ESP-32 Hard resetting for infinity after uploading
my newly bought ESP-32 Wrover E (or Wrover Dev, there are two labels saying different things) keeps persisting on "Hard Resetting through the RTS pin." right after uploading the code. The output is in italian so beware?
Lo sketch usa 1506025 byte (45%) dello spazio disponibile per i programmi. Il massimo è 3342336 byte.
Le variabili globali usano 70216 byte (21%) di memoria dinamica, lasciando altri 257464 byte liberi per le variabili locali. Il massimo è 327680 byte.
esptool.py v4.5.1
Serial port COM7
Connecting....
Chip is ESP32-D0WDQ6 (revision v1.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 08:b6:1f:8e:71:00
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00181fff...
Compressed 18992 bytes to 13112...
Writing at 0x00001000... (100 %)
Wrote 18992 bytes (13112 compressed) at 0x00001000 in 0.3 seconds (effective 542.3 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 114...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (114 compressed) at 0x00008000 in 0.0 seconds (effective 771.2 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 1330.0 kbit/s)...
Compressed 1511776 bytes to 986854...
Writing at 0x00010000... (1 %)
Writing at 0x0001432b... (3 %)
Writing at 0x0001a938... (4 %)
Writing at 0x00026670... (6 %)
Writing at 0x0002c35c... (8 %)
Writing at 0x00030795... (9 %)
Writing at 0x00034ada... (11 %)
Writing at 0x00039b01... (13 %)
Writing at 0x0003e70a... (14 %)
Writing at 0x0004331c... (16 %)
Writing at 0x00047ec4... (18 %)
Writing at 0x0004cccb... (19 %)
Writing at 0x00051640... (21 %)
Writing at 0x00055a6d... (22 %)
Writing at 0x00059eb1... (24 %)
Writing at 0x0005e1de... (26 %)
Writing at 0x000623ba... (27 %)
Writing at 0x000667ce... (29 %)
Writing at 0x0006ab19... (31 %)
Writing at 0x000728f3... (32 %)
Writing at 0x00085fdd... (34 %)
Writing at 0x000915c4... (36 %)
Writing at 0x00096f55... (37 %)
Writing at 0x0009c5e1... (39 %)
Writing at 0x000a1bc2... (40 %)
Writing at 0x000a6fd3... (42 %)
Writing at 0x000ac30f... (44 %)
Writing at 0x000b1579... (45 %)
Writing at 0x000b694b... (47 %)
Writing at 0x000bbcd3... (49 %)
Writing at 0x000c0f2f... (50 %)
Writing at 0x000c6489... (52 %)
Writing at 0x000cd100... (54 %)
Writing at 0x000d3eac... (55 %)
Writing at 0x000db81c... (57 %)
Writing at 0x000e19b8... (59 %)
Writing at 0x000e7342... (60 %)
Writing at 0x000ec70d... (62 %)
Writing at 0x000f1b28... (63 %)
Writing at 0x000f7876... (65 %)
Writing at 0x000fcec1... (67 %)
Writing at 0x001021bc... (68 %)
Writing at 0x001075ad... (70 %)
Writing at 0x0010ca10... (72 %)
Writing at 0x00111fea... (73 %)
Writing at 0x00117759... (75 %)
Writing at 0x0011d62e... (77 %)
Writing at 0x00123040... (78 %)
Writing at 0x00129e17... (80 %)
Writing at 0x00133b6b... (81 %)
Writing at 0x0013aa29... (83 %)
Writing at 0x00142c37... (85 %)
Writing at 0x00149bb9... (86 %)
Writing at 0x00151eb1... (88 %)
Writing at 0x0015b3aa... (90 %)
Writing at 0x00162b49... (91 %)
Writing at 0x00167cc3... (93 %)
Writing at 0x0016d68f... (95 %)
Writing at 0x00173075... (96 %)
Writing at 0x0017a0e0... (98 %)
Writing at 0x0017fafd... (100 %)
Wrote 1511776 bytes (986854 compressed) at 0x00010000 in 13.2 seconds (effective 917.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
So i tried having a look at the serial plotter and it says this:
ets Jun  8 2016 00:22:57
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
(time is not set correctly, it's not 2016)
It keeps printing this. i tried uploading sketch after sketch, i tried updating esptool.py 4 times. What can i do? for more info, the camera is OV2640.
Show a screen dump of the "Tools" menu in the IDE so we can see what board you have selected and the configuration.
The date you see is probably the date of the software release.
Here it is!
OK. Try disconnecting the camera and anything else to see if that changes the error message. Try also loading just the "Blink" sketch to see if that works.
It is possible that you have selected a board or configuration settings which don't match your device/application or that you have used pins intended for the exclusive use of the flash memory.
Ok, so i have disconnected the camera from the board and retried uploading the code. (the code in question is
#include "esp_camera.h"
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
//            Ensure ESP32 Wrover Module or other board with PSRAM is selected
//            Partial images will be transmitted if image exceeds buffer size
//            You must select partition scheme from the board menu that has at least 3MB APP space.
