hi guys ... can i use an arduino nano without the diode
Which diode would that be ?
s4.
Can we all play ?
z123.
Please explain exactly which diode that you are referring to. Is this a classic Nano or one of the newer variants ?
i dont really know what you are talking about ...but whatever ... the diode is called s4 ..it is writen on it
and i think its a classic arduino nano and may be a cloud even
Whereabouts is this diode on the board ?
Why may you need to do without it ?
I'm guessing it is the Schottky diode between the USB socket and the 5V rail.
http://actrl.cz/blog/wp-content/uploads/nano_ch340_schematics-rev1.pdf
If you power the Nano via its Vin or 5V pins, does it work ?
yes
It sounds like the Schottky diode. If so, then I have replaced them in the past following "incidents" with power connections
Although they are SMD components they are reasonably easy to solder with a soldering iron
i know that i need to replace them ..but iam asking can i just go without replacing it just unpug it and solder
do you understand me
its writen on it ;;s4
here
If the Nano works via its 5V and Vin pins, and that is enough for you, leave it as it is. There is no need to remove the dead diode which appears to have failed on open circuit.
If you want to power the Nano through the USB socket, then replace the dead diode.
if i want to power it from the usb can i just pull the diode out of the arduino nano and solder the two parts
because when i do this the usb power will work
