my Arduino was working just fine until yesterday. Whenever I try to upload a program, I get this message:
"avrdude: stk500_recv(): programmer is not responding"
When I upload or reset the Arduino, only L blinks. TX and RX don't blink at all. I am concerned that it's a hardware problem.
I looked up solutions for this problem and found bunch of other people who had the same problem but either didn't post the solution, didn't find a solution, or I couldn't follow up with the solution.
I tried resetting the Arduino, restart the computer, uploading another program, changing the USB port, and made sure I chose the write board (UNO), but none worked.
Thank you for the quick reply!
I am struggling a bit with upgrading the firmware. So am I supposed to download the folders from Github and replace the ones I have on my mac? or only the hex file that suits the Arduino I have?
I am not sure how to download them either.
Wjdan94:
Wjdan94:
In your browser, select File->Save as... and save the page as a file called Arduino-usbserial-uno.hex
I did it as explained, but unfortunately did not work.
I uninstalled the application and started all over again but did not work either.
what is odd is that, after I replace the hex file and restart the application and upload the Blink code, it says "Done Uploading" with "avrdude: stk500_recv(): programmer is not responding" ! I get both messages only the first time I upload. However, after that, it goes back to the same old problem "Problem uploading to board ..." "avrdude: stk500_recv(): programmer is not responding"
Also, another odd thing is that TX and RX never blinked since I got the problem two days ago.
