Drone Project Help - UNO R3 Bricked - How to AVOID in future(specifically in this case)?
I am working on making a drone using an Arduino, and using it as the main flight controller. Have been testing on and off for quite a few days, almost a month now, and using a 3S LiPo Battery (11.1V nominal voltage, and 12.6V fulle charged voltage) to power the whole setup. It suddeny decided to stop working, the main chip, starts to heat up very fast (maybe its always been hot, I decided to check today).
Connected Reset to Ground and RX to TX and checked by typing in random words in the Serial Monitor. The same word is returned so the chip seems to be fine. Flashed the latest .hex file using Atmel Flip to the Arduino. Still no use.
The built in LED is constantly on. Even on pressing the RESET button there is no change. Any advice on what can be done to salvage this Arduino? Need it desperately to finish the drone - both for a school project and see something fly, because it doesnt have the time to fall ( Orville Wright)
Check your design against these crispy critter rules:
Gil's Crispy Critter Rules, they apply to processor hardware:
Rule #1. A Power Supply the Arduino is NOT!
Rule #2. Never Connect Anything Inductive (motor, speaker) to an Arduino!
Rule #3 Don't connecting or disconnecting wires with power on.
Rule #4 Do not apply power to any pin unless you know what you are doing.
Rule #5 Do not exceed maximum Voltages.
LaryD's Corollary's
Coro #1 when first starting out, add a 220R resistor in series with both Input and Output pins.
Coro #2 buy a DMM (Digital Multi-meter) to measure voltages, currents and resistance. Violating these rules tends to make crispy critters out of Arduinos.
Hint: It is best to keep the wires under 25cm/10" for good performance.
If you violated any of them you probably fried your Arduino. See what chip gets hot, it may not be the processor. The chips are replaceable but if you do not have experience it is best to chuck it and purchase a new one(s).
We could do better if you posted your annotated schematic showing all connections, power, ground, and power sources.
That's too much for the on-board 5V regulator. You can not power more 5V modules, instead use a separate 5V step-down converter.
It's also used in the SPI interface. If you use SPI devices then this LED is not usable otherwise.
You are aware that there are 2 main chips on the board? A serial-to-usb converter (on real Unos that will be a 16U2) and the 328P (I suppose that that's the one that you refer to as the main chip).
Sounds like you reprogrammed the 16U2; that is not very useful if the loopback test was successful :wink:
Buy a new Arduino Uno is the safest bet; there might have been done other damage though the serial-to-usb converter seems to have survived. Alternatively, if your board has a DIP 328P, buy a 328P with the bootloader pre-installed.
You will have to review your schematic because a mistake in that will cause the same problem to come back after you've fixed your board.
For advise on why it failed you will need to provide schematics and code.
Nothing inductive was connected to the arduino.
what exactly are the maximum voltages. and is 12.5V out of range?
im not exactly sure what you mean by these
what exactly do i post?
i did not use the 5V out to power anything, but the 3.3V was being used to power and MPU6050, could that be why?
can i create a voltage divider by using resistors, and the use that to power the arduino through Vin
i dont know what the SPI interface is could you please clarify
which one seems to be fried? so according to you the serial-usb converter is ok? but the Atmega328P is fried. are those easily replacable.
 * The software is provided "as is", without any warranty of any kind.
 * Feel free to edit it if needed.
