Drivers
Hola.
tengo un problema. al conectar la placa de arduino en mi pc no me reconoce el puerto usb y los drivers ya estan instalados. que debo hacer?
I have a problem. when I connect the usb to my pc not recognize me and I have installed the drivers. What should I do?
What is your operation system? Windows, Linux , mac?
Please be more specific
I have Windows Xp Ihave installed the ftdi drivers but when I connect usb arduino board to my pc did not recognize it. in the IDE I do not see the option of serial port
Is your Arduino board using a FTDI chip? If not, the FTDI drivers are of no use. You install the drivers in the "drivers" directory, not the "FTDI" directory.
Hello!
My board has FTdI , I installed the drivers for Ftdi ,but the pc does not recognize it.When I play arduino program do not appear in tools>serial port.
I should do to make me recognize the COM port.
thanks
per the install instructions what does the device manager show?
The usb board of arduino is conected.
you have resolve the items that have a question mark in that list
Yes when conect the board of arduino apear this questions marks in "administrados de dispositivos"
Try to disable the question mark drivers and wait for a couple of minutes. Then re-enabled them.
Rooo:
try using the 1.0 driver folder.
hello.
one question
Because when i have the board of arduino and selected serial port,board .... i give upload and i get the message in the screen below: serial port COm10 already in use.try quiting any programs that may be in use. won't let me load the plate in the sketch and therefore i can't compile the program
