or C values for a higher cutoff frequency.
But as already pointed out the "cutoff" is not a cutoff. For that first order filter, the response is a very slowly decreasing rolloff.
Capture
A good starting point is to choose a value for the capacitor and calculate its reactance at the given frequency. Then make the resistor equal to that.
Sorry I missread your reply , I was thinking of analogWrite(pin,freq); gen a single tone.
My code does indeed use analogWrite.
You could do better PWM than analogWrite() gives you.
Or use a board with a real digital to analog converter.
Or get a digital to analog converter module.
Or make your own with the same ICs they use in the modules.
Modules make it easiest and best I think.
a7
So if you used pins 5 or 6, you'd get double the PWM frequency, and hence you'd get smaller spikes for a given low pass filter compared to using pin 10.
As I, and others, said you won't be able to filter out the PWM frequency with a simple RC filter when you are trying to produce a 440Hz sine wave with a PWM frequency that's only just over 2x your 440Hz.
Ignoring filtering for the moment, the PWM frequency should probably be 10X the generated sine frequency.
Or with "infinite filtering" (or a filter with a much sharper cut-off than a simple RC filter) you can generate a square wave at the desired frequency (no PWM) and with the harmonics filtered-out, the square wave becomes a sine wave.
...Class-D audio amplifiers (which use something like PWM) typically have a switching frequency in the MHz range.
Maybe this would be fun:
As a reference to above responses I tested this below code and the PWM freq is as what every one said 490Hz.Note the commented out line's .. chapter 2.
//#include <TimerOne.h> // Include TimerOne library
//const int sampleRate = 8000;
  //Timer1.initialize(1000000 / sampleRate);
  analogWrite(10, 128);
Chapter 2.
With the below code the PWM is 8Khz .. Timerone Library change the PWM.
Yes but I am just playing around , this is all I have at the moment.
Fun indeed , I must save a link to this for future use.
Without Timerone Library.
With Timerone Library.
Sorry I didn't spot that you were bumping the PWM frequency up to 8kHz.
That's a lot better, now the frequency you are trying to filter out is ~20x the frequency of your sine wave.
Even so, I would expect, with a 440Hz RC low pass filter, that the spikes from the PWM would be about 10% of the amplitude of your sine wave.
Neither did I.
Just found out after testing on my Scope at home.
On a off topic note you are not by any chance this guy? .. Just asking.
Busted! LOL.
a7
That's right, I'm not :slight_smile:
@Dave_Lowther
I tested the filtered sine wave's freq and my friend chatGpt made a boo boo.
The freq is not 440Hz but 263 or 273Hz cant remember which one.
When I asked again for the code I got a complete different code that does not generate anything.
When I told AI the code is not working I got a new improved version did it 4 times all broken code when the code does generate something ,the top part is Sine but the bottom is a triangle.
Back to the drawing , now I will do it my way.
The cut off Freq remains a hidden.