#include <Wire.h>
// ------------------- Define some constants for convenience -----------------
#define CHANNEL1 0
#define CHANNEL2 1
#define CHANNEL3 2
#define CHANNEL4 3
#define YAW      0
#define PITCH    1
#define ROLL     2
#define THROTTLE 3
#define X           0     // X axis
#define Y           1     // Y axis
#define Z           2     // Z axis
#define MPU_ADDRESS 0x68  // I2C address of the MPU-6050
#define FREQ        250   // Sampling frequency
#define SSF_GYRO    65.5  // Sensitivity Scale Factor of the gyro from datasheet
#define STOPPED  0
#define STARTING 1
#define STARTED  2
// ---------------- Receiver variables ---------------------------------------
// Previous state of each channel (HIGH or LOW)
volatile byte previous_state[4];
// Duration of the pulse on each channel of the receiver in µs (must be within 1000µs & 2000µs)
volatile unsigned int pulse_length[4] = {1500, 1500, 1000, 1500};
// Used to calculate pulse duration on each channel
volatile unsigned long current_time;
volatile unsigned long timer[4]; // Timer of each channel
// Used to configure which control (yaw, pitch, roll, throttle) is on which channel
int mode_mapping[4];
// ----------------------- MPU variables -------------------------------------
// The RAW values got from gyro (in °/sec) in that order: X, Y, Z
int gyro_raw[3] = {0,0,0};
// Average gyro offsets of each axis in that order: X, Y, Z
long gyro_offset[3] = {0, 0, 0};
// Calculated angles from gyro's values in that order: X, Y, Z
float gyro_angle[3]  = {0,0,0};
// The RAW values got from accelerometer (in m/sec²) in that order: X, Y, Z
int acc_raw[3] = {0 ,0 ,0};
// Calculated angles from accelerometer's values in that order: X, Y, Z
float acc_angle[3] = {0,0,0};
// Total 3D acceleration vector in m/s²
long acc_total_vector;
// Calculated angular motion on each axis: Yaw, Pitch, Roll
float angular_motions[3] = {0, 0, 0};
 * Real measures on 3 axis calculated from gyro AND accelerometer in that order : Yaw, Pitch, Roll
 *  - Left wing up implies a positive roll
 *  - Nose up implies a positive pitch
 *  - Nose right implies a positive yaw
float measures[3] = {0, 0, 0};
// MPU's temperature
int temperature;
// Init flag set to TRUE after first loop
boolean initialized;
// ----------------------- Variables for servo signal generation -------------
unsigned int  period; // Sampling period
unsigned long loop_timer;
unsigned long now, difference;
unsigned long pulse_length_esc1 = 1000,
        pulse_length_esc2 = 1000,
        pulse_length_esc3 = 1000,
        pulse_length_esc4 = 1000;
// ------------- Global variables used for PID controller --------------------
float pid_set_points[3] = {0, 0, 0}; // Yaw, Pitch, Roll
// Errors
float errors[3];                     // Measured errors (compared to instructions) : [Yaw, Pitch, Roll]
float delta_err[3]      = {0, 0, 0}; // Error deltas in that order   : Yaw, Pitch, Roll
float error_sum[3]      = {0, 0, 0}; // Error sums (used for integral component) : [Yaw, Pitch, Roll]
float previous_error[3] = {0, 0, 0}; // Last errors (used for derivative component) : [Yaw, Pitch, Roll]
// PID coefficients
float Kp[3] = {3.0, 0, 0};    // P coefficients in that order : Yaw, Pitch, Roll
float Ki[3] = {0.02, 0, 0}; // I coefficients in that order : Yaw, Pitch, Roll
float Kd[3] = {0, 20, 20};        // D coefficients in that order : Yaw, Pitch, Roll
 * Status of the quadcopter:
 *   - 0 : stopped
 *   - 1 : starting
 *   - 2 : started
 * @var int
int status = STOPPED;
int battery_voltage;
 * Setup configuration
    // Start I2C communication
    Wire.begin();
    TWBR = 12; // Set the I2C clock speed to 400kHz.
    // Turn LED on during setup
    pinMode(13, OUTPUT);
    digitalWrite(13, HIGH);
    // Set pins #4 #5 #6 #7 as outputs
    DDRD |= B11110000;
    setupMpu6050Registers();
    calibrateMpu6050();
    configureChannelMapping();
    // Configure interrupts for receiver
    PCICR  |= (1 << PCIE0);  // Set PCIE0 to enable PCMSK0 scan
    PCMSK0 |= (1 << PCINT0); // Set PCINT0 (digital input 8) to trigger an interrupt on state change
    PCMSK0 |= (1 << PCINT1); // Set PCINT1 (digital input 9) to trigger an interrupt on state change
    PCMSK0 |= (1 << PCINT2); // Set PCINT2 (digital input 10)to trigger an interrupt on state change
    PCMSK0 |= (1 << PCINT3); // Set PCINT3 (digital input 11)to trigger an interrupt on state change
    period = (1000000/FREQ) ; // Sampling period in µs
    // Initialize loop_timer
    loop_timer = micros();
    // Turn LED off now setup is done
    digitalWrite(13, LOW);
 * Main program loop
    // 1. First, read raw values from MPU-6050
    readSensor();
    // 2. Calculate angles from gyro & accelerometer's values
    calculateAngles();
    // 3. Calculate set points of PID controller
    calculateSetPoints();
    // 4. Calculate errors comparing angular motions to set points
    calculateErrors();
    if (isStarted()) {
        // 5. Calculate motors speed with PID controller
        pidController();
        compensateBatteryDrop();
    // 6. Apply motors speed
    applyMotorSpeed();
 * Generate servo-signal on digital pins #4 #5 #6 #7 with a frequency of 250Hz (4ms period).
