Esp32-c6, arduino IDE and SH1106 oled on I2C
I'm trying to work with the esp32-c6 (with ESP32 Arduino Core 3.0.0rc), got around some glitches but am having some issues with I2C. I'll start with what works : I can scan the devices with this code
* LAB: 17
* Name: ESP32 I2C Scanner
* Author: Khaled Magdy
* For More Info Visit: www.DeepBlueMbedded.com
#include <Wire.h>
#define I2C_Freq 100000
#define SDA_0 6
#define SCL_0 7
TwoWire I2C_0 = TwoWire(0);
  I2C_0.begin(SDA_0 , SCL_0 , I2C_Freq);
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    I2C_0.beginTransmission(address);
    error = I2C_0.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
I tried many examples for the sh1106 oled from different libraries, adding the #defines at the top of the working code, but no sign of life from the screen.
Anybody got his working on a esp32-c6?
Will add examples if needed.
I was succesful with another library :
   The MIT License (MIT)
   Copyright (c) 2018 by ThingPulse, Daniel Eichhorn
   Copyright (c) 2018 by Fabrice Weinberg
   Permission is hereby granted, free of charge, to any person obtaining a copy
   of this software and associated documentation files (the "Software"), to deal
   in the Software without restriction, including without limitation the rights
   to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
   copies of the Software, and to permit persons to whom the Software is
   furnished to do so, subject to the following conditions:
   The above copyright notice and this permission notice shall be included in all
   copies or substantial portions of the Software.
   THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
   IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
   FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
   AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
   LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
   OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
   SOFTWARE.
   ThingPulse invests considerable time and money to develop these open source libraries.
   Please support us by buying our products (and not the clones) from
   https://thingpulse.com
// Include the correct display library
// For a connection via I2C using the Arduino Wire include:
#include <Wire.h>               // Only needed for Arduino 1.6.5 and earlier
//#include "SSD1306Wire.h"        // legacy: #include "SSD1306.h"
#include "SH1106Wire.h"   // legacy: #include "SH1106.h"
// For a connection via I2C using brzo_i2c (must be installed) include:
// #include <brzo_i2c.h>        // Only needed for Arduino 1.6.5 and earlier
// #include "SSD1306Brzo.h"
// OR #include "SH1106Brzo.h"
// For a connection via SPI include:
// #include <SPI.h>             // Only needed for Arduino 1.6.5 and earlier
// #include "SSD1306Spi.h"
// OR #include "SH1106SPi.h"
// Optionally include custom images
#include "images.h"
// Initialize the OLED display using Arduino Wire:
//SSD1306Wire display(0x3c, SDA, SCL);   // ADDRESS, SDA, SCL  -  SDA and SCL usually populate automatically based on your board's pins_arduino.h e.g. https://github.com/esp8266/Arduino/blob/master/variants/nodemcu/pins_arduino.h
// SSD1306Wire display(0x3c, D3, D5);  // ADDRESS, SDA, SCL  -  If not, they can be specified manually.
// SSD1306Wire display(0x3c, SDA, SCL, GEOMETRY_128_32);  // ADDRESS, SDA, SCL, OLEDDISPLAY_GEOMETRY  -  Extra param required for 128x32 displays.
SH1106Wire display(0x3c, 6, 7);     // ADDRESS, SDA, SCL
// Initialize the OLED display using brzo_i2c:
// SSD1306Brzo display(0x3c, D3, D5);  // ADDRESS, SDA, SCL
// or
// SH1106Brzo display(0x3c, D3, D5);   // ADDRESS, SDA, SCL
// Initialize the OLED display using SPI:
// D5 -> CLK
// D7 -> MOSI (DOUT)
// D0 -> RES
// D2 -> DC
// D8 -> CS
// SSD1306Spi display(D0, D2, D8);  // RES, DC, CS
// or
// SH1106Spi display(D0, D2);       // RES, DC
#define DEMO_DURATION 3000
typedef void (*Demo)(void);
int demoMode = 0;
int counter = 1;
  // Initialising the UI will init the display too.
