I am trying to select an enclosure for a project and am looking for the specifications of the physical dimension of the UNO.
the enclosure will need to have room for at least one shield. it seems that every shield could be a different height so that would complicate things a bit.
I did find a plan view of the board over at a different thread Re: Duemilanove engineering drawings
but it was wrong. the locations of the pins was wrong, specifically the top row.
I know I can measure my current boards, but that that does not offer anything other than what I have. I was hoping for a manufacturing spec that anyone making boards would try to follow. like a maximum allowable height.
The dimensions of the board, including the mounting hole locations, are published. These are needed to cut out the board and drill the holes.
The height of the components installed on the board is not a function of the schematic. You need to get out a ruler. There is no maximum allowable height.
Here's a drawing I did some time ago, it doesn't have the R3 connector sizes but nobody has said any dimensions are wrong after a couple of years so it should be pretty good.
dave-in-nj:
Nobody is going to give you a sensible answer on the information you have given. The physical dimensions of the Uno need only be rough, the heights of shields vary substantially, and that may be only part of the height problem. The other part is what plugs into it. You are far better off getting everything working, and then determine your own dimensions, and checking what's available. Making your own enclosure has a lot of things going for it, but price isn't necessarily one of them.
PaulS:
There should be to prevent mechanical interference with a possible shield attached.