 * Direct port manipulation is used for performances.
 * This function might not take more than 2ms to run, which lets 2ms remaining to do other stuff.
 * @see https:// www.arduino.cc/en/Reference/PortManipulation
void applyMotorSpeed() {
    // Refresh rate is 250Hz: send ESC pulses every 4000µs
    while ((now = micros()) - loop_timer < period);
    // Update loop timer
    loop_timer = now;
    // Set pins #4 #5 #6 #7 HIGH
    PORTD |= B11110000;
    // Wait until all pins #4 #5 #6 #7 are LOW
    while (PORTD >= 16) {
        now        = micros();
        difference = now - loop_timer;
        if (difference >= pulse_length_esc1) PORTD &= B11101111; // Set pin #4 LOW
        if (difference >= pulse_length_esc2) PORTD &= B11011111; // Set pin #5 LOW
        if (difference >= pulse_length_esc3) PORTD &= B10111111; // Set pin #6 LOW
        if (difference >= pulse_length_esc4) PORTD &= B01111111; // Set pin #7 LOW
 * Request raw values from MPU6050.
void readSensor() {
    Wire.beginTransmission(MPU_ADDRESS); // Start communicating with the MPU-6050
    Wire.write(0x3B);                    // Send the requested starting register
    Wire.endTransmission();              // End the transmission
    Wire.requestFrom(MPU_ADDRESS,14);    // Request 14 bytes from the MPU-6050
    // Wait until all the bytes are received
    while(Wire.available() < 14);
    acc_raw[X]  = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the acc_raw[X] variable
    acc_raw[Y]  = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the acc_raw[Y] variable
    acc_raw[Z]  = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the acc_raw[Z] variable
    temperature = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the temperature variable
    gyro_raw[X] = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the gyro_raw[X] variable
    gyro_raw[Y] = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the gyro_raw[Y] variable
    gyro_raw[Z] = Wire.read() << 8 | Wire.read(); // Add the low and high byte to the gyro_raw[Z] variable
 * Calculate real angles from gyro and accelerometer's values
void calculateAngles() {
    calculateGyroAngles();
    calculateAccelerometerAngles();
    if (initialized) {
        // Correct the drift of the gyro with the accelerometer
        gyro_angle[X] = gyro_angle[X] * 0.9996 + acc_angle[X] * 0.0004;
        gyro_angle[Y] = gyro_angle[Y] * 0.9996 + acc_angle[Y] * 0.0004;
        // At very first start, init gyro angles with accelerometer angles
        resetGyroAngles();
        initialized = true;
    // To dampen the pitch and roll angles a complementary filter is used
    measures[ROLL]  = measures[ROLL]  * 0.9 + gyro_angle[X] * 0.1;
    measures[PITCH] = measures[PITCH] * 0.9 + gyro_angle[Y] * 0.1;
    measures[YAW]   = -gyro_raw[Z] / SSF_GYRO; // Store the angular motion for this axis
    // Apply low-pass filter (10Hz cutoff frequency)
    angular_motions[ROLL]  = 0.7 * angular_motions[ROLL]  + 0.3 * gyro_raw[X] / SSF_GYRO;
    angular_motions[PITCH] = 0.7 * angular_motions[PITCH] + 0.3 * gyro_raw[Y] / SSF_GYRO;
    angular_motions[YAW]   = 0.7 * angular_motions[YAW]   + 0.3 * gyro_raw[Z] / SSF_GYRO;
 * Calculate pitch & roll angles using only the gyro.
