I find making up a set of DVM meter cables as seen below can make meter testing easier.
Make up one banana plug cable (about 2 feet).
Solder male pin connectors to the testing end.
Make up as many probe tip ends as needed, install female pins on the meter side.
Change your probe ends as needed.
That's something I need to do. I actually think I have all the stuff to do it, other than the red shrink-tube.
What I need is ideas on organizing all the different leads from all the different gear. Jumper wires seem to be a mess, and then there's all the different USB power cables
That might help "a little", but I often have 4 or 5 usb powered devices hooked up, some to the computer, others to a 4 port charger.
Then, while the meter leads you posted are neat, I also have 3 different dvom's, two o-scopes (2 leads ea), a function generator, and a logic analyzer (my fav, with 8 leads).
That's a bunch of wires to keep tidy.
Your pictures have given me an idea for some of the clutter though. Dragging dvom wires from the back of the desk isn't ideal, but putting the dvom up front is in the way too. Perhaps I can wall mount the meters and use leads like you have pictured and bring them through the wire hole in the desk and have a panel up front labelled with the different meters, so I can just plug in the appropriate test lead to the meter I'm using.
It solves some cable storage and allows me to bring the leads from the front of the desk.
As for yours, where's the micro grabbers? How are you going to grab a pin on a SOIC 16?
LarryD:
Thought this might be of interest to some.
I have a set that does the same , got them from maplins i think.
V useful, also extension lead is available.
