ESP-32cam camera probe failed
Hello, i followed this tutorial https://www.youtube.com/watch?v=vdgVQcQ8WrI , im using the OV2640 and i get this error:
E (488) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
Camera init failed!
Failed to initialize the camera!
, this is my slightly modified code so i dont use ap wifi
#include "esp_camera.h"
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
// Camera-related constants
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#define FLASH_PIN 4  // Flashlight pin
const char *ssid = "GVR";
const char *password = "parolawifi123";
AsyncWebServer server(80);
AsyncWebSocket wsCamera("/Camera");
uint32_t cameraClientId = 0;
// HTML for the webpage
const char *htmlPage PROGMEM = R"HTML(
<!DOCTYPE html>
<html>
  <head>
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <style>
      body { font-family: Arial; text-align: center; background-color: #f0f0f0; margin: 0; padding: 0; }
      h2 { color: teal; }
      .slidecontainer { width: 80%; margin: 20px auto; }
      .slider { width: 100%; }
      img { max-width: 100%; height: auto; }
    </style>
  </head>
  <body>
    <h2>Fish Feeding Boat</h2>
    <img id="cameraImage" src="" alt="Video Stream">
    <div class="slidecontainer">
      <p><b>Flashlight Brightness:</b></p>
      <input type="range" min="0" max="255" value="0" class="slider" id="flashlightSlider"
             oninput="adjustFlashlight(this.value)">
    </div>
    <script>
      const cameraSocketUrl = `ws://${window.location.hostname}/Camera;
      let cameraSocket;
      function initCameraSocket() {
        cameraSocket = new WebSocket(cameraSocketUrl);
        cameraSocket.binaryType = "blob";
        cameraSocket.onmessage = function(event) {
          document.getElementById("cameraImage").src = URL.createObjectURL(event.data);
        cameraSocket.onclose = function() {
          setTimeout(initCameraSocket, 2000);
      function adjustFlashlight(brightness) {
        fetch(`/controlFlashlight?value=${brightness}`);
      window.onload = initCameraSocket;
    </script>
  </body>
</html>
)HTML";
// Function to control the flashlight
void controlFlashlight(int brightness) {
  ledcWrite(0, brightness);
// Initialize the camera
bool initCamera() {
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // Frame size and quality
  config.frame_size = FRAMESIZE_QVGA;
  config.jpeg_quality = 10;
  config.fb_count = 2;
  if (esp_camera_init(&config) != ESP_OK) {
    Serial.println("Camera init failed!");
    return false;
  return true;
  pinMode(12, OUTPUT);  // Set digital pin 12 as an output
  digitalWrite(12, HIGH);  // Turn the LED on         //g
  // Setup LEDC for flashlight control
  ledcSetup(0, 5000, 8);
  ledcAttachPin(FLASH_PIN, 0);
  // Initialize camera
  if (!initCamera()) {
    Serial.println("Failed to initialize the camera!");
    while (1);
  WiFi.begin(ssid, password);
  Serial.print("Connecting to WiFi");
    Serial.print(".");
  Serial.print("WiFi connected. IP address: ");
  // WebSocket event handler for camera stream
  wsCamera.onEvent([](AsyncWebSocket *server, AsyncWebSocketClient *client, AwsEventType type, void *arg, uint8_t *data, size_t len) {
    if (type == WS_EVT_CONNECT) {
      cameraClientId = client->id();
    } else if (type == WS_EVT_DISCONNECT) {
      cameraClientId = 0;
  server.addHandler(&wsCamera);
  // Route for the HTML page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
    request->send_P(200, "text/html", htmlPage);
  // Route for controlling the flashlight
  server.on("/controlFlashlight", HTTP_GET, [](AsyncWebServerRequest *request) {
    int brightness = request->getParam("value")->value().toInt();
    controlFlashlight(brightness);
    request->send(200, "text/plain", "Flashlight brightness set");
  server.begin();
  wsCamera.cleanupClients();
  // Capture and send frames if a client is connected
  if (cameraClientId) {
    camera_fb_t *fb = esp_camera_fb_get();
    if (fb) {
      wsCamera.binary(cameraClientId, fb->buf, fb->len);
      esp_camera_fb_return(fb);
Hi @kamikazebaa. Have you tried the "CameraWebServer" example sketch that is provided by the "esp32" boards platform?
Even if it isn't exactly what you need for your real project, I think this serves as a "known good" starting point, which can serve as a useful reference for troubleshooting. If the "CameraWebServer" example sketch works while your bespoke sketch does not, then that would indicate that the problem is related to something in your code. If the problem also occurs when using the "CameraWebServer" example sketch, this might indicate that the problem is with the ESP32-CAM hardware rather than the code.
So if you haven't already, give that a try. I provided some instructions here:
Hi, i used the example camera web server and now its just stuck booting
ets Jul 29 2019 12:21:46
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4916
load:0x40078000,len:16492
load:0x40080400,len:4
load:0x40080404,len:3524
entry 0x400805b8