void calculateGyroAngles() {
    // Subtract offsets
    gyro_raw[X] -= gyro_offset[X];
    gyro_raw[Y] -= gyro_offset[Y];
    gyro_raw[Z] -= gyro_offset[Z];
    // Angle calculation using integration
    gyro_angle[X] += (gyro_raw[X] / (FREQ * SSF_GYRO));
    gyro_angle[Y] += (-gyro_raw[Y] / (FREQ * SSF_GYRO)); // Change sign to match the accelerometer's one
    // Transfer roll to pitch if IMU has yawed
    gyro_angle[Y] += gyro_angle[X] * sin(gyro_raw[Z] * (PI / (FREQ * SSF_GYRO * 180)));
    gyro_angle[X] -= gyro_angle[Y] * sin(gyro_raw[Z] * (PI / (FREQ * SSF_GYRO * 180)));
 * Calculate pitch & roll angles using only the accelerometer.
void calculateAccelerometerAngles() {
    // Calculate total 3D acceleration vector : √(X² + Y² + Z²)
    acc_total_vector = sqrt(pow(acc_raw[X], 2) + pow(acc_raw[Y], 2) + pow(acc_raw[Z], 2));
    // To prevent asin to produce a NaN, make sure the input value is within [-1;+1]
    if (abs(acc_raw[X]) < acc_total_vector) {
        acc_angle[X] = asin((float)acc_raw[Y] / acc_total_vector) * (180 / PI); // asin gives angle in radian. Convert to degree multiplying by 180/pi
    if (abs(acc_raw[Y]) < acc_total_vector) {
        acc_angle[Y] = asin((float)acc_raw[X] / acc_total_vector) * (180 / PI);
 * Calculate motor speed for each motor of an X quadcopter depending on received instructions and measures from sensor
 * by applying PID control.
 * (A) (B)     x
 *   \ /     z ↑
 *    X       \|
 *   / \       +----→ y
 * (C) (D)
 * Motors A & D run clockwise.
 * Motors B & C run counter-clockwise.
 * Each motor output is considered as a servomotor. As a result, value range is about 1000µs to 2000µs
void pidController() {
    float yaw_pid      = 0;
    float pitch_pid    = 0;
    float roll_pid     = 0;
    int   throttle     = pulse_length[mode_mapping[THROTTLE]];
    // Initialize motor commands with throttle
    pulse_length_esc1 = throttle;
    pulse_length_esc2 = throttle;
    pulse_length_esc3 = throttle;
    pulse_length_esc4 = throttle;
    // Do not calculate anything if throttle is 0
    if (throttle >= 1012) {
        // PID = e.Kp + ∫e.Ki + Δe.Kd
        yaw_pid   = (errors[YAW]   * Kp[YAW])   + (error_sum[YAW]   * Ki[YAW])   + (delta_err[YAW]   * Kd[YAW]);
        pitch_pid = (errors[PITCH] * Kp[PITCH]) + (error_sum[PITCH] * Ki[PITCH]) + (delta_err[PITCH] * Kd[PITCH]);
        roll_pid  = (errors[ROLL]  * Kp[ROLL])  + (error_sum[ROLL]  * Ki[ROLL])  + (delta_err[ROLL]  * Kd[ROLL]);
        // Keep values within acceptable range. TODO export hard-coded values in variables/const
        yaw_pid   = minMax(yaw_pid, -400, 400);
        pitch_pid = minMax(pitch_pid, -400, 400);
        roll_pid  = minMax(roll_pid, -400, 400);
        // Calculate pulse duration for each ESC
        pulse_length_esc1 = throttle - roll_pid - pitch_pid + yaw_pid;
        pulse_length_esc2 = throttle + roll_pid - pitch_pid - yaw_pid;
        pulse_length_esc3 = throttle - roll_pid + pitch_pid - yaw_pid;
        pulse_length_esc4 = throttle + roll_pid + pitch_pid + yaw_pid;
    // Prevent out-of-range-values
    pulse_length_esc1 = minMax(pulse_length_esc1, 1100, 2000);
    pulse_length_esc2 = minMax(pulse_length_esc2, 1100, 2000);
    pulse_length_esc3 = minMax(pulse_length_esc3, 1100, 2000);
    pulse_length_esc4 = minMax(pulse_length_esc4, 1100, 2000);
 * Calculate errors used by PID controller
void calculateErrors() {
    // Calculate current errors
    errors[YAW]   = angular_motions[YAW]   - pid_set_points[YAW];
