Display GM12864-59N
Hi, I bought this GM12864-59N display for Arduino, I didn't understand which library to use and at what voltage it works. Can anyone help me?
I found the library, it's there
ST7567S_128X64_I2C-main
Which library did you use the ug8 one or the adafruit?
Or a separate one from Git?
Sorry complete n00b here!
Hello, I found the lib here: linkToHub
But I can display only a text. If we use Arduino UNO (5v logic) it is nececery to put R=4.7kOhm between +5 and SDA&SCL.
At long last i was able to make it run. Thanks for the info!!
Hello. I planned to use this display, and I am looking for technical documentation. It uses Sitronix ST7567S driver, and it is easy to find a complete data sheet explaining every command which can be addressed. But some things are not fixed, which depends on the usage made, PCB wiring, and the bare LCD. Which I2C adress ? Wich voltage and polarisation must be programmed, and so. Does anybody has a engineering technical data sheet of GM12864-59N and not only of the IC used on it ?
I want to understand everything, I do not want to use any alreay made library.
Hi Clark.
did you use a level shifter to connect to Arduino? What Arduino model did you use?
Can you send me the link of the level shifter that you used?
Thank so much.
