When I tried to verify this:
`#include <MUIU8g2.h>
#include <U8g2lib.h>
#include <U8x8lib.h>
int Hipofisis 22
int Pineal 24
int Hipotalamo 26
int Tiroides 28
int Paratiroides 30
int Suprarrenal 31
int Pancreas 32
int Ovarios 33
int Testiculos 34
pinMode(Hipofisis, INPUT_PULLUP);
pinMode(Pineal, INPUT_PULLUP);
pinMode(Hipotalamo, INPUT_PULLUP);
pinMode(Tiroides, INPUT_PULLUP);
pinMode(Paratiroides, INPUT_PULLUP);
pinMode(Suprarrenal, INPUT_PULLUP);
pinMode(Pancreas, INPUT_PULLUP);
pinMode(Ovarios, INPUT_PULLUP);
pinMode(Testiculos, INPUT_PULLUP);
bool U8G2::begin
(It's part of a bigger proyect that I'm doing)
I get this:
In file included from /home/diegt/Arduino/libraries/U8g2/src/MUIU8g2.h:44:0,
from /tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:1:
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:127:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_get_x(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:128:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_get_y(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:129:1: error: 'u8g2_t' does not name a type; did you mean 'U8G2_H'?
u8g2_t *mui_get_U8g2(mui_t *ui);
U8G2_H
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:131:42: error: 'u8g2_uint_t' has not been declared
void mui_u8g2_draw_button_utf(mui_t *ui, u8g2_uint_t flags, u8g2_uint_t width, u8g2_uint_t padding_h, u8g2_uint_t padding_v, const char *text);
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:131:61: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:131:80: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:131:103: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:132:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_u8g2_get_pi_flags(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:133:41: error: 'u8g2_uint_t' has not been declared
void mui_u8g2_draw_button_pi(mui_t *ui, u8g2_uint_t width, u8g2_uint_t padding_h, const char *text);
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:133:60: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:134:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_u8g2_get_fi_flags(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:135:41: error: 'u8g2_uint_t' has not been declared
void mui_u8g2_draw_button_fi(mui_t *ui, u8g2_uint_t width, u8g2_uint_t padding_h, const char *text);
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:135:60: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:136:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_u8g2_get_pf_flags(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:137:41: error: 'u8g2_uint_t' has not been declared
void mui_u8g2_draw_button_pf(mui_t *ui, u8g2_uint_t width, u8g2_uint_t padding_h, const char *text);
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:137:60: error: 'u8g2_uint_t' has not been declared
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:138:1: error: 'u8g2_uint_t' does not name a type; did you mean 'u8g2_u8toa'?
u8g2_uint_t mui_u8g2_get_if_flags(mui_t *ui);
u8g2_u8toa
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:139:41: error: 'u8g2_uint_t' has not been declared
void mui_u8g2_draw_button_if(mui_t *ui, u8g2_uint_t width, u8g2_uint_t padding_h, const char *text);
/home/diegt/Arduino/libraries/U8g2/src/clib/mui_u8g2.h:139:60: error: 'u8g2_uint_t' has not been declared
In file included from /tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:1:0:
/home/diegt/Arduino/libraries/U8g2/src/MUIU8g2.h:53:18: error: expected ')' before '&' token
MUIU8G2(U8G2 &u8g2, fds_t *fds, muif_t *muif_list, size_t muif_cnt) {
/home/diegt/Arduino/libraries/U8g2/src/MUIU8g2.h:56:16: error: 'U8G2' has not been declared
void begin(U8G2 &u8g2, fds_t *fds, muif_t *muif_list, size_t muif_cnt) {
/home/diegt/Arduino/libraries/U8g2/src/MUIU8g2.h: In member function 'void MUIU8G2::begin(int&, fds_t*, muif_t*, size_t)':
/home/diegt/Arduino/libraries/U8g2/src/MUIU8g2.h:57:35: error: request for member 'getU8g2' in 'u8g2', which is of non-class type 'int'
mui_Init(&mui, (void *)u8g2.getU8g2(), fds, muif_list, muif_cnt);
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino: At global scope:
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:5:15: error: expected initializer before numeric constant
int Hipofisis 22
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino: In function 'void setup()':
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:18:11: error: 'Hipofisis' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:19:11: error: 'Pineal' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:20:11: error: 'Hipotalamo' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:21:11: error: 'Tiroides' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:22:11: error: 'Paratiroides' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:23:11: error: 'Suprarrenal' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:24:11: error: 'Pancreas' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:25:11: error: 'Ovarios' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:26:11: error: 'Testiculos' was not declared in this scope
/tmp/.arduinoIDE-unsaved2023322-14096-16go8qu.ja4f/sketch_apr22a/sketch_apr22a.ino:28:1: error: qualified-id in declaration before '}' token
exit status 1
Compilation error: expected initializer before numeric constant
What happened?