    errors[PITCH] = angular_motions[PITCH] - pid_set_points[PITCH];
    errors[ROLL]  = angular_motions[ROLL]  - pid_set_points[ROLL];
    // Calculate sum of errors : Integral coefficients
    error_sum[YAW]   += errors[YAW];
    error_sum[PITCH] += errors[PITCH];
    error_sum[ROLL]  += errors[ROLL];
    // Keep values in acceptable range
    error_sum[YAW]   = minMax(error_sum[YAW],   -400/Ki[YAW],   400/Ki[YAW]);
    error_sum[PITCH] = minMax(error_sum[PITCH], -400/Ki[PITCH], 400/Ki[PITCH]);
    error_sum[ROLL]  = minMax(error_sum[ROLL],  -400/Ki[ROLL],  400/Ki[ROLL]);
    // Calculate error delta : Derivative coefficients
    delta_err[YAW]   = errors[YAW]   - previous_error[YAW];
    delta_err[PITCH] = errors[PITCH] - previous_error[PITCH];
    delta_err[ROLL]  = errors[ROLL]  - previous_error[ROLL];
    // Save current error as previous_error for next time
    previous_error[YAW]   = errors[YAW];
    previous_error[PITCH] = errors[PITCH];
    previous_error[ROLL]  = errors[ROLL];
 * Customize mapping of controls: set here which command is on which channel and call
 * this function in setup() routine.
void configureChannelMapping() {
    mode_mapping[YAW]      = CHANNEL4;
    mode_mapping[PITCH]    = CHANNEL2;
    mode_mapping[ROLL]     = CHANNEL1;
    mode_mapping[THROTTLE] = CHANNEL3;
 * Configure gyro and accelerometer precision as following:
 *  - accelerometer: ±8g
 *  - gyro: ±500°/s
 * @see https://www.invensense.com/wp-content/uploads/2015/02/MPU-6000-Register-Map1.pdf
void setupMpu6050Registers() {
    // Configure power management
    Wire.beginTransmission(MPU_ADDRESS); // Start communication with MPU
    Wire.write(0x6B);                    // Request the PWR_MGMT_1 register
    Wire.write(0x00);                    // Apply the desired configuration to the register
    // Configure the gyro's sensitivity
    Wire.write(0x1B);                    // Request the GYRO_CONFIG register
    Wire.write(0x08);                    // Apply the desired configuration to the register : ±500°/s
    // Configure the acceleromter's sensitivity
    Wire.write(0x1C);                    // Request the ACCEL_CONFIG register
    Wire.write(0x10);                    // Apply the desired configuration to the register : ±8g
    // Configure low pass filter
    Wire.write(0x1A);                    // Request the CONFIG register
    Wire.write(0x03);                    // Set Digital Low Pass Filter about ~43Hz
 * Calibrate MPU6050: take 2000 samples to calculate average offsets.
 * During this step, the quadcopter needs to be static and on a horizontal surface.
 * This function also sends low throttle signal to each ESC to init and prevent them beeping annoyingly.
 * This function might take ~2sec for 2000 samples.
void calibrateMpu6050() {
    int max_samples = 2000;
    for (int i = 0; i < max_samples; i++) {
        readSensor();
        gyro_offset[X] += gyro_raw[X];
        gyro_offset[Y] += gyro_raw[Y];
        gyro_offset[Z] += gyro_raw[Z];
        // Generate low throttle pulse to init ESC and prevent them beeping
        PORTD |= B11110000;      // Set pins #4 #5 #6 #7 HIGH
        delayMicroseconds(1000); // Wait 1000µs
        PORTD &= B00001111;      // Then set LOW
        // Just wait a bit before next loop
        delay(3);
    // Calculate average offsets
    gyro_offset[X] /= max_samples;
    gyro_offset[Y] /= max_samples;
    gyro_offset[Z] /= max_samples;
 * Make sure that given value is not over min_value/max_value range.
