Error compiling for board esp32-wroom-da module
This may look like a reopening of another topic with the same name but that one was auto closed without actually explaining how to fix the problem.
this is the standard dump
Arduino: 1.8.19 (Linux), Board: "ESP32-WROOM-DA Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
WARNING: Category '' in library ESP Insights is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
: -c: line 1: unexpected EOF while looking for matching `''
exit status 2
Error compiling for board ESP32-WROOM-DA Module.
option enabled in File -> Preferences.
The longer version can be added
Sorry I should have mentioned this is Debian 12 and IDE 1.18.19
looks like you have missmatched ", i.e. a missing terminator " to match opening "
try Tools>AutoFormat it may help
Did you try that?
This error happens on any ESP32-WROOM-DA target in my Debian box on IDE 1.8.19. They do work on windows. So I may Be in the wrong forum
The Verbose error dump is 28 pages long. Also it works in other environments so I'm starting to think this is a Debian 12 problem
This is the verbose 28 page dump
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/jonathan/.arduino15/packages -tools /usr/share/arduino/hardware/tools/avr -tools /home/jonathan/.arduino15/packages -libraries /home/jonathan/Arduino/libraries -fqbn=esp32:esp32:esp32da:PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path /tmp/arduino_build_543978 -warnings=none -build-cache /tmp/arduino_cache_191349 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/home/jonathan/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/home/jonathan/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.mkspiffs.path=/home/jonathan/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/jonathan/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=/home/jonathan/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/home/jonathan/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.mklittlefs.path=/home/jonathan/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/jonathan/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.dfu-util.path=/home/jonathan/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/home/jonathan/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -verbose /home/jonathan/Documents/arduino/esp32test/esp32test.ino
arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/jonathan/.arduino15/packages -tools /usr/share/arduino/hardware/tools/avr -tools /home/jonathan/.arduino15/packages -libraries /home/jonathan/Arduino/libraries -fqbn=esp32:esp32:esp32da:PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10819 -build-path /tmp/arduino_build_543978 -warnings=none -build-cache /tmp/arduino_cache_191349 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/home/jonathan/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/home/jonathan/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/home/jonathan/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.mkspiffs.path=/home/jonathan/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/jonathan/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=/home/jonathan/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/home/jonathan/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.mklittlefs.path=/home/jonathan/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/jonathan/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.dfu-util.path=/home/jonathan/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/home/jonathan/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -verbose /home/jonathan/Documents/arduino/esp32test/esp32test.ino
Using board 'esp32da' from platform in folder: /home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10
Using core 'esp32' from platform in folder: /home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10
bash -c "[ ! -f "/home/jonathan/Documents/arduino/esp32test"/partitions.csv ] || cp -f "/home/jonathan/Documents/arduino/esp32test"/partitions.csv "/tmp/arduino_build_543978"/partitions.csv"
bash -c "[ -f "/tmp/arduino_build_543978"/partitions.csv ] || [ ! -f "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da"/partitions.csv ] || cp "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da"/partitions.csv "/tmp/arduino_build_543978"/partitions.csv"
bash -c "[ -f "/tmp/arduino_build_543978"/partitions.csv ] || cp "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10"/tools/partitions/default.csv "/tmp/arduino_build_543978"/partitions.csv"
bash -c "[ -f "/home/jonathan/Documents/arduino/esp32test"/bootloader.bin ] && cp -f "/home/jonathan/Documents/arduino/esp32test"/bootloader.bin "/tmp/arduino_build_543978"/esp32test.ino.bootloader.bin || ( [ -f "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da"/bootloader.bin ] && cp "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da"/bootloader.bin "/tmp/arduino_build_543978"/esp32test.ino.bootloader.bin || python3 "/home/jonathan/.arduino15/packages/esp32/tools/esptool_py/4.5.1"/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "/tmp/arduino_build_543978"/esp32test.ino.bootloader.bin "/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32"/bin/bootloader_qio_80m.elf )"
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
bash -c "[ ! -f "/home/jonathan/Documents/arduino/esp32test"/build_opt.h ] || cp -f "/home/jonathan/Documents/arduino/esp32test"/build_opt.h "/tmp/arduino_build_543978"/build_opt.h"
bash -c "[ -f "/tmp/arduino_build_543978"/build_opt.h ] || touch "/tmp/arduino_build_543978"/build_opt.h"
bash -c ": > /tmp/arduino_build_543978/file_opts"
Detecting libraries used...
