Hello,
Can someone tell me how to connect a DMF5005N to Arduino.
And if there is something I have to download for library.
Manny thanks in advance.
Hello,
As usual, a link to the datasheet would help. After some internet search, i found this: http://www.kyocera-display.com/SiteImages/PartList/SPEC/DMF5005N-COE-DDN_Eng.pdf
According to the datasheet, the display has a size of 240x64 pixel (page 2)
The controller is a T6963 (page 2)
The contrast setup is shown on page 8, but i do not think that you need a transistor. A simple variable potentiometer will be good enough. But you will need some -15 V (I have used a DC-DC converter module for this).
Once done with the electrical setup, you can use u8glib (Google Code Archive - Long-term storage for Google Code Project Hosting.):
U8GLIB_T6963_240X64(d0, d1, d2, d3, d4, d5, d6, d7, cs, a0, wr, rd [, reset])
Notes:
Oliver
Thanks for you reply Olikraus,
But I'm not a expert at this moment ![]()
I found this LCD in the trash at work and I'm sure he's still ok, but can you gide me trough how to connect the 20 pins?
1: FG -> gnd
2: VSS -> gnd
3: VCC -> +5V
4: VCC -> +5V with potmeter for contrast
5,6 -> 20 ???
I can work with a normal 16x2 LCD with the #include <LiquidCrystal.h>
Do you have some drawing of the wiring and some code?
Many thanks in advance,
Gunther
So after I wired it up what kind of include do I need to use?
Hi
Please have a look here: HITACHI - LMG7420PLFC-X - Displays - Arduino Forum
I suggest to connect the variable pot as described here (page 4): http://www.newhavendisplay.com/specs/NHD-24064CZ-FSW-GBW.pdf
For the graphics lib: Download U8glib v1.12 from here: Google Code Archive - Long-term storage for Google Code Project Hosting.
Follow the install instructions in "install.txt"
Let me know if you have more questions.
Oliver
Edit: VEE in the refered data sheet must be replaced by the output of an extern negative voltage source (-15V)
Hello Olivier,
thanks for answering.
I'm new with lcd's so ... I'm a little bit stupid ![]()
This LCD 16 x 2 Character LCD for 3.3V Power Supply Technical Data I can work with
but it's the dmf5005N is compleet differend if you look at http://www.kyocera-display.com/SiteImages/PartList/SPEC/DMF5005N-COE-DDN_Eng.pdf
When I put 5VDC on pin A and K on the side of the LCD I have the backlight comming on.
Pin 11->19 is D0 ->D7 and is for the data like on the 16x2 lcd
But I don't know how to connect all the other pins.
This is also what I found on the net: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=27405
Optrex DMF5005N Graphic LCD Test Circuit | This is a test ci… | Flickr
I don't have a electronic background but I try to learn it.
So if you can help me with the wiring and a test code I would be verry happy to start with.
Kind Regards
Gunther
Hi
//U8GLIB_T6963_240X64 u8g(8, 9, 10, 11, 4, 5, 6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
8 ) Uncomment this line:
Oliver
Edit:
14) Connect Arduino to your PC, download "HelloWorld" example. Adjust wiper until you see the HelloWorld String. Optional: Post a picture of the result.
Hello Olivier,
Thanks for your clear explanation ![]()
first I will make a DC inverter.
I let you know the result.
Kind Regards,
Gunther
how is this project going, curious if he ever got it going or not..
I have also attempted to do this.
Here's a picture of my setup:
Unfortunately, I can only get my LCD to show two lines and that's it.
It shows a few more horizontal lines when the arduino reboots but then nothing. Two lines and that's it.
Any ideas?
I am running the "hello world" example from u8g library as mentioned by olikraus, above.
Update:
It was working! The problem was the contrast voltage was set up incorrectly. I haven't really solved that problem, just run into a new one.
To recap though, Vcc-Vee voltage must be around 10-11V to display correctly.
So my setup is to have a 10k resistor connected to one side of a 5k pot, and the other side connected to -16V coming from a wall wart power supply. The wiper produces -4 to -16 V.
Here's a video demonstrating the problem I'm having. The voltage won't stay steady!
Update:
I replaced the two little electrolytic capacitors on the back of the display, and now it works perfectly!!
So the conclusion is, if your display is being wonky, try replacing the capacitors!!
Just for future reference, the rating of those capacitors is: 10 uF, 16 V and 4.7 uF 35 V
Dear , I have the MEGA 2560 and I want to use the 240x64 display moduleDMF5005 .
I just hook up all pin (as described above ) , but I need more clarification on PIN A0 A1A2 A3 A4 .
---->In MEGA version .there is PIN 14,15,16,17,18 and ALSO A0 A1 A2 A3 A4 .
my question is: What I must use ?
the syntax is ?
U8GLIB_T6963_240X64 u8g(8, 9, 10, 11, 4, 5,6, 7, 14, 15, 17, 18, 16); // 8Bit Com: D0..D7: 8,9,10,11,4,5,6,7, cs=14, a0=15, wr=17, rd=18, reset=16
I connect 5 V to VCC
VSS is connected to ground and
VEE connected to power negative -10 V
thank you in advance .
