hey fellas, im having a issue with this code. im getting a error message about noteOn wasnt delcared in the scope, but the odd thing is this code as compiled before. i donno, ive googled around and i havnt come up with anything that really fits my issue, ive seen where people were missing spaces or typo, but ive looked over the code an i am a noob at coding it looks lagit to me. if anyone can help spot something im not seeing that would be great. thanks.
// what midi channel is being sent
// ranges from 0-15
#define drumchan 2
// general midi drum notes
#define note_bassdrum 33
#define note_snaredrum 37 // RED PAD
#define note_hihatclosed 44 // FOOT SWITCH FOR CLOSED HI HAT
#define note_hihatopen 22 // YELLOW CYMBAL, PIN 0
#define note_crash 49 // GREEN CYMBAL.A5
#define note_hitom 48 //
#define note_lowtom 45 //
#define note_floortom 41 //
#define note_ridecym 51 // BLUE CYMBOL A6
// define the pins we use
#define switchAPin 10 //bass pedal, DIGITAL PIN 10
#define switchCPin 2 // hihatclosed pedal, DIGITAL PIN 2???????????????????????
#define piezoAPin 0 //hi hat open pedal, YELLOW CYMBAL, ANALOG PIN 0
#define piezoBPin 1 //hi tom YELLOWA1
#define piezoCPin 2 //snare drum RED A2
#define piezoDPin 3 // low tom BLUE A3
#define piezoEPin 4 // floor tom GREEN A4
#define piezoFPin 5 // GREEEN CYMBAL A5
#define piezoGPin 6 // BLUE CYMBAL A6
#define ledPin 13 // for midi out status
// analog threshold for piezo sensing
#define PIEZOTHRESHOLD1 500 //YELLOW CYMBAL
#define PIEZOTHRESHOLD2 500//YELLOW PAD
#define PIEZOTHRESHOLD3 500//RED PAD
#define PIEZOTHRESHOLD4 500 //BLUE PAD
#define PIEZOTHRESHOLD5 500 //GREEN PAD
#define PIEZOTHRESHOLD6 500 //GREEN CYMBAL
#define PIEZOTHRESHOLD7 500//BLUE CYMBAL
int switchAState = LOW;
int switchCState = LOW;
int currentSwitchState = LOW;
// variables will change:
int buttonState = 0;
// variable for reading the pushbutton status
int val,t;
pinMode(switchAPin, INPUT);
pinMode(switchCPin, INPUT);
digitalWrite(switchAPin, HIGH); // turn on internal pullup
digitalWrite(switchCPin, HIGH); // turn on internal pullup
pinMode(ledPin, OUTPUT);
Serial.begin(31250); // set MIDI baud rate
// deal with switchA BASS DRUM
currentSwitchState = digitalRead(switchAPin);
if( currentSwitchState == LOW && switchAState == HIGH ) // push
noteOn(drumchan, note_bassdrum, 100);
if( currentSwitchState == HIGH && switchAState == LOW ) // release
noteOff(drumchan, note_bassdrum, 0);
switchAState = currentSwitchState;
// deal with HI HAT CLOSED FOOT PEDLE
currentSwitchState = digitalRead(switchCPin);
if( currentSwitchState == LOW && switchCState == HIGH ) // push
noteOn(drumchan, note_hihatclosed, 100);
if( currentSwitchState == HIGH && switchCState == LOW ) // release
noteOff(drumchan, note_hihatclosed, 0);
switchCState = currentSwitchState;
// 1 deal with first piezo, HI HAT OPEN, YELLOW CYMBAL
val = analogRead(piezoAPin);
if( val >= PIEZOTHRESHOLD1 ) {
t=0;
while(analogRead(piezoAPin) >= PIEZOTHRESHOLD1/2) {
t++;
noteOn(drumchan,note_hihatopen, t*2);
delay(t);
noteOff(drumchan,note_hihatopen,0);
// 2 deal with second piezos, HITOM, YELLOW PAD
val = analogRead(piezoBPin);
if( val >= PIEZOTHRESHOLD2 ) {
t=0;
while(analogRead(piezoBPin) >= PIEZOTHRESHOLD2/2) {
t++;
noteOn(drumchan,note_hitom, t*2);
delay(t);
noteOff(drumchan,note_hitom,0);
// 3 deal with second piezos,SNARE DRUM RED PAD
val = analogRead(piezoCPin);
if( val >= PIEZOTHRESHOLD3 ) {
t=0;
while(analogRead(piezoCPin) >= PIEZOTHRESHOLD3/2) {
t++;
noteOn(drumchan,note_snaredrum, t*2);
delay(t);
noteOff(drumchan,note_snaredrum,0);
// 4 deal with second piezos, LOW TOM BLUE PAD
val = analogRead(piezoDPin);
if( val >= PIEZOTHRESHOLD4 ) {
t=0;
while(analogRead(piezoDPin) >= PIEZOTHRESHOLD4/2) {
t++;
noteOn(drumchan,note_lowtom, t*2);
delay(t);
noteOff(drumchan,note_lowtom,0);
// 5 deal with second piezos, FLOOR TOM GREEN PAD
val = analogRead(piezoEPin);
if( val >= PIEZOTHRESHOLD5 ) {
t=0;
while(analogRead(piezoEPin) >= PIEZOTHRESHOLD5/2) {
t++;
noteOn(drumchan,note_floortom, t*2);
delay(t);
noteOff(drumchan,note_floortom,0);
// 6 deal with second piezos,CRASH GREEN CYMBAL
val = analogRead(piezoFPin);
if( val >= PIEZOTHRESHOLD6 ) {
t=0;
while(analogRead(piezoFPin) >= PIEZOTHRESHOLD6/2) {
t++;
noteOn(drumchan,note_crash, t*2);
delay(t);
noteOff(drumchan,note_crash,0);
// 7 deal with 7TH piezos,BLUE CYMBAL
val = analogRead(piezoGPin);
if( val >= PIEZOTHRESHOLD7 ) {
t=0;
while(analogRead(piezoGPin) >= PIEZOTHRESHOLD7/2) {
t++;
noteOn(drumchan,note_ridecym, t*2);
delay(t);
noteOff(drumchan,note_ridecym,0);
// Send a MIDI note-on message. Like pressing a piano key
// channel ranges from 0-15
void noteOn(byte channel, byte note, byte velocity) {
midiMsg( (0x90 | channel), note, velocity);
// Send a MIDI note-off message. Like releasing a piano key
void noteOff(byte channel, byte note, byte velocity) {
midiMsg( (0x80 | channel), note, velocity);
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
digitalWrite(ledPin,HIGH); // indicate we're sending MIDI data
Serial.write(cmd);
Serial.write(data1);
Serial.write(data2);
digitalWrite(ledPin,LOW);
the error is noteOns and the noteOffs are not declared in the scope.
any help would be appreciated.