 * @param float value     : The value to convert
 * @param float min_value : The min value
 * @param float max_value : The max value
 * @return float
float minMax(float value, float min_value, float max_value) {
    if (value > max_value) {
        value = max_value;
    } else if (value < min_value) {
        value = min_value;
    return value;
 * Return whether the quadcopter is started.
 * To start the quadcopter, move the left stick in bottom left corner then, move it back in center position.
 * To stop the quadcopter move the left stick in bottom right corner.
 * @return bool
bool isStarted() {
    // When left stick is moved in the bottom left corner
    if (status == STOPPED && pulse_length[mode_mapping[THROTTLE]] <= 1015) {
        status = STARTING;
    // When left stick is moved back in the center position
    if (status == STARTING && pulse_length[mode_mapping[THROTTLE]] >= 1090) {
        status = STARTED;
        // Reset PID controller's variables to prevent bump start
        resetPidController();
        resetGyroAngles();
    // When left stick is moved in the bottom right corner
    if (status == STARTED && pulse_length[mode_mapping[THROTTLE]] <= 1015) {
        status = STOPPED;
        // Make sure to always stop motors when status is STOPPED
        stopAll();
    return status == STARTED;
 * Reset gyro's angles with accelerometer's angles.
void resetGyroAngles() {
    gyro_angle[X] = acc_angle[X];
    gyro_angle[Y] = acc_angle[Y];
 * Reset motors' pulse length to 1000µs to totally stop them.
void stopAll() {
    pulse_length_esc1 = 1000;
    pulse_length_esc2 = 1000;
    pulse_length_esc3 = 1000;
 * Reset all PID controller's variables.
void resetPidController() {
    errors[YAW]   = 0;
    errors[PITCH] = 0;
    errors[ROLL]  = 0;
    error_sum[YAW]   = 0;
    error_sum[PITCH] = 0;
    error_sum[ROLL]  = 0;
    previous_error[YAW]   = 0;
    previous_error[PITCH] = 0;
    previous_error[ROLL]  = 0;
 * Calculate PID set points on axis YAW, PITCH, ROLL
void calculateSetPoints() {
    pid_set_points[YAW]   = calculateYawSetPoint(pulse_length[mode_mapping[YAW]], pulse_length[mode_mapping[THROTTLE]]);
    pid_set_points[PITCH] = calculateSetPoint(measures[PITCH], pulse_length[mode_mapping[PITCH]]);
    pid_set_points[ROLL]  = calculateSetPoint(measures[ROLL], pulse_length[mode_mapping[ROLL]]);
 * Calculate the PID set point in °/s
 * @param float angle         Measured angle (in °) on an axis
 * @param int   channel_pulse Pulse length of the corresponding receiver channel
 * @return float
float calculateSetPoint(float angle, int channel_pulse) {
    float level_adjust = angle * 15; // Value 15 limits maximum angle value to ±32.8°
    float set_point    = 0;
    // Need a dead band of 16µs for better result
    if (channel_pulse > 1508) {
        set_point = channel_pulse - 1508;
    } else if (channel_pulse <  1492) {
        set_point = channel_pulse - 1492;
    set_point -= level_adjust;
    set_point /= 3;
    return set_point;
 * Calculate the PID set point of YAW axis in °/s
 * @param int yaw_pulse      Receiver pulse length of yaw's channel
 * @param int throttle_pulse Receiver pulse length of throttle's channel
 * @return float
float calculateYawSetPoint(int yaw_pulse, int throttle_pulse) {
    // Do not yaw when turning off the motors
    if (throttle_pulse > 1050) {
        // There is no notion of angle on this axis as the quadcopter can turn on itself
        set_point = calculateSetPoint(0, yaw_pulse);
    return set_point;
 * Compensate battery drop applying a coefficient on output values
void compensateBatteryDrop() {
    if (isBatteryConnected()) {
        pulse_length_esc1 += pulse_length_esc1 * ((1240 - battery_voltage) / (float) 3500);
        pulse_length_esc2 += pulse_length_esc2 * ((1240 - battery_voltage) / (float) 3500);
        pulse_length_esc3 += pulse_length_esc3 * ((1240 - battery_voltage) / (float) 3500);
        pulse_length_esc4 += pulse_length_esc4 * ((1240 - battery_voltage) / (float) 3500);
        Serial.print(battery_voltage);
 * Read battery voltage & return whether the battery seems connected
 * @return boolean
bool isBatteryConnected() {
    // Reduce noise with a low-pass filter (10Hz cutoff frequency)
    battery_voltage = battery_voltage * 0.92 + (analogRead(0) + 65) * 0.09853;
    return battery_voltage < 1240 && battery_voltage > 800;
 * This Interrupt Sub Routine is called each time input 8, 9, 10 or 11 changed state.