"/home/jonathan/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS   "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/newlib/platform_include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/port/xtensa/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/heap/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/log/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps/sntp" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/lwip/src/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/platform_port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/soc" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/public_compat" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_pm/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ringbuf/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/vfs/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_wifi/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_event/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_netif/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_eth/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcpip_adapter/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ipc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_trace/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_timer/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_update/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spi_flash/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bootloader_support/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nvs_flash/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/pthread/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ieee802154/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/console" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/asio/asio/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/osi/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/include/esp32/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/api/include/api" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/inclu
de" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cbor/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/unity/src" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cmock/CMock/src" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/libcoap/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_adc_cal/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hid/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcp_transport/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_client/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_server/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_ota/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_server/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/interface" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/common" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/security" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/transports" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mdns/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_local_ctrl/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/sdmmc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_serial_slave_link/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_websocket_client/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/expat/expat/lib" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/port/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wear_levelling/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/diskio" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/vfs" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/src" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/jsmn/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json/cJSON" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/port_include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/openssl/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/perfmon/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spiffs/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ulp/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wifi_provisioning/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rmaker_common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_diagnostics/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rtc_store/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_insights/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_generator/upstream" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_schedule/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rainmaker/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/gpio_button/button/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/qrcode/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ws2812_led" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_littlefs/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/tool" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/typedef" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/image" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/math" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/nn" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/layer" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/detect" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/driver/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/conversions/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include"
 "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1  -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_543978/build_opt.h" "@/tmp/arduino_build_543978/file_opts" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da" "/tmp/arduino_build_543978/sketch/esp32test.ino.cpp" -o "/dev/null"
 "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1  -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_543978/build_opt.h" "@/tmp/arduino_build_543978/file_opts" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da" "/tmp/arduino_build_543978/sketch/esp32test.ino.cpp" -o "/tmp/arduino_build_543978/preproc/ctags_target_for_gcc_minus_e.cpp"
Generating function prototypes...
"/usr/bin/arduino-ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_543978/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
 "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_WROOM_DA -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_WROOM_DA" -DARDUINO_VARIANT="esp32da" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1  -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_543978/build_opt.h" "@/tmp/arduino_build_543978/file_opts" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/jonathan/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/esp32da" "/tmp/arduino_build_543978/sketch/esp32test.ino.cpp" -o "/tmp/arduino_build_543978/sketch/esp32test.ino.cpp.o"
Compiling libraries...
Compiling core...
bash -c "echo '-DARDUINO_CORE_BUILD' > /tmp/arduino_build_543978/file_opts"
exit status 2
I am getting the same error for the same board. When I open the serial monitor I can see the board is happily talking with my pc, but when I try to compile any sketch(including example ones) I get the exact same errors. For reference, I'm using PopOS 22.04.
