DC motors work, servo and HC-SR04 doesn't
Ok so far I got the DC motors connected and the servo along with the Ultrasonic Sensor. I got the code uploaded and it only seems to run the DC motors forwards then back. I think within the code I don't have some sort of connection line for the Ultrasonic sensor and the servo. Could someone please help me out with this I think it's a coding issue.
//Servo
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
//Ultra sonic sensor
#include <AFMotor.h >    //Adafruit Motor Driver Shield library
long duration;         //duration of ultrasonic pulse
int distanceCm;        //distance in cm
//Motors
#include <AFMotor.h>
AF_DCMotor m1(1);//define motor 1 as m1
AF_DCMotor m2(2);//define motor 2 as m2
AF_DCMotor m3(3);//define motor 3 as m3
AF_DCMotor m4(4);//define motor 4 as m4
  //Servo
myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  Serial.begin (9600);
  pinMode(A1, OUTPUT);    //Analog pin A1 connected to TRIG
  pinMode(A0, INPUT);     //Analog pin A0 connected to ECHO
//Motors
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Robojax Motor test!");
  // initial state of motor turn on motor
  m1.setSpeed(0);//motor 1 is turned off to turn on change 0, to 255
  m2.setSpeed(0);//motor 2 is turned off
  m3.setSpeed(0);//motor 3 is turned off
  m4.setSpeed(0); //motor 4 is turned off
//servo
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15 ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
  digitalWrite(A1, LOW);
  delayMicroseconds(2);
  digitalWrite(A1, HIGH);    //give a pulse of 10us on TRIG
  delayMicroseconds(10);
  duration = pulseIn(A0, HIGH);     //check time elasped in receiving back the pulse on ECHO
  distanceCm = duration * 0.034 / 2; //convert to distance in cm
  if (distanceCm <= 20)          //if distance less than 20cm display on monitor
    Serial.println(distanceCm);
//motors
uint8_t i;
  Serial.println("Motor 1 FORWARD 100% speed");
  m1.run(FORWARD);
  m1.setSpeed(speed(100));
  Serial.println("m2 FORWARD 100%");
  m2.run(FORWARD);
  m2.setSpeed(speed(100));
  Serial.println("Motor 3 FORWARD 100% speed");
  m3.run(FORWARD);
  m3.setSpeed(speed(100));
  Serial.println("Motor 4 FORWARD 100% speed");
  m4.run(FORWARD);
  m4.setSpeed(speed(100));
  delay(3000);
  m1.run(RELEASE);
  Serial.println("M1 RELEASE");
  m2.run(RELEASE);
  Serial.println("m2 RELEASE");
  m3.run(RELEASE);
  Serial.println("M3 RELEASE");
  m4.run(RELEASE);
  Serial.println("M4 RELEASE");
  delay(3000);
  Serial.println("M1 BACKWARD 80%");
  m1.run(BACKWARD );
  m1.setSpeed(speed(80));
  Serial.println("m4 BACKWARD 80%");
 m2.run(BACKWARD );
 m2.setSpeed(speed(80));
  m3.run(BACKWARD );
  m3.setSpeed(speed(80));
  m4.run(BACKWARD );
  m4.setSpeed(speed(80));
  delay(3000);
 delay(3000);
  m1.run(RELEASE);
  m2.run(RELEASE);
  m3.run(RELEASE);
  m4.run(RELEASE);
  delay(3000);
  Serial.println("=============");
 * get pereentage value  0 to 100% and
 * conversts it to 0 to 255 which is motor speed used by Arduino
 * written by Ahmad Shamshiri on Feb 12, 2021
int speed(int b)
  return map(b, 0, 100, 0, 255);
This code was created by cutting and pasting blocks of code without understanding how they work? If so, that approach is a lottery.
Test each sensor and motor separately, using example code from the library for each one. Then you know that you have connected each one correctly and that your hardware is not faulty.