 * Read the receiver signals in order to get flight instructions.
 * This routine must be as fast as possible to prevent main program to be messed up.
 * The trick here is to use port registers to read pin state.
 * Doing (PINB & B00000001) is the same as digitalRead(8) with the advantage of using less CPU loops.
 * It is less convenient but more efficient, which is the most important here.
 * @see https://www.arduino.cc/en/Reference/PortManipulation
 * @see https://www.firediy.fr/article/utiliser-sa-radiocommande-avec-un-arduino-drone-ch-6
ISR(PCINT0_vect) {
        current_time = micros();
        // Channel 1 -------------------------------------------------
        if (PINB & B00000001) {                                        // Is input 8 high ?
            if (previous_state[CHANNEL1] == LOW) {                     // Input 8 changed from 0 to 1 (rising edge)
                previous_state[CHANNEL1] = HIGH;                       // Save current state
                timer[CHANNEL1] = current_time;                        // Save current time
        } else if (previous_state[CHANNEL1] == HIGH) {                 // Input 8 changed from 1 to 0 (falling edge)
            previous_state[CHANNEL1] = LOW;                            // Save current state
            pulse_length[CHANNEL1] = current_time - timer[CHANNEL1];   // Calculate pulse duration & save it
        // Channel 2 -------------------------------------------------
        if (PINB & B00000010) {                                        // Is input 9 high ?
            if (previous_state[CHANNEL2] == LOW) {                     // Input 9 changed from 0 to 1 (rising edge)
                previous_state[CHANNEL2] = HIGH;                       // Save current state
                timer[CHANNEL2] = current_time;                        // Save current time
        } else if (previous_state[CHANNEL2] == HIGH) {                 // Input 9 changed from 1 to 0 (falling edge)
            previous_state[CHANNEL2] = LOW;                            // Save current state
            pulse_length[CHANNEL2] = current_time - timer[CHANNEL2];   // Calculate pulse duration & save it
        // Channel 3 -------------------------------------------------
        if (PINB & B00000100) {                                        // Is input 10 high ?
            if (previous_state[CHANNEL3] == LOW) {                     // Input 10 changed from 0 to 1 (rising edge)
                previous_state[CHANNEL3] = HIGH;                       // Save current state
                timer[CHANNEL3] = current_time;                        // Save current time
        } else if (previous_state[CHANNEL3] == HIGH) {                 // Input 10 changed from 1 to 0 (falling edge)
            previous_state[CHANNEL3] = LOW;                            // Save current state
            pulse_length[CHANNEL3] = current_time - timer[CHANNEL3];   // Calculate pulse duration & save it
        // Channel 4 -------------------------------------------------
        if (PINB & B00001000) {                                        // Is input 11 high ?
            if (previous_state[CHANNEL4] == LOW) {                     // Input 11 changed from 0 to 1 (rising edge)
                previous_state[CHANNEL4] = HIGH;                       // Save current state
                timer[CHANNEL4] = current_time;                        // Save current time
        } else if (previous_state[CHANNEL4] == HIGH) {                 // Input 11 changed from 1 to 0 (falling edge)
            previous_state[CHANNEL4] = LOW;                            // Save current state
            pulse_length[CHANNEL4] = current_time - timer[CHANNEL4];   // Calculate pulse duration & save it
here is the wiring, everything was done correctly, and was working fine before for many trials, the only thing i can think of is that i left the drone on and idle for almost 10 minutes, where the arduino was powering the mpu6050, could that be the cause for the arduino maybe overheating and short circuiting?
thank you all for replying so quickly. again i would buy a new board but i dont have resources or the time right now so i am looking for how i myself can salvage this and finish my project.