Arduino: 1.8.19 (Linux), Board: "NodeMCU-32S, 80MHz, 921600, None, Disabled"
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/sava/.arduino15/packages -hardware /home/sava/Arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -tools /home/sava/.arduino15/packages -libraries /home/sava/Arduino/libraries -fqbn=esp32:esp32:nodemcu-32s:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_783376 -warnings=none -build-cache /tmp/arduino_cache_892285 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/home/sava/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/sava/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mklittlefs.path=/home/sava/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/sava/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.dfu-util.path=/home/sava/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/home/sava/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/home/sava/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/home/sava/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.esptool_py.path=/home/sava/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/home/sava/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -verbose /home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead/AnalogRead.ino
arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/sava/.arduino15/packages -hardware /home/sava/Arduino/hardware -tools /usr/share/arduino/hardware/tools/avr -tools /home/sava/.arduino15/packages -libraries /home/sava/Arduino/libraries -fqbn=esp32:esp32:nodemcu-32s:FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_783376 -warnings=none -build-cache /tmp/arduino_cache_892285 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=/home/sava/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/home/sava/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mklittlefs.path=/home/sava/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/home/sava/.arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.dfu-util.path=/home/sava/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=/home/sava/.arduino15/packages/arduino/tools/dfu-util/0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=/home/sava/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=/home/sava/.arduino15/packages/esp32/tools/openocd-esp32/v0.11.0-esp32-20221026 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=/home/sava/.arduino15/packages/esp32/tools/riscv32-esp-elf-gdb/11.2_20220823 -prefs=runtime.tools.esptool_py.path=/home/sava/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=/home/sava/.arduino15/packages/esp32/tools/esptool_py/4.5.1 -verbose /home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead/AnalogRead.ino
Using board 'nodemcu-32s' from platform in folder: /home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10
Using core 'esp32' from platform in folder: /home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10
bash -c "[ ! -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/partitions.csv ] || cp -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/partitions.csv "/tmp/arduino_build_783376"/partitions.csv"
bash -c "[ -f "/tmp/arduino_build_783376"/partitions.csv ] || [ ! -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s"/partitions.csv ] || cp "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s"/partitions.csv "/tmp/arduino_build_783376"/partitions.csv"
bash -c "[ -f "/tmp/arduino_build_783376"/partitions.csv ] || cp "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10"/tools/partitions/default.csv "/tmp/arduino_build_783376"/partitions.csv"
bash -c "[ -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/bootloader.bin ] && cp -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/bootloader.bin "/tmp/arduino_build_783376"/AnalogRead.ino.bootloader.bin || ( [ -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s"/bootloader.bin ] && cp "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s"/bootloader.bin "/tmp/arduino_build_783376"/AnalogRead.ino.bootloader.bin || python3 "/home/sava/.arduino15/packages/esp32/tools/esptool_py/4.5.1"/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "/tmp/arduino_build_783376"/AnalogRead.ino.bootloader.bin "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32"/bin/bootloader_dio_80m.elf )"
esptool.py v4.5.1
bash -c "[ ! -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/build_opt.h ] || cp -f "/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/libraries/ESP32/examples/AnalogRead"/build_opt.h "/tmp/arduino_build_783376"/build_opt.h"
bash -c "[ -f "/tmp/arduino_build_783376"/build_opt.h ] || touch "/tmp/arduino_build_783376"/build_opt.h"
bash -c ": > /tmp/arduino_build_783376/file_opts"
"/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS   "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/newlib/platform_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/port/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/heap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/log/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps/sntp" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/lwip/src/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/platform_port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/public_compat" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_pm/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ringbuf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/vfs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_wifi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_event/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_netif/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_eth/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcpip_adapter/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ipc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_trace/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_timer/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_update/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spi_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bootloader_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nvs_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/pthread/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ieee802154/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/console" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/asio/asio/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/osi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cbor/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/unity/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cmock/CMock/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/libcoap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_adc_cal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hid/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcp_transport/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_ota/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/interface" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/common" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/security" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/transports" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mdns/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_local_ctrl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/sdmmc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_serial_slave_link/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_websocket_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/expat/expat/lib" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wear_levelling/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/diskio" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/vfs" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/jsmn/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json/cJSON" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/port_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/openssl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/perfmon/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spiffs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ulp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wifi_provisioning/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rmaker_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_diagnostics/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rtc_store/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_insights/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_generator/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_schedule/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rainmaker/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/gpio_button/button/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/qrcode/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ws2812_led" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_littlefs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/tool" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/typedef" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/image" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/math" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/nn" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/layer" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/detect" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/conversions/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NodeMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0    -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_783376/build_opt.h" "@/tmp/arduino_build_783376/file_opts" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s" "/tmp/arduino_build_783376/sketch/AnalogRead.ino.cpp" -o "/dev/null"