//            Face Recognition is DISABLED for ESP32 and ESP32-S2, because it takes up from 15
//            seconds to process single frame. Face Detection is ENABLED if PSRAM is enabled as well
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
#define CAMERA_MODEL_ESP32_CAM_BOARD // Has PSRAM
//#define CAMERA_MODEL_ESP32S3_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
//#define CAMERA_MODEL_M5STACK_UNITCAM // No PSRAM
//#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
//#define CAMERA_MODEL_XIAO_ESP32S3 // Has PSRAM
// ** Espressif Internal Boards **
//#define CAMERA_MODEL_ESP32_CAM_BOARD
//#define CAMERA_MODEL_ESP32S2_CAM_BOARD
//#define CAMERA_MODEL_ESP32S3_CAM_LCD
//#define CAMERA_MODEL_DFRobot_FireBeetle2_ESP32S3 // Has PSRAM
//#define CAMERA_MODEL_DFRobot_Romeo_ESP32S3 // Has PSRAM
#include "camera_pins.h"
// Enter your WiFi credentials
const char* ssid = "blank";
const char* password = "blank";
void startCameraServer();
void setupLedFlash(int pin);
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sccb_sda = SIOD_GPIO_NUM;
  config.pin_sccb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.frame_size = FRAMESIZE_UXGA;
  config.pixel_format = PIXFORMAT_JPEG; // for streaming
  //config.pixel_format = PIXFORMAT_RGB565; // for face detection/recognition
  config.grab_mode = CAMERA_GRAB_WHEN_EMPTY;
  config.fb_location = CAMERA_FB_IN_PSRAM;
  config.jpeg_quality = 12;
  config.fb_count = 1;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(config.pixel_format == PIXFORMAT_JPEG){
    if(psramFound()){
      config.jpeg_quality = 10;
      config.fb_count = 2;
      config.grab_mode = CAMERA_GRAB_LATEST;
      // Limit the frame size when PSRAM is not available
      config.frame_size = FRAMESIZE_SVGA;
      config.fb_location = CAMERA_FB_IN_DRAM;
    // Best option for face detection/recognition
    config.frame_size = FRAMESIZE_240X240;
#if CONFIG_IDF_TARGET_ESP32S3
#endif
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  sensor_t * s = esp_camera_sensor_get();
  // initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1); // flip it back
    s->set_brightness(s, 1); // up the brightness just a bit
    s->set_saturation(s, -2); // lower the saturation
  // drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
#if defined(CAMERA_MODEL_ESP32S3_EYE)
  s->set_vflip(s, 1);
#endif
// Setup LED FLash if LED pin is defined in camera_pins.h
#if defined(LED_GPIO_NUM)
  setupLedFlash(LED_GPIO_NUM);
#endif
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("Camera Ready! Use 'http://");
  Serial.print(WiFi.localIP());
  Serial.println("' to connect");
  // Do nothing. Everything is done in another task by the web server
  delay(10000);
and i tried also Blink.ino (the arduino version didn't work so i tried this one instead
 * https://circuits4you.com
 * ESP32 LED Blink Example
 * Board ESP23 DEVKIT V1
 * ON Board LED GPIO 2
#define LED 2
  // Set pin mode
  pinMode(LED,OUTPUT);
  digitalWrite(LED,HIGH);
  digitalWrite(LED,LOW);
and it repeatedly prints out this (on the serial monitor because everything is normal in the normal outpu terminal)
You've selected the forum category: Nano Family/Nano ESP32 for this issue. Maybe that is not appropriate. Anyway, include a link to the actual board you purchased (ESP-32 Wrover ?). It really looks like there is a mismatch between the board you selected in the IDE and the board you actually have. Or maybe just the configuration is wrong, for example configured is 8M flash memory and perhaps the device has only 4M.
I moved your topic to a more appropriate forum category @cruxvelox.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
I don't have ESP32 boards and I'm not familiar with them. But to my knowledge that message is normal; you should have the same message when you upload a simple example sketch like blink.
It is normal.
Just to be clear. The hard reset message is of course normal but the following crash cycle is not. It doesn't even get as far as a core dump:
i bought the actual board from amazon.
https://www.amazon.it/ARCELI-ESP32-WROVER-DEV-Bluetooth-ESP32-CAM-compatibile/dp/B0CP7S6D9Z/ref=sr_1_6?__mk_it_IT=ÅMÅŽÕÑ&crid=3PFCPN7IFA3P3&dib=eyJ2IjoiMSJ9.1qgN4SN_8zjKeU-Z1LIdcBQOnWa8zjjDJLCjMbgzz7YlImkCx2kCzbJQkqXPBJtSj7Qb36MuF9BrNOwGbXXtaElAokOrn1XvUmwAWByyfQ_XToAdMEsMthWzDf3ssbzViZ-B8Ndv0PxbYLzkXN9cNHVApnN4EqZxWUWggadLrMbnCxEF1tSkjgKXjN0tOklhFGFmO69hQQYctTiLzQhPbYmPI0pBGOBH7p9FOOppVTEvNT9IoUAs5rnerOMAmbWydojt5Pc-eV0qnQGecxhLYURoxCdQkV8-i86Hr5gJZYY.rrCMVK8CIBRvIUfoDWsrPSmxdl-FRT2005yhPEg4HmI&dib_tag=se&keywords=esp32+cam+wch.com&qid=1711624342&s=electronics&sprefix=esp32+cam+wch.cn%2Celectronics%2C69&sr=1-6)
It looks like there is a conflict here:
4MB flash:
8MB Flash:
Maybe try this just to see if the blink sketch loads and runs then attempt to find what your camera software requires:
it's got always the same issue i descirbed before, since i bought it the only thing that worked on it was the blink program i pasted before.
UPDATE: i tried pressing and holding down the EN / RST button on the left and it printed out some lines saying this
so i tried putting DIO flash mode
and it works. for now i'm testing it with small programs
but soon i'll do heavier ones
The board in this tutorial looks similar to yours: Getting Started with the Freenove ESP32-Wrover CAM Board | Random Nerd Tutorials
Note also the reader's comments at the end where problems with various clones/fakes are discussed.
Esp32 flash modes are explained here: https://docs.espressif.com/projects/esptool/en/latest/esp32/advanced-topics/spi-flash-modes.html