Hopefully, you need only one include per library.
What gets printed to the serial monitor?
maybe the hardware is faulty the servo only moves like a degree like there's power, a couple of times it did move, which is hard too explain it was going wild
What does that mean, please?
like a line of code saying Ultrasonic sensor pulse, rotate servo, then motors on if clear, if object turn right or left.
Ok what's wrong with this code it comes up with an error on the first line saying no such file or directory when I installed the adafruit motor drivers.
This code seems to make way more sense even though I don't fully understand it I suppose but this error comes up!
#include <AfMotor.h>                                //Import library to control motor shield
#include <Servo.h>                                  //Import library to control the servo
AF_DCMotor rightBack(1)                             //Create an object to control each motor
AF_DCMotor rightFront(2)
AF_DCMotor leftFront(3)
Af_DCMotor leftBack(4)
Servo servoLook;                                    //Create an object to control the servo
byte trig = 2;                                      //Assign the ultrasonic sensor pins
byte echo = 13;
byte maxDist = 150;                                 //Maximum sensing distance (Objects further than this distance are ignored)
byte stopDist = 50;                                 //Minimum distance from an object to stop in cm
float timeOut = 2*(maxDist+10)/100/340*1000000;     //Maximum time to wait for a return signal
byte motorSpeed = 55;                               //The maximum motor speed
int motorOffset = 10;                               //factor to account for one side being more powerful
int turnSpeed = 50;                                 //Amount to add to motor speed when turning
rightBack.setSpeed(motorSpeed);                     //Set the motors to the motor speed
rightFront.setSpeed(motorSpeed);
leftFront.setSpeed(motorSpeed+motorOffset;
rightBack.run(RELEASE);                             //Ensure all motors are stopped
rightFront.run(RELEASE);
leftFront.run(RELEASE);
leftBack.run(RELEASE);
servoLook.attach(10);                               //Assign the servo pin
pinMode(trig,OUTPUT);                               //Assign ultrasonic sensor pin modes
pinMode(echo,INPUT);
 servoLook.write(90);                              //Set the servo to look straight ahead
 delay(750);
 int distance = getDistance();                     //Check that there are no objects ahead
 if(distance >= stopDist)                          //If there are no objects within the stopping distance, move forward
  moveforward();
 while(distance >= stopDist)                      //Keep checking the object distance until it is within the minimum stopping distance
  delay(250);
stopMove();                                      //Stop the motors
int turnDir = checkDirection();                  //Check the left and right object distances amd get the turning instruction
Serial.print(turnDir);
switch (turnDir)                                //Turn left, turn around or turn right depending on the instruction
  case 0:                                       //Turn left
    turnLeft (400);
  case 1:                                       //Turn around
    turnLeft (700);
  case 2:                                       //Turn right
  turnRight (400);
void accelerate()                               //Function to accelerate the motors from 0 to full speed
  for (int i=0; i<motorSpeed; i++)              //Loop from 0 to full speed
    rightBack.setSpeed(i);                      //Set the motors to the current loop speed
    rightFront.setSpeed(i);
    leftFront.setSpeed(i+motorOffset);
    leftBack.setSpeed(i+motorOffset);
    delay(10);
void moveForward()                              //Set all motors to run forward
  rightBack.run(FORWARD);
  rightFront.run(FORWARD);
  leftFront.run(FORWARD);
  leftBack.run(FORWARD);
void stopMove()                               //Set all motors to stop
void turnLeft(int duration)                   //Set motors to turn left for the specified duration then stop
  rightBack.setSpeed(motorSpeed+turnSpeed);   //Set the motors to the motor speed
  rightFront.setSpeed(motorSpeed+turnSpeed;
  leftFront.setSpeed(motorSpeed+motorOffset+turnSpeed);
  leftBack.setSpeed(motorSpeed+motorOffset+turnSpeed);