"/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS   "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/newlib/platform_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/port/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/heap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/log/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps/sntp" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/lwip/src/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/platform_port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/public_compat" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_pm/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ringbuf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/vfs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_wifi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_event/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_netif/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_eth/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcpip_adapter/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ipc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_trace/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_timer/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_update/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spi_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bootloader_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nvs_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/pthread/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ieee802154/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/console" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/asio/asio/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/osi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cbor/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/unity/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cmock/CMock/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/libcoap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_adc_cal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hid/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcp_transport/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_ota/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/interface" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/common" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/security" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/transports" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mdns/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_local_ctrl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/sdmmc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_serial_slave_link/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_websocket_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/expat/expat/lib" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wear_levelling/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/diskio" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/vfs" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/jsmn/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json/cJSON" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/port_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/openssl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/perfmon/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spiffs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ulp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wifi_provisioning/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rmaker_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_diagnostics/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rtc_store/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_insights/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_generator/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_schedule/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rainmaker/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/gpio_button/button/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/qrcode/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ws2812_led" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_littlefs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/tool" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/typedef" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/image" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/math" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/nn" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/layer" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/detect" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/conversions/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NodeMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0    -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_783376/build_opt.h" "@/tmp/arduino_build_783376/file_opts" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s" "/tmp/arduino_build_783376/sketch/AnalogRead.ino.cpp" -o "/tmp/arduino_build_783376/preproc/ctags_target_for_gcc_minus_e.cpp"
"/usr/bin/arduino-ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/tmp/arduino_build_783376/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/home/sava/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS   "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/newlib/platform_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/port/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/heap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/log/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/include/apps/sntp" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/lwip/src/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/soc/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/hal/platform_port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rom/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/soc" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_system/port/public_compat" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/xtensa/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/driver/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_pm/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ringbuf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/efuse/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/vfs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_wifi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_event/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_netif/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_eth/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcpip_adapter/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_phy/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_ipc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_trace/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_timer/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/app_update/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spi_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bootloader_support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nvs_flash/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/pthread/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_gdbstub/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ieee802154/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/console" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/asio/asio/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/asio/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/osi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/include/esp32/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cbor/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/unity/unity/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/cmock/CMock/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/coap/libcoap/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_adc_cal/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_hid/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/tcp_transport/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_http_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_ota/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_https_server/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_lcd/interface" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/common" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/security" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/protocomm/include/transports" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mdns/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_local_ctrl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/sdmmc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_serial_slave_link/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_websocket_client/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/expat/expat/lib" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/expat/port/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wear_levelling/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/diskio" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/vfs" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fatfs/src" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/idf_test/include/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/jsmn/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json/cJSON" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/libsodium/port_include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/openssl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/perfmon/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/spiffs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ulp/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/wifi_provisioning/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rmaker_common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_diagnostics/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/rtc_store/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_insights/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_parser/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/json_generator/upstream" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_schedule/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_rainmaker/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/gpio_button/button/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/qrcode/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/ws2812_led" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp_littlefs/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/tool" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/typedef" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/image" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/math" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/nn" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/layer" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/detect" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/driver/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/esp32-camera/conversions/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti  -MMD -c -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NodeMCU_32S -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="NodeMCU_32S" -DARDUINO_VARIANT="nodemcu-32s" -DARDUINO_PARTITION_default  -DESP32 -DCORE_DEBUG_LEVEL=0    -DARDUINO_USB_CDC_ON_BOOT=0 "@/tmp/arduino_build_783376/build_opt.h" "@/tmp/arduino_build_783376/file_opts" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/cores/esp32" "-I/home/sava/.arduino15/packages/esp32/hardware/esp32/2.0.10/variants/nodemcu-32s" "/tmp/arduino_build_783376/sketch/AnalogRead.ino.cpp" -o "/tmp/arduino_build_783376/sketch/AnalogRead.ino.cpp.o"
Compiling libraries...
Compiling core...
bash -c "echo '-DARDUINO_CORE_BUILD' > /tmp/arduino_build_783376/file_opts"
>: -c: line 1: unexpected EOF while looking for matching `''
>: -c: line 2: syntax error: unexpected end of file
exit status 2
Error compiling for board NodeMCU-32S.
I believe I've found the solution. For some reason apt obtained Arduino IDE has problems with the newest esp32 library.
Issue
Solution
This platform.txt file can be found in ~/.arduino15/packages/esp32/hardware/esp32/2.0.10
Automatic fix can be applied with the following command sed -i "s/'-DARDUINO_CORE_BUILD'/-DARDUINO_CORE_BUILD/g" ~/.arduino15/packages/esp32/hardware/esp32/2.0.10/platform.txt
Hope this helped :slight_smile:
Wow
thank you
fixed and amazed
