Hello everyone,
I'm 16, I'm french and I am making a switch panel to act as a keyboard with an arduino pro micro to flight simulator on PC an XBOX. I want to use 16 switches with an off/on position connected to an CD74HC4067 and 3 rotary encoders directly to digital pins. Each switch must write a character when it is turned on, but only once. And each switch must write a character when it is turned off, but only once. About encoders, they must write a character for each step CW and each step CCW. I am a beginner and I'm bad at coding. I am trying to do a prototype with an arduino uno board that send information but not as keyboard key but as serial.print.
I wrote this code on wokwi to try and it's not working very well someone can help me pls ?
#include <light_CD74HC4067.h>
#define inputCLK 4
#define inputDT 5
#define inputCLK1 6
#define inputDT1 7
#define inputCLK2 2
#define inputDT2 3
CD74HC4067 mux(A5, A4, A3, A2);
int currentStateCLK;
int previousStateCLK;
int currentStateCLK1;
int previousStateCLK1;
int currentStateCLK2;
int previousStateCLK2;
int previous[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
const int signal_pin = A1;
int current[16]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
pinMode (signal_pin,INPUT_PULLUP);
pinMode (inputCLK,INPUT);
pinMode (inputDT,INPUT);
pinMode (inputCLK1,INPUT);
pinMode (inputDT1,INPUT);
pinMode (inputCLK2,INPUT);
pinMode (inputDT2,INPUT);
// Setup Serial Monitor
Serial.begin (9600);
// Assign to previousStateCLK variable
previousStateCLK = digitalRead(inputCLK);
previousStateCLK1 = digitalRead(inputCLK1);
previousStateCLK2 = digitalRead(inputCLK2);
// Read the current state of inputCLK
currentStateCLK = digitalRead(inputCLK);
// If the previous and the current state of the inputCLK are different then a pulse has occured
if (currentStateCLK != previousStateCLK){
// If the inputDT state is different than the inputCLK state then
// the encoder is rotating counterclockwise
if (digitalRead(inputDT) != currentStateCLK) {
Serial.println("up");
// Encoder is rotating clockwise
Serial.println("down");
// Update previousStateCLK with the current state
previousStateCLK = currentStateCLK;
currentStateCLK1 = digitalRead(inputCLK1);
// If the previous and the current state of the inputCLK1 are different then a pulse has occured
if (currentStateCLK1 != previousStateCLK1){
// If the inputDT1 state is different than the inputCLK1 state then
if (digitalRead(inputDT1) != currentStateCLK1) {
// Update previousStateCLK1 with the current state
previousStateCLK1 = currentStateCLK1;
currentStateCLK2 = digitalRead(inputCLK2);
// If the previous and the current state of the inputCLK2 are different then a pulse has occured
if (currentStateCLK2 != previousStateCLK2){
// If the inputDT2 state is different than the inputCLK state then
if (digitalRead(inputDT2) != currentStateCLK2) {
// Update previousStateCLK2 with the current state
previousStateCLK2 = currentStateCLK2;
for (byte i = 0; i < 16; i++) {
mux.channel(i);
current[i]= digitalRead(signal_pin); // Read analog value
if(current[i]!= previous[i]){
if(current[i]== 0){
Serial.print(i);
Serial.println(". on");
Serial.print(i);
Serial.println(". off");
previous[i]=current[i];
delay(50);
