Can one safely cut up generic silicon solar cells (i.e. radioshacks: RadioShack.com Official Site - America's Technology Store) into smaller shapes with a dremel tool? Or would that destroy the cell (i.e. they would stop working) or would it just shatter it to bits from their fragility?
I've never tried it, but I'd be inclined to think it wouldn't cut nearly how you wanted it too unless you went VERY slowly with a VERY sharp blade and were VERY gentle!
Well, I suppose there is no loss in trying it myself. Too bad I won't be home for another week+, so if anyone has some solar cells lying around and a dremel/x-acto/glass cutter, then perhaps you could do a social service for all of us?
Various places (Electronic Goldmine, for instance) sell broken solar cells for making larger experimental panels; you won't ruin anything by cutting them smaller. Just make sure you leave the contacts for output available on your smaller pieces, and you should be OK.
I'm pretty sure that the regular brown cutting discs won't work for this, because they aren't hard enough. There are diamond discs available, but I think a carbide cutting tip will do.
The score-and-break method is likely to be your best bet: trying to cut all the way through with an abrasive will generate a lot of heat, and I suspect that may damage the cell. I know they warn you to be very careful soldering to them.
Actually, It's not for powering anything, but rather to detect a laser beam. I need to cut the panels up because I need a rather awkward shape to cover with the panels
just spent 15 minutes writing then had to delete it, got a bit carried away and it was'nt really appropriate but went along the lines of blah spy roaches, hollywood, blah, sharks with frikin lasers, blah U-571
why use a solar panel to detect a laser beam, won't it be affected by ambient light?
what about a phototransistor, or if you want to be clever how about using an LED as a detector
The conditions of operation for the project will maintain ambient light at a relatively constant level, or atleast below a minimum, so it will be easy to filter out (especially when there's a super-bright beam of light focused on the solar cell).
The reason I'm using solar panels is because I need something flat that can cover a rectangular prism
i might have used and old cdrom head, laser and detector on the same unit and mirrors and prism
Too complicated. Plus, the circuitry for detection will be inside the prism (I'm obviously not giving away a more specific idea in mind here, keeping my project under wraps ), and I need the prism to be able to tell which solar cell is detecting the laser.
don't worry, we'll get it out of you sooner or later, so why would you want to use a prism, to direct or split a beam, i would have said to break light into a spectrum but as a laser is only one wavelength i guess that wont work, maybe for a rangefinder, maybe for an audio spy, rgb laser colour mixing, laser blink sketch maybe, ah, laser harp, any advances
Hi it is possible to cut solar cells If you scratch them they'll snap (like glass )
I use carbide knife(I'm not sure is that a proper name) from cnc machine (it is hard and sharp )
I don't think that a standard disc glass cutter will do it- solar cells cracks very easy and disc cutter require pressure.
Dremel with a cutting disc will be good for scratching (then just need a snap:) )
When you have a chose get a thick cells they don't crack
I have thick cells with tin plating and they are very good for cutting