  display.init();
  display.flipScreenVertically();
  display.setFont(ArialMT_Plain_10);
void drawFontFaceDemo() {
  // Font Demo1
  // create more fonts at http://oleddisplay.squix.ch/
  display.setTextAlignment(TEXT_ALIGN_LEFT);
  display.drawString(0, 0, "Hello world");
  display.setFont(ArialMT_Plain_16);
  display.drawString(0, 10, "Hello world");
  display.setFont(ArialMT_Plain_24);
  display.drawString(0, 26, "Hello world");
void drawTextFlowDemo() {
  display.drawStringMaxWidth(0, 0, 128,
                             "Lorem ipsum\n dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore." );
void drawTextAlignmentDemo() {
  // Text alignment demo
  // The coordinates define the left starting point of the text
  display.drawString(0, 10, "Left aligned (0,10)");
  // The coordinates define the center of the text
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.drawString(64, 22, "Center aligned (64,22)");
  // The coordinates define the right end of the text
  display.setTextAlignment(TEXT_ALIGN_RIGHT);
  display.drawString(128, 33, "Right aligned (128,33)");
void drawRectDemo() {
  // Draw a pixel at given position
  for (int i = 0; i < 10; i++) {
    display.setPixel(i, i);
    display.setPixel(10 - i, i);
  display.drawRect(12, 12, 20, 20);
  // Fill the rectangle
  display.fillRect(14, 14, 17, 17);
  // Draw a line horizontally
  display.drawHorizontalLine(0, 40, 20);
  display.drawVerticalLine(40, 0, 20);
void drawCircleDemo() {
  for (int i = 1; i < 8; i++) {
    display.setColor(WHITE);
    display.drawCircle(32, 32, i * 3);
    if (i % 2 == 0) {
      display.setColor(BLACK);
    display.fillCircle(96, 32, 32 - i * 3);
void drawProgressBarDemo() {
  int progress = (counter / 5) % 100;
  // draw the progress bar
  display.drawProgressBar(0, 32, 120, 10, progress);
  // draw the percentage as String
  display.drawString(64, 15, String(progress) + "%");
void drawImageDemo() {
  // see http://blog.squix.org/2015/05/esp8266-nodemcu-how-to-create-xbm.html
  // on how to create xbm files
  display.drawXbm(34, 14, WiFi_Logo_width, WiFi_Logo_height, WiFi_Logo_bits);
Demo demos[] = {drawFontFaceDemo, drawTextFlowDemo, drawTextAlignmentDemo, drawRectDemo, drawCircleDemo, drawProgressBarDemo, drawImageDemo};
int demoLength = (sizeof(demos) / sizeof(Demo));
long timeSinceLastModeSwitch = 0;
  // clear the display
  display.clear();
  // draw the current demo method
  demos[demoMode]();
  display.drawString(128, 54, String(millis()));
  // write the buffer to the display
  display.display();
  if (millis() - timeSinceLastModeSwitch > DEMO_DURATION) {
    demoMode = (demoMode + 1)  % demoLength;
    timeSinceLastModeSwitch = millis();
  counter++;
  delay(10);
Welcome to the forum.
Can you take a step back ?
You have a ESP32-C6 board ? Can you give a link to it ? Preferably a link to where you bought it.
There are a few different versions. I see that Adafruit has one: https://www.adafruit.com/product/5672
Are you using the newest Arduino IDE ?
And you are using the board definitions from Espressif themselves ? Is there a link for the release candidate ? (I can not find it).
The current version for "esp32" is still 2.0.16.
The Arduino build environment for ESP32-C6 might still have bugs. The upgrade to version 3 seems a major upgrade.
:point_right: To stay out of trouble, please always use the most common and the most simple and the most used predefined settings. :point_left:
So please use the default pins for the I2C and SPI bus.
Don't use this:
It might result into a bad mix. Use "Wire" and perhaps "Wire1" and "Wire2", depending on how many I2C buses are supported.
It seems that the default pins are at 23 and 22 for the I2C bus: https://github.com/espressif/arduino-esp32/blob/master/variants/esp32c6/pins_arduino.h
In the second (working) example, you are relying on the display library to call Wire.begin() with the normal "Wire" object. Can you put also a Wire.begin() in setup() ?
We chose this one : https://www.waveshare.com/wiki/ESP32-C6-DEV-KIT-N8
Newest ESP-IDF, newest Arduino and ESP32 (v3.0.0rc).
That board has lp_i2c on gpio6 and gpio7, so this is what I'm using.
I will try wire.begin() in setup, but it works fine without and doesnt interfere with a mcp23008 on the same bus.
Adafruit puts often a Wire.begin() in their libraries, just to be sure.
You can add it to setup(), to show that you are going to use the Wire library.
About 7 or 8 dollars for a low power RISC-V with WiFi 6 and Bluetooth 5, that is pretty good.
My point was not to copy weird code from old and outdated tutorials, for example with the "TwoWire(0)". Use what is already prepared for you. Less is better: less code, less weird things, less workarounds for things that are not even a problem, less fixes for things that do not need to be fixed.
Adafruit has their OLED library for their own OLED displays. You might encounter some compatible problems anyway, regardless if you are using a ESP32-C6.