  leftFront.run(BACKWARD);
  leftBack.run(BACKWARD);
  delay(duration);
  leftFront.setSpeed(motorSpeed+motorOffset);
  leftBack.setSpeed(motorSpeed+motorOffset);
void turnRight(int duration)                  //Set motors to turn right for the specified duration then stop
  rightFront.setSpeed(motorSpeed+turnSpeed);
  rightBack.run(BACKWARD);
  rightFront.run(BACKWARD);
  delay(duration);
  leftBack.setSpeed(motorSpeed+motorOffset;
int getDistance()                          //Measure the distance of an object
  unsigned long pulseTime;                //Create a variable to store the pulse travel time
  int distance;                           //Create a variable to store the calculated distance
  digitalWrite(trig. HIGH);               //Generate a 10 microsecond pulse
  digitalWrite(trig,LOW);
  pulseTime = pulseIn(echo, HIGH, timeOut);     //Measure the time for the pulse to return
  distance = (float)pulseTime *340 / 2 / 10000; //Calculate the object distance based on the pulse time
  return distance;
int checkDirection()                          //check the left and right directions and decide which way to turn
  int distances [2] = {0,0};                  //Left and right distances
  int turnDir = 1;                            //Direaction to turn, 0 left, 1 reverse, 2 right
  servoLook.write(180);                       //Turn servo to look left
  distances [0] = getDistance();              //Get the left object distance
  servoLook.write(0);                         //Turn servo to look right
  distances [1] = setDistance();              //Get the right object distance
  if (distances[0]>=200 && distances[1]>=200) //If both directions are clear, turn left
    turnDir = 0;
  else if (distances[0]<=stopDist && distances[1]<=stopDist)    //If both directions are blocked, turn around
    turnDir = 1;
  else if (distances[0]>=distances[1])                          //If left has more space, turn left
    turnDir = 0;
  else if (distances[0]<distances[1])                          //If right has more space, turn right
    turnDir = 2;
  return turnDir;
I fixed some small errors in the code and added a few things that sort of made sense when something wasn't declared but not it's saying 'Error compiling for board Arduino Uno.'
I installed about every motor shield library I could think of
What's wrong with the code?
#include <AFMotor.h>                                //Import library to control motor shield
;AF_DCMotor rightFront(2)
;AF_DCMotor leftFront(3)
;AF_DCMotor leftBack(4)
;Servo servoLook;                                    //Create an object to control the servo
byte echo = 13;
 delay(750);
  void moveforward();
  delay(250);
  case 0:                                       //Turn left
    turnLeft (400);
    turnLeft (700);
  turnRight (400);
    delay(10);
  delay(duration);
  delay(duration);
  return distance;
  distances [1] = getDistance();              //Get the right object distance
    turnDir = 0;
    turnDir = 1;
    turnDir = 0;
    turnDir = 2;
  return turnDir;
I got it working and used different code that worked out. She works perfectly! oh I've been waiting or this moment for a little while lol
Here's where I got the code that works wonderfully.
I can't believe I typed a whole thing of code that I paused on youtube before I found this one. But this code works great! Happy camper.
only problem is after a couple of bumps it started going backwards until I switched the wires of the left motors.
Now the back right motor slightly goes backwards to turn it right somewhat obtusely then goes forwards when there's nothing in the way.
also I had to switch the motors on the left side around after it's bump. Still not sure why it won't go forward...
Do you understand the code, or don't you care?
Understanding the code will make any debugging easier for all of us.
Please don't go starting new threads about the same project.
Tom.. :grinning: :+1: :coffee: :coffee: :coffee: :coffee: :australia:
This will not compile. Remove the semi-colons at the left/beginning of the lines, move them to the right/end of the lines.
Why not?
The first semicolon is after a comment... ooh... just tried it again (after failing)... it will compile. : /
I can't wait for the "one line" self balancing robot.
it told me to add semicolons odd
that's what the compiler told me to do
You were right. I was wrong.