The 3.3V are derived from the 5V by another on-board regulator. That one also can be overloaded easily, in addition to the 5V regulator.
Get a multimeter and measure the voltages.
Such a voltage divider is useful with analog or digital signals but not for power.
It's used by many modules (displays...) for data transmission. The bus has SCK, MOSI and MISO signals with SCK also tied to pin 13, the built-in LED.
I did exactly that just now, and getting a voltage of about 4.5V from 5V to GND and a voltage of about 3.28V from 3.3V to GND. This is when the arduino is connected to the laptop by USB cable.
So what exactly would you say is keeping the LED light on?
Please do let me know what other steps I can take to diagnose and possibly fix the issue. Thanks.
What if disconnected?
Remove everything connected to the Arduino. If it still gets hot then replace it. Otherwise add more connections until the Arduino gets hot and report.
the atmega328p gets hot, even when nothing is connect to the arduino
im not sure what you mean? its off when its disconnected so...?
Then replace it.
So nothing at all can be done about it?
So. The title should be pretty self explanatory, im looking for good resources in order to understand how to build a drone from scratch. I'm also trying to get a hand on the code behind all these projects and keep to a tight budget.
I have all the required parts, but I need some place to get guidance for these things. Any help would be appreciated.
DogPile.com
Thanks for the clolourfu picture but some more is requested. Real schematics is the prefered presentation.
Powering the UNO via Vin the 5 volt pint is very, very unsafe to use as the internal 5 volt converter can be overloaded, overheat or even damaged.
What is the little bord below the UNO?
What is the little board above the UNO?
What is the capacity for delivering current from the LiPo's?
Datasheets would be helpful.
mpu6050 - https://invensense.tdk.com/wp-content/uploads/2015/02/MPU-6000-Datasheet1.pdf - datasheet
it is a 2200mAh battery 30C 11.1 nominal voltage
it is the rf reciever - it is not getting powered by the uno though - it is from the ESCs BEC.
im not sure what this means, sorry for being a total noob, but please bear with me
Why do you think that this particular wiring would cause your arduino to go down?
That is the energy content and it does not tell how many Amps it delivers.
We are all new in the beginning.
A Fritzing picture like You posted You can give to a half blind completely ignorant person and say: "Wire this", and it will work. For engineering analyzis it's hopeless to use.
The logic of pins, told in datasheets, schematics, show the function of the pin.
Wire positions, showed on the picture, are hardly handled by people having those parts in the hand. The overview is lost.
Do some search in forum on "Schematics"! Often pen and paper works well. One important thing is the name of the pins.
I thought it would work, and for quite a while it did, but one fine day it stopped working, so trying to figure out what i can do to avoid that. im speaking from experience (even if a single incident) so trying to solve all possible problems. this didnt seem problematic so went with that. tested for a while without the mpu6050, but while tuning PID and leaving the arduino idle and on for about 5-10 mins it stopped responding.
right
so lets see if ive got this down properly
ESC1/2/3/4 Control Pins to Digital Pins 4,5,6,7 respectively
Reciever Channel 1/2/3/4 to Digital Pins 8,9,10,11 respectively
Recieiver GND to Arduino GND
LiPo Positive Terminal to Vin
ESC all grounded to Arduino
MPU6050 5V to Arduino 3.3V out
MPU GND to UNO GND
MPU SDA/SCL to Analog Pins 4 and 5 respectively
does this work?
also this works down to a max discharge rate of 66A (capacity into c rating)
sorry for not specifying
also found this for the MPU 6050 - The MPU6050 consumes less than 3.6mA during measurements and only 5μA when idle . - [credit](https:// The MPU6050 consumes less than 3.6mA during measurements and only 5μA when idle.)
thanks to you i realise my mistake, i realise i shouldve looked a little harder before asking
but this dont you think this is a bit underhanded? couldve said it a bit better dont you think? anyways. point taken.
